Camry 1995, engine RPM fall and car doesn't start anymore
VENKAT
  • 1995 TOYOTA CAMRY
My toyota camry LE 1995, started off nice yesturday, but with in 1/4 mile the engine rpm went down drastically and car came to a abrupt halt. It doesn't start anymore. What could be the possible reason(s). If so how much am I looking at to get it fixed.
Do you
have the same problem?
Friday, March 3rd, 2006 AT 9:48 AM
FISHERMAN
Did you check for spark on the spark plugs?
How about gas?
Eveything turns off?
There is a lot off posible causes.
Gas Pump, coil, switch, fuse.
Friday, March 3rd, 2006 AT 9:55 AM
VENKAT
Yes,
the gas was about half a tank.
Battery is in condition.
When I try to kick up the engine it doesn't catch.
But engine was running for like 5 minutes befor it came to a halt!
Friday, March 3rd, 2006 AT 10:13 AM
FISHERMAN
Well.
It "cranks"
but not start.
Any simptoms before?
Like check engine light on. Hesitation. Or it was runnig just fine.
Did you drive your car with low gas tank before?
If so, could be a pump problem.
Or ignition problem like coil or ignition module. Even a switch.
Do you know something about mechanic problems?
Friday, March 3rd, 2006 AT 10:45 AM
AMANDA
I had my 1995 Camry into a shop after it died on the side of the road and had the clutch replaced and also the timing belt. Two weeks later it dies again. Had it towed home had the alternator and battery checked both are okay. The car "cranks" but doesn't catch. Sounds similiar to this situation.
Any suggestions
Tuesday, April 24th, 2007 AT 7:37 AM
Check the coil, ignitor, and fuel pressure
Tuesday, April 24th, 2007 AT 5:24 PM
Recommended Guides
