2000 Explorer. Rattle Noise At High Speed
My Ford Explorer Sport 2000 (manual Transmission) With 60000 Miles Has Had A Noise For About 4 Months. It Is Like A Rattle But Not To Loud....
abiezer73
2001 Chevrolet 6.0. I Get A Code P0307 ?
I Need Some Help! I Have A 2001 Chevrolet 6.0. I Get A Code P0307 Which Is #7 Cylinder Misfire, I Have Changed Plugs, Wires Coil, Fuel...
STACYP260
GMC C2500
Code Problems
Today My Coolant Light Came On. I Drained And Flushed My Radiator, Then Filled It Back Up With Dex-cool. It Is Definatley Full, But The...
Andy01
Dropped A Washer In The Distributor Hole
Just As It Says. A Washer Slipped Out Of My Hand And Into The Distributor Hole. I Just Did A Complete Rebuild On It And Was Planning On...
ImpalaKarma
1992 Acura Starting Issue - Help
Check The Battery Cable Connections For Corrosion At The Battery And Starter First. Check The Ground Connections From The Battery To The...
peppermrj
94 Isuzu Amigo Transmission
I Have A 94 Isuzu Amigo 2.6 Liter W/ 5 Speed Manual Transmission. I Just Replaced The Transmission And Put In A New Clutch And New Clutch...
MWGlass
93 Dodge Grand Caravan With 240000 Miles
My Van Is Not Burning All Of The Gas. There Is Gas Coming Out Of My Exhuast As Well As Smoke. It Is Not Burning Oil Though. It Has Had...
teddyadms5
Windshield Wipers
I Have A 1989 Chevy Celebrity, With 139,000 Miles On It. The Wipers Won't Work. The Motor Runs, And The Arms Make A Clicking Sound. I...
redneck34142
Ford Mustang 85 130,000 Miles
85 Mustang Ii Tries To Start When Connecting The Battery While There Is No Key In The Ignition! Car Then Starts And The Engine Sounds...
'85MustangII
1985
92 Pontiac Bonneville SSE Engine Dies While Driving
The Engine Dies While Driving. Will Start Again After Waiting About 10 Minutes. This Usually Happens After I Have Driven Some Distance And...
texashatlady
PONTIAC BONNEVILLE
94 Camry Check Engine Light
The Check Engine Light On Toyota Camry 94 V6 139k Came On.I Tried To Check It At Different Autozone Locations - They Didnt Have An Adaptor...
2g
Stuck Ignition
I Have A 2004 Ranger. The Ignition Is Stuck And I Can't Figure Out Why. Do I Need To Replace The Ignition Assembly? Does Anyone Know Of...
haddy21
Steering Shake
Hi, I Have A 1990 Nissan, 240 Sx. The Only Problem I Have Is In The Steering Wheel. In Between 35 And 45 Mph (around There). My Steering...
hope4thafuture
NISSAN 240SX
1997 Ford Escort LX - Wagon, Mileage 108414
I Recently Purchased This Vehicle. Had All Fluids Changed. Decided To Change Plugs And Wires Myself. Auto Part Store Only Had Bosch...
oladd
95 Caravan Won't Idle
My 95 Caravan 58,000 Miles Would Not Start After I Inadvertently Left The Lights On. I Jumped It And Now It Won't Idle. Its Never Had A...
krzy18
Water Leak
Water Is Leaking Between My Head And My Block
fiki123
BMW OTHER
Does Tappet Gasket Leak Make Sense For Intake Vaccum...
I Have Toyota Cressida 1979, Since Couple Of Weeks I Am Trying To Locate Intake Vaccume Leak Which Is Giving Bing Pain In Driving. My Whole...
ahmedmir
TOYOTA CRESSIDA
88 Chevy Pickup 4.3 L V-6 130,000 Miles
Water Pump Went And Mechanic Said It Will Be $300.00 To Replace. Is That High? I Don't Have Air Conditioning And The Pump Looks Very...
rick37thompson
1998 Ford Escort Zx2 Stalls
I Bought A 1998 Ford Escort For $500 It Had No Start I Changed The Crank Sensor And Know I Have Fire. Car Now Runs.I Test Drive It For About...
motoup437
Brake Light Wiring Diagrams? When I Step On The Brakes...
When I Step On The Brakes The Right Directionals Light Up Solid With The Brake Lights. The Bulbs All Seem To Be Intact. Is It A Ground? Is...
kvpoll
Ford Taurus Headlight
I Have A 1998 Ford Taurus With 118,123 Miles On It. The Bright Headlights Are On All The Time And Will Not Shut Off When The Key Is Turned...
2678388
An Irritating Clicking Noise
I Have A 1988 Cultass Ciera International That I Love. But Every Time I Turn On My Car I Hear This Clicking Noise Coming From What My Father...
mizz_lady
Compression
I Was Given A 1973 Plymouth Valiant. I Checked The Compression From Front Of The Engine To The Back Was 90, 90, 90, 0, 90, And 155....
rainedout2000
PLYMOUTH OTHER
94 Ford Explorer Ignition Trouble
I Own A 1994 Ford Explorer Xlt With 213,000 Miles. Sometimes (whenever It Feels Like It), My Truck Will Just Lose Ignition Or Just Won't...
sponger
1998 Ford Contour GL
I Have A 1998 Ford Contour Gl With 93,000 Miles. I Have Had The Car For About 1 1/2 Years But I Have Driven It Less Than 2,500 Hundred...
lshipley
FORD CONTOUR
20138
20139
20140
