Not cranking over
DRJ232002
  • 2008 DODGE CALIBER
  • 76,000 MILES
I have no crank, turn key and nothing. I jumped the solenoid wire and the starter spins but no fuel and or spark. I really need to know if there are any other relays other than what is in the driver fender. Also, if there are any other start fuses other than what are in the TIPM (Total Integrated Power Module). I have the service manual and am doing test light diagnosis but am stuck. I have an idea that it is the ECM (Engine Control Module) but I wanna know why. It ran fine when parked. We had a thunderstorm roll through middle of the night and next morning. Nothing, no crank or nothing.
Do you
have the same problem?
Tuesday, September 17th, 2013 AT 12:04 PM
SATURNTECH9
I have seen the TIPM cause this problem but to be sure let's check for power output to the starter solenoid. Here is a wiring diagram so you can see how the starter wiring works, use a test light by following this guide, test the yellow and grey wire
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Tuesday, September 17th, 2013 AT 12:46 PM
DRJ232002
Had a Snap-On "Ethos" reader here briefly and it could not communicate with the engine and spit out code- could not communicate with the ECM/PCM (U0100) with a few other codes but that seemed to be the big one. I am about burnt out on it. Tried a ton of things. Trying to use the service manual to diagnose. Thing I found out, this car had front end damage at one time and we didn't know that when we bought it. These Calibers are notorious for electrical trouble, especially with previous front end damage. I was checking some of the wires under the battery tray that go into the driver fender. The battery tray is pretty heavy duty. It is almost broke completely in half. I dunno what to do. Gonna have to buck up and tow it in I spose.
Tuesday, September 17th, 2013 AT 12:52 PM
SATURNTECH9
This furthers my thought on the bad TIPM here are diagrams and instructions to help you replace it. This unit is plug and play it self initializes.
Tuesday, September 17th, 2013 AT 1:01 PM
DRJ232002
I have checked before. Wiring seems to be OK. I am not sure which of the 4 is the main relay though. It has 3 that are supposed to be radiator fan. There are 3 on one side and one alone in the corner on other side. I know the one alone in the corner is a fan relay. Hit it with the test light and the fan started up. They aren't the bigger square ones, they are the smaller rectangular relays.
Tuesday, September 17th, 2013 AT 1:09 PM
SATURNTECH9
In the totally integrated power module number 18 40amp is ASD relay contact power feed. Number 23 is 15 amp engine ASD relay feed number 3. Number 26 is 15amp engine ASD relay feed. Number 32 is 30 amp engine ASD control feed 1.
Tuesday, September 17th, 2013 AT 1:21 PM
DRJ232002
I got a new TIPM for $233.00 and installed it everything is working as it should thanks for your help I love this site.
Tuesday, September 17th, 2013 AT 1:24 PM
SATURNTECH9
Nice work, we are here to help, please use 2CarPros anytime
Tuesday, September 17th, 2013 AT 1:39 PM
STACEY88LYNNE
  • 2007 DODGE CALIBER
  • 2.0L
  • 4 CYL
Checked fuel pressure and it's good. Still won't crank. Desperately need help.
Wednesday, December 28th, 2016 AT 10:25 AM (Merged)
  • EXPERT
If you use starting fluid, will it start for a couple seconds?
STACEY88LYNNE
It's fuel injexted. I'm dumb where do I spray it
  • EXPERT
In the throttle body
STACEY88LYNNE
  • 2.0L
  • 4 CYL
  • 179,000 MILES
Ran out of gas put gas in now does nothing but spin please help
WRENCHTECH
In tank fuel pumps are cooled and lubricated by the fuel in the tank. When you run a car out of gas or very low, it pumps a lot of air through the pump which overheats it and causes some severe wear and many times, failure when they cool off.
You will need to use a fuel pressure gauge to verify this
DENISE6328
Engine Mechanical problem
2007 Dodge Caliber 4 cyl Two Wheel Drive Automatic
we put a obd2 scanner on it. It gave us 2 codes one was the fuel level sensor and the engine oil pressure sensor but we dont even know where to find these on the car could you please help we cant find a repair manual for this car so we have no schematics for the engine
Wednesday, December 28th, 2016 AT 10:26 AM (Merged)
  • EXPERT
Hi:
I believe the oil pressure sensor can shut down the engine if it indicates no pressure. Also, I believe it's near the oil filter.
Let me know what you find.
AWEITNER
  • 4 CYL
  • 61,100 MILES
Dodge Caliber SXT, 2007, 61,100 miles After a trip from Texas to New Mexico and back we pulled into a relatives home, we parked on an incline; initially left the car running. After a few minutes we turned off the vehicle. Fifteen minutes later we started up the car reversed into the street then the gas pedal became unresponsive and the engine sputtered twice before dying. After that the car will not turn over. Today is Christmas, tomorrow is Sunday and I will not be able to get the car into a mechanic until Monday. Any thing to look for or try before I tow it to a mechanic.
NELSONKENN
  • 2.0L
  • 4 CYL
  • 24,537 MILES
The head gasket got burnt. After changing to a new one we couldn't start the car. If you turn on the ignition all the dash board light shows even radio but cannot crank. The relays has been checked okay. But on the dash board no sign of display whether on drive or pack position. Again can changing of battery while the key is at ignition cause this problem and what's the solution? Thank you
Sunday, August 18th, 2019 AT 1:24 PM (Merged)
KEN
  • ADMIN
Can I ask if the security light is flashing when you try to crank the engine over? If so here is a guide to help reset the system.
https://www.2carpros.com/articles/how-to-reset-a-security-system
If not this guide will help walk us through how to test the starter system
Sunday, August 18th, 2019 AT 1:26 PM
NELSONKENN
Thanks for your detailed explanation. From our finds and your suggestion, the starter is okay with the solenoid, but we are thinking about a fault from the starter wiring circuit as u said. So how can you help to resolve this problem
Thanks,
Nelson.
Wednesday, August 21st, 2019 AT 5:35 PM
KEN
  • ADMIN
Can I ask if the security light is flashing? If so here is a guide to help fix it. Here is the starting wiring diagrams so you can see how the system works:
Wednesday, August 21st, 2019 AT 5:37 PM
