1993 Ford Ranger V6 3.0L Supercab
JC2545
  • 1993 FORD RANGER
Right turn signal works fine, but when using left turn signal, rear lamp goes on and stays on without flashing, front lamp doesn't turn on. Could this be as simple as new bulb for front lamp or does it sound like turn signal flasher failing? If turn signal flasher is failing, how do I replace that?
Do you
have the same problem?
Friday, March 3rd, 2006 AT 10:16 AM
DB554
Front bulb is burned out
Friday, March 3rd, 2006 AT 4:28 PM
Recommended Guides
