1988 Buick Skylark 3.0 Litre Updated
Thanks Nos So Far For Your Suggestions. So Far: Car Sat For A Bit Before Returning To Service. Replaced - Transmission, Timing Chain/...
rugruv
BUICK SKYLARK
1996 Audi A4 2.8
Car Will Not Scan, I Need To Clear The Computor For The " Check Engine Light". I Just Replaced The Temp Sensor For The 2nd Time And Want To...
jason12
AUDI A4
1991 Ford Explorer Stalling
My Truck Keeps Stalling And Its Getting Annoying, It Does It At Idle And While Cruising. It Also Drags Sometimes Which Is Kind Of Annoying...
HatTrickTech
97 Chrysler Only Heats Up When I Move..
How Long Would It Take To Replace The Water Pump? It Only Heats Up When I Press The Gas Pedal. But When I Let Off The Gass. It Gets Cold....
foreveryoung88
CHRYSLER OTHER
Engine Swap
I Own A 1995 Mazda Mx-6 24 Valve V6. My Transmission Recently Went Out And Am Thinking Of Puting A 2002 Toyota Camry Engine And Trans My...
miguel
MAZDA MX5
1993 Ford Ranger V6 3.0L Supercab
Right Turn Signal Works Fine, But When Using Left Turn Signal, Rear Lamp Goes On And Stays On Without Flashing, Front Lamp Doesn't Turn...
jc2545
Camry 1995, Engine Rpm Fall And Car Doesn't Start...
Hi, My Toyota Camry Le 1995, Started Off Nice Yesturday, But With In 1/4 Mile The Engine Rpm Went Down Drastically And Car Came To A...
venkat
VR6 Jetta Hiccups, Sometimes Hesitates.
Hi, My Jetta Has This Problem For A Year Now, Here Are The Facts: 1. No Check Engine Light. 2. Does Not Hiccup All The Time. 3....
cebuano
Car Heaters
Why Does Car Heaters Blow Cold Air Even Thou The The Car Is Warm Thanks
hallix
Rear Main Oil Leak
I Have A 1975 Jeep Wagoneer W/ 360 Ci And Auto Trans. My Rear Main Seal Is Leaking And Was Wondering If This Something I Can Do Or Should A...
hoodrat
JEEP WAGONEER
Oxygen Sensor
How Often Should We Change The Oxygen Sensors. Some Say Toyoto Sensors Seldom Fails But Other Says It Should Be A Part Of Regular...
jrmassey
ML320 OIL CAPACITY
I Am In The Marine Corps, Currently Serving In Iraq. My Wife Took Our 2001 Mercedes Ml320 For An Oil Change And Was Charged $120. She...
MORRISONJL
1932
MERCEDES BENZ OTHER
1993 Nissan Maxima Milage: 145,000
93 Nissan Maxima Milage: 145,000 My Har Hestitates/bucks When Accelerating/changing Gears. Do I Need To Change The Engine Wires Or Is It...
afogel
NISSAN MAXIMA
1989 Olds 98
I Recently Bought An Oldsmobile 98 Regency. I Love My Car, But The Only Thing That I Have Noticed That Drives Me Absolutely Crazy, Is...
neclark
1995 Chevy 1500 Gas Mileage
Is 250 Miles Good For A 1995 Chev 1500 5.7 Z71 On A 23 Gallon Gas Tank? Or Could It Be Improved?
nos155
Engine Trouble With 99 Civic Si With Gsr Swap
99 Honda Civic Si With A 94 Integra Gsr Swap With 70000 Miles. My Vtec Is Not Coming On Like It Is Supposed To. The Car Is Cutting Off When...
hondasi
1999.5 Nissan Pathfinder Pinging Noise
Hello, I Live In The Very Hot Dominican Republic. Purchased A Used Pathfinder And It Has Been Fine For 2 Years. Now, I Have This...
JohnnyBoyFloyd
2003 Jeep Cherokee Electric Fan Motor
My 03 Jeep Grand Cherokee With 45k. The Fan Motor Stays On After The Engine Is Off. I Thought At First It Would Stay On For A While Because...
ROD REED
Stalling
I Have A 2000 Mitsubishi Eclipse With 60,000 Miles. My Problem Is When The Engine Is At A Normal Running Temp. And The Car, Is Idle It Is...
help
MITSUBISHI OTHER
1994 Toyota Camry 5 Speed 88,500k Miles
Leaks Oil Only When In Neutral: Was Told It Might Be The Rear Main Seal, But I Have My $1200.00 Doubts :shock: Any One Know For Sure What...
Marip
Emergency Brake Problem
Recently I Bought Honda Civic 2005 Value Pack Sedan Dx Mileage 18,000, Auto Transmission. Today While Driving From My Workplace To Home, I...
dpurva
Fuel Pump
My Car Is A 2000 Sunfire, 2.2l, My Fuel Pump Seems To Be Working But It Is As Though It Over Heats And Shuts Down Until It Cools Off....
scouties
'95 Cavalier Wheel Bearing
Hi, I Don't Know A Lot About Cars And I Need To Find Out How To Replace The Right Front Wheel Bearing On My 95 Cavalier. Any Help Would...
boozer1086
Stalling Car
I Have A 1995 Chevy Corsica. It Starts Up With No Problem At All But When You First Go To Take Off It Dies. It Will Always Start Right Back...
prettyred
1989 Cutlass Ciera Stalling Problem
Car: 1989 Olds Cutlass Ciera 3.3l 81,000 Miles Problem: Went To Work One Day Car Ran Great Go To Leave The Car Has A Hard Time Starting...
Kattatonik916
20151
20152
20153
