92 Tercel Temperature Dropping Problem
Color=black]my Girlfriends Canadian 1992 Toyota Tercel Has 230k Kms And Recently Had A Head Gasket Done. Ever Since, When You Drive At...
peter411
TOYOTA TERCEL
Ford Windstar 2000 Not Auto Shifting To Higher Gears/...
Have A Ford Windstar 2000 With 108k Miles. Runs In Drive, But Would Not Auto Shift Gearup To Higher Speeds (max Is About 25) Unless I...
mikeo
1.8L TROUBLE CODES
I Have A 1993 Mercuy Tracer Lts With 95228 Miles. Recently It Died On Me While Driveing Down The Road. I Did The Test On It With The Check...
mcleod7881
1994 Isuzu Rodeo S V6 Trasnmissions Problems...I Think...
My Truck Has Been Running Perfectly For The Last 5 Years. No Problems, New Brakes, New Tires. Over The Last 3 Years, We Took Maybe 20...
KeithMSmith
Odometer Quit After Clutch Replacement
We Recently Had The Clutch Replaced In Our 1993 Saturn Sc2. Noticed That The Odometer Was Not Working. Took It Back To Repair Shop And...
Marmy5
2001 Malibu P1404 Code
My 2001 Malibu Has 15,000 Miles (new Engine Dropped In At 13,000) In June 2005. Now My Check Engine Light Comes On. Took To My Local...
kevindarlene
Check Engine Light
I Have A 1995 F 150. Just Replaced The Plugs And Wires And The Check Light Came On. I Do Have 225000 Miles On It But The Light Has Never...
jasono
Check Engine Light Comes On Tps,and Engine Dies Out
I Own A 1996 Gmc Serria C1500 With 4.3l And 153266 Miles. Problem Check Engine Comes On For Tps Code Po122. And Engine Dies Out At Idle Wont...
reynaldov
1998 Ford Escort Problem
I Have A 1998 Ford Escort With 120,000 Miles. It Idles Rough And Has No Power. I Changed The Coil Pack After Realizing That #1 & #4 Plug Was...
Texbuck
Starter
Have A 1998 Chevy Camaro With 165,000 Miles. Car Would Not Start And It Sounded Like The Battery Died. Replaced Battery And The Car Still...
gilbert gonzales
Turn Signal Doesn't Click Into Place
One Day While Driving Around The Turn Signal Stuck In The Right Turn Position And Wouldn't Come Out So I Did What Any Man In This Position...
jeffrey e hoffman
4.2 Liter Engine Questions
I Have A F-150, 2003, With 104,000 Miles On It. I Change The Oil Every 3000 Miles, No Problems There. Engine Is Sound. I Need To Change...
turfmanager
Transmission Problems
About A Month Ago I Replaced A Starter On My 92 Plymouth Acclaim, Next Morning It Ran Fine On The Way To The Car Wash Were I Gunked Down...
kevdeb
PLYMOUTH ACCLAIM
95 Camaro
Ive Recently Replaced Three Starters In My 95 Camaro 350 After The Second I Replaced The Fly Wheel And The Problem Persisted What Could Be...
michaelphlr
Blows Blue Smoke When Cold
91 Chevy S10 Blazer About 129,327 Actual Milage It Blows Blue Smoke While Cold As Soon As I Start It Up Bloes Blue Smoke For About 5 To 10...
cms
Won't Start At All
1987 Ford Aerostar, 3.0 V-6, Manula Transmission. It Has Only 65,000 Miles On It. It Had Been Sitting For 5 Years Without Being Driven....
bartmcajas
FORD AEROSTAR
Pinging - Detonation
I Have A 2000 Mustang Gt With 122,000 Miles. At 4,000 Rpm's I Am Getting A Bad Pinging (detonation). Does Not Matter If I Am At Wot Or Not...
dstryker24
Chevy Fuel Line
We Are Looking Into Buying A Car Which Is A Good Deal, Very Good But Has A Fuel Line Leak. How Much Is A Repair. The Car Is About 1987 May...
ekbest
Knocking Noise Rear Of Car
Hi, I Have A Fiat Punto 1996, I Have Just Put It Through Its Mot, Before I Put It Through It Had A Knocking Noise From The Rear Of The...
misswise
FIAT OTHER
Brakes
I Have A 1999 Saturn Sl With 75000+ Miles. When I Got In To My Car I Press On The Brake And The Brake Peddle Went Clear To The Floor. I...
ljlj
My Car Wants To Die
Hyundai Accent 2001 About 94,000 Miles. When My Car Is Idling It Wants To Die. I've Changed The Spark Plug And Wires And It Helped But Only...
eliza
HYUNDAI OTHER
1994 GMC Safari Assorted Problems
I Just Bought This Car Two Days Ago. Whenever I Turn On The Headlights, Dash Illumination For The Spedometer Etc Won't Come On, But All...
shadowtree
GMC SAFARI
93 Mazda No Starting After Getting Hot.
My Son Has A 93 Mazda Protege, It Seems To Always Start Cold But After Driving For 20 Min. Or So When He Stops And Shuts It Off It Will Not...
allen_p
MAZDA PROTEGE
1989 Pontiac Grand Am
I Have A 1989 Pontiac Grand Am It Has About 120,000 We Was Doing A Tune Up And I Got Lazy And Didnt Remove The Alternator And Then We...
Wendy Mitchell
Starting Stumper
1998 Dodge Grand Caravan, 120,000 Miles. I Love My Van When It Runs. About A Year And A Half Ago, We Started Having Problems With...
lenzmom
20150
20151
20152
