Replace shift tube truck will not start but will turn over
PSELL
  • 1995 FORD F-150
  • 5.8L
  • V8
  • 4WD
  • 15,600 MILES
Had to replace shift tube in steering column, now truck will turn over but not run? Any help would be awesome!
Do you
have the same problem?
Monday, February 10th, 2020 AT 7:59 AM
  • EXPERT
Good morning,
Did you verify the connections for the ignition switch?
Check the output at the switch with the key on. I highlighted the wires you need to test.
Monday, February 10th, 2020 AT 8:24 AM
PSELL
Thank you, will check it this evening. Thank you
Monday, February 10th, 2020 AT 9:02 AM
  • EXPERT
You are welcome.
Always glad to help.
Monday, February 10th, 2020 AT 9:20 AM
