MY Car Doesn't Recognize My Key Is In The Ignition
The Other Day I Was Messing With My Radio On My 1999 Mercury Cougar And A Wire Touched The Back Of The Radio, And Now My Car Doesn't Even...
omari300
Driver Side Lock Is Stuck
My 1999 Taurus Driver's Door Was Open And My Son Flicked The Latch On The Side Of The Door That Catches Onto The Body Of The Car. The Car...
mrtrevenen
97 Dakota 2.5 STALLING ISSUES
My Dakota Driving Me Nuts. Mechs Have Ripped Me Off. When Ever I Slow Down Truck Stalls Out. No Codes Coming Up. Have Replaced Map Sensor...
titantium3x
Power Steering
Hello, I Have A Skoda Fabia 1.4, 2000 The Warning Light Of The Powersteering Came On, Which Means That The Hydraulic Fluid Level Is Too...
parsa4u
1986 Ford F150 Stalls After Short Run
1986 Ford F150 With 120,000 Miles. My Ford 1986 F150 Cranks And Runs Down The Road About A Mile, Then Stalls. After It Stalls, I Can...
pjaska
1993 Toyota Celica GT 150,000miles... Lights Flicker
I Recently Replaced The Headlight Assemblies For This Car After An Accident. I Spliced The Wires. This Was Fine For Over A Year And Half...
KGOPEL
TOYOTA CELICA
2000 Mazda Protege - Pinging, Lifter Noise
2000 Mazda Protege (1.6 Liter), Manual Transmission. 80,800 Miles. Light To Moderate Pinging, But This Only Happens When Outside Temp Is...
kainos
MAZDA PROTEGE
Bacward Jump
Hello Everyone, I Made A Rather Large Mistake When I Jumped My Girlfriends 95 Nissan Pathfinder Backwards. I Smelled A Burning Toxic Smell...
boomer
92 Tempo: Removing The Distributor
I'm Trying To Replace The Distributor On My 92 Tempo Gl, But The Problem Is I Have No Idea Where The Mounting Screws Are! Usually On My...
fordexplo
Cannot Locate Signal Flasher On 1990 Plymouth Sundance
I Cannot Seem To Locate The Signal Light Flasher On My 1990 Plymouth Sundance. I Can Locate The Harzard Flasher, Horn Relay And Ignition...
tp123
PLYMOUTH OTHER
4wd Auto Difflock
The Auto Difflock Doesent Work On My Sportage 1999 Mod Is There Any Thing I Can Do With Out Taking It To A Garage?
steve1
Honda 2003 Accord Right Turn Signal Stopped...
The Right Turnsignal On My 2003 Accord Stopped Wroking Completely. No Lights Come On Either Inside The Car Or Outside. I Am Used To A Burned...
tonysa
V-tec Engine
It Would Seem That Ther V-tec On My 1999 1.6 Honda Civic Does Not Kick In, What Can Be Causing This? The Car Has Done 68,000 Miles Ally
ally990
Honda Accord EX 97 Makes Noise In Reverse
The Car Runs Great, It Just Makes A High Pitch Noise When I'm Driving In Reverse, Which It Stops Sometimes When I Tap In The Brakes, Then...
diegoborgh
Low Idle Spiting Sputtering And Dying
I Am A Chef Not A Mechanic But Anyway I Have A 1990 Mercury Topaz With A 4 Cyclinder Motor When The Car Is Idling Or A Very Low Speeds The...
JFrank
Timing Belt
I Installed A Timing Belt On A 1999 Subaru Legacy Outback. I Lined Up All The Marks On The Timing Belt According To The Gears, All Lined Up...
mjdragos
SUBARU OTHER
BATTERY/ALARM
How Do I Disconnect The Alarm System From A 1994 Toyota Camry? I Replaced The Battery And Now The Alarm Continues To Go Off. My Remote No...
rflackey
TCC Solenoid
Can Someone Tell Me Where The Plug Is For The Tcc Solenoid On A 1991 Beretta 3.1 Is.
robort
1992 Oldsmobile 88 Royale 167,000 Mi Stalls
Car Runs Fine On The Interstate. When Slowing Down In Local Traffic, Or Running Into A Store For A Moment, Car Will Stall/not Start. Car...
cantw82
Cooling System Problem
I Have A 2000 Pontiac Grand Am 3.4 V6 With 120,000 Miles. I Had Overheating Problems About 500 Miles Ago So I Took The Car To Our Local...
Matt Reilly
Engine Won't Turn Over Properly
Gentleman, I Have A 1963 Ford Thunderbird That I Recently Inherited From My Dad. It Has Been Garaged For 18 Years And Only 92,000 Miles.I...
jimn0421
FORD THUNDERBIRD
Problems With The Clutch
1999 Ford Mustang Gt Mileage: 69242. I Was Wondering If It Is Normal For The Clutch Pedal To Feel Rough When You Push Down On It And...
juliaberger
2001 Nissan Maxima - A/C & Steering Shake Seems To...
I Bought 2001 Nissan Maxima 2 Months Back. Never Used A/c So Far, When I Was Using A/c Last 2 Weeks Back. I Don;t See A/c Is Working Very...
rprabhuattur
NISSAN MAXIMA
Mazda B2000 Motor Siezing After It Turns Over Twice
Have An 87 Mazda B200 With 100,000 On It Just Replaced The Head On It.I Lined Both The Timing Marks And Put Everything Back Together Right...
jjr24
MAZDA TRUCK
My 1999 Taurus
Hello, I An Thinking About Buying A Friends Ford Taurus 1999 With A 3.0 Motor. We Put A Scan Tool On It And It Said Cylinder 6 Misfiring...
tallmankaa
20137
20138
20139
