Why is my engine overheating?
JWELLMAN
  • 1994 FORD RANGER
  • 4.0L
  • 6 CYL
  • 4WD
  • MANUAL
  • 195,000 MILES
Recently the lower radiator hose busted, after replacing hose and adding antifreeze back I started truck and everything seemed to run the same as in past. Within 5 miles however notice the truck began to overheat. Checked to make sure hose stayed on and it did however after let truck cool down it seem to not want to start acting like it wasn’t getting fuel it needed. After finally starting yet again within few miles the truck continued to overheat. I’m not very mechanically inclined and need to know what I can do myself to try solving problem.
Tuesday, December 10th, 2019 AT 9:37 PM
SCGRANTURISMO
  • 4,897 POSTS
This sounds like your vehicle's thermostat may have stuck shut. Every vehicle has a thermostat in it that allows the coolant to heat up and then it opens at a predetermined temperature to let the coolant flow through the radiator, which cools it. Then the thermostat closes again and the whole process starts over. This allows the coolant to get hot enough so your vehicle has a heater and a defroster. When a thermostat fails it either sticks open or sticks closed depending on how it was when it failed, usually closed. Thermostats are very easy to change and can be done with usually with just a wrench and a screwdriver. In the diagrams down below I have included the Original Equipment Manufacturer [OEM] part number for your reference, a guide explaining all the possible ways your vehicle could overheat for your reference, and instructions for the removal and installation of your vehicle's thermostat. Please go through these guides and get back to us with what you are able to find out. I hope that this helps.
Thanks,
Alex
2CarPros
Wednesday, December 11th, 2019 AT 12:11 AM
BENBEN32178
  • 1994 FORD RANGER
1994 ford ranger, 4 cylinder. Overheating an blows cold air out vents. I changed water pump and thermostat, but still overheats.
Wednesday, October 28th, 2020 AT 2:17 PM (Merged)
SATURNTECH9
  • 30,870 POSTS
Is your radiator fan working correctly? This guide can help us fix it
https://www.2carpros.com/articles/engine-overheating-or-running-hot
DJM76
  • 11 POSTS
Could be radiator or fan clutch
DOCDTC
  • 53 POSTS
With the cold air coming from vents, did you purge the air from the cooling system after the thermostat change? Also, did the truck gradually begin to run hotter, prompting the thermostat and pump change? Have you checked for leaking head gasket? This will cause these symptoms. Doc
JOHN R SIDERS
  • 1994 FORD RANGER
Engine Cooling problem
1994 Ford Ranger 6 cyl Four Wheel Drive Manual
The temp gage keeps going up and down it makes a pressure noise in the over fill then idles ruff
KHLOW2008
  • 41,815 POSTS
Hi John R Siders,
Situation don't look good. Symptoms similar to a head gasket problem.
If coolant level is low, it can cause the problem described.
So does a clogged radiator, faulty thermostat.
When engine is cold, is the coolant level in the radiator high or low?
Do you need to top up coolant regularly?
Check the radiator seals for wear and cracks.
STARCATCHER017
  • 6 POSTS
It is either a head gasket or your radiators that has a problem. It is better to check the radiators for clogs, breakage or any problems in it.
There are no shortcuts to life's greatest achievements.
Ford ranger parts
for hire
CHRIS BLOW
  • 1994 FORD RANGER
1994 Ford Ranger 6 cyl Two Wheel Drive Automatic
i replaced the waterpum and thermostat and the trucks temperature gauge is still going from cold to hot in a matter of minutes. What do you think the problem could be?
DAVE H
  • 13,383 POSTS
Is the vehicle overheating. Or could the coolant temperature sender be faulty?
Coolant Temperature Sending Unit
Ranger
2.3L. On left rear of engine, above oil pressure switch.
3.0L. On top right of engine, near thermostat housing.
4.0L. On top left front of engine
DANGERRANGER09
Try seeing if ur radiator cap is damaged it happend to my car it was cracked and it cased it to overheat and lose all of my collent.
JEFF SCARRONE
  • 1994 FORD RANGER
  • 6 CYL
  • 90,000 MILES
Engine overheated from leaking hose. Added stop leak could not find the exact location at first. Worked for a couple of days, then overheated again. Let cool down for 5 minutes, trickled water into radiator to cool down and fill. Changed hose, ran fine for a couple of months. Started to run warmer than usual, (mid range), no signs of leaks. Topped of system every week or so. Temperature spiked at top of range, (freeway at night, 70 degrees outside), then dropped to mid range. Roughly 10 miles of freeway driving. Drove another 10 miles, (freeway), gauge fluctuating every 10-15 seconds from top of range to lower 1/3 range mark. Changed thermostat, flushed radiator and system. No change. Changed other hose, same thing. Changed pump, tested thermostat again. Gauge spikes to 3/4 range within 2 minutes, then drops to 1/3 for 5-10 seconds, then spikes again in 5-10 seconds. Ran with garden hose in radiator neck, same thing. When cap is off, gushes from neck after 45 seconds, not a steady overflow. Upper hose runs hot as well, lower hose stays cool. Suspected bad heads or block from first overheat. Had both checked. 1 head near warp limit and corrected. Now overheats within 1 minute, the rest is the the same. No problems at all before this mess. Next step is dynamite!
BLACKOP555
  • 10,371 POSTS
Upper hose is hot. Lower is cool?
Suspect faulty thermostat, bad water pump, restricted radiator, trying having it rodded out. Or take it off and apply radiator flush to it and keep running it through.
  • 108,269 POSTS
I read through you description of what is happening. I have a couple ideas that could be causing this. First, you mentioned that within 2 minutes, the vehicle reaches the 3/4 point. That is hard to believe it would happen that quickly. Have you checked the coolant temperature sensor? It may be sending random signals.
The first thing I would check for are diagnostic trouble codes. Here is a link that explains how to retrieve codes on a Ford OBD1 system:
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
There is a list of OBD1 codes with definitions at the end of the link.
Next, I would first check the sensor. Here are the directions. Pic 1 below shows the sensor location.
_________________________
1994 Ford Truck Ranger 2WD V6-182 3.0L
DA3 - Check Resistance of Temperature Sensor - Engine Off
Vehicle Powertrain Management Computers and Control Systems Testing and Inspection Pinpoint Tests With EEC IV (OBD I-A System) Pinpoint Tests DA - Intake Air and Engine Coolant Temperature Sensors DA3 - Check Resistance of Temperature Sensor - Engine Off
DA3 - CHECK RESISTANCE OF TEMPERATURE SENSOR - ENGINE OFF
- Key "OFF".
- Disconnect suspect temperature sensor.
- Measure resistance between sensor signal circuit and SIG RTN circuit at the temperature sensor. Refer to the corresponding chart for resistance specifications.
- Is resistance within specifications?
Yes -- For Engine Coolant Temperature (ECT) sensor with a No Start: Do not service Diagnostic Trouble Code (DTC) 116 at this time.
Go to pinpoint test step AA1. See: Computers and Control Systems > Pinpoint Tests > AA1 - Identify Type of No Start
No -- Replace suspect sensor. Reconnect vehicle harness. Rerun quick test. See: Computers and Control Systems > Reading and Clearing Diagnostic Trouble Codes > Quick Test Appendix (Detailed Testing Instructions)
__________________________________
If the sensor checks good and there are no codes, my next concern is the idea that coolant shoots from the radiator after about 45 seconds. That quickly leads me to believe it could be the result of pressure from the combustion chamber via a head gasket. Do a couple checks on this idea. Here is a link that explains how to check for a head gasket issue:
Let me know what you find or if you have other questions. Also, keep in mind that the reason I'm suspecting one of the two things above is simply because it happens at highway speeds and you have already done all the basics.
MICHAEL EMERY
  • 1993 FORD RANGER
  • 3.0L
  • V6
  • 600,000 MILES
Truck started running rough a few days back and now it starts to overheat. Then there is a gurgling sounds from passenger side behind the dash heater core maybe. Right after engine cools then it repeats over and over. Seems the truck is losing power as well. Mind you I don't know if the overheating came first or not as the wife had the truck when this all started.
  • 108,269 POSTS
Can you tell me if the coolant level is dropping? As you are most likely aware, there are different things which can cause the engine to overheat. Things such as low coolant, a stuck thermostat, even a bad head gasket.
With that in mind, I am going to provide a few different links which are designed to help identify different causes of overheating and how to check.
First, if the coolant is low, check the following:
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/car-is-leaking-coolant
https://www.2carpros.com/articles/coolant-leak-symptoms
Here is a link that shows how to check a cylinder head gasket for leaks:
___________________
If the coolant isn't low and you can find no evidence of leaks, my next suspect is a bad or stuck thermostat. The first link discusses a thermostat, it's general location, and how to check one.
https://www.2carpros.com/articles/how-an-engine-thermostat-works
Here is a link that shows in general how one is replaced:
Once you review the aforementioned links, let me know what you find so I can further help.
ANDREWAIKEN
  • 1993 FORD RANGER
  • 6 CYL
  • 4WD
  • 140,000 MILES
I have a 1993 Ford Ranger 4.0 automatic 4x4 140000 miles. The engine runs hot if I am not traveling at highway speeds. For instance going thru a drive thru or landing a boat, etc. About three years ago the radiator, fan clutch and thermostat were replaced. Still having the same problem. In the cooler months the temperature is normal no matter the speed.
Wednesday, October 28th, 2020 AT 2:18 PM (Merged)
CJ MEDEVAC
  • 11,004 POSTS
Been 3 years?
Things go bad
Even new stuff can be bad
Hoses s. Ucking flat?
Could be a head or head gasket issue. Sorta the last test to try.
Got a shroud around your fan?
Test your fan clutch (popular auto parts guys my check it for FREE!)
Are you mixing your coolant externally, then installing it, thus insuring it's the proper mix, throughout (topping off the same way, later on?). Or are you one of those "guessers" just pouring it in then filling with water till you hit the top?
Lesser of the Evils after the clutch test, would be the thermostat. Simple, EZ to do, less than $10
The Medic
ANDREWAIKEN
Yes I understand things go bad and new parts can be bad. After all the new parts were installed the repair shop could not fix the over heating problem. No flat hoses. Got the shroud. No I am not a guesser. Just had the radiator serviced and I use the pre diluted antifreeze.I will get the clutch fan tested.
CJ MEDEVAC
  • 11,004 POSTS
Roger, on all of that!
It's really been hot out!
My Jeeps don't over heat, but they are running hotter
Is yours "Hotter" or really pegging the gauge out?
At night, when cooler, how does it perform?
Could be the sender to the gauge, might be inaccurate.
Head Gasket test.A pressure test can be done.A chemical too!
Radiator Cap? It can be tested, or inexpensively replaced
Just trying to help you.I see something new (sometimes hilarious!) Everyday
Are you at the mercy of the wolves?
I may can help there too. If you are willing to broaden your horizons
I'm a Plumber. Learned a lot, bought tools, did not "drink away", my tight limited fundage! Jeeps are my primary transportation, and have been since '81. My hobby too, Mine do not go to a shop, 'cept for alignments. Had 7, still have 6 and 7.6 almost scratch built, 7 From nothingness!
I do it all myself.I find resources, and use 'em to my fullest extent, whether it be my Jeeps, Wife's Escape, Family or friends rigs.I'm called "McGyver" quite a bit.I sub out nothing, at my house. Not even the toaster!
My sole goal here is to help. Especially the CJ guys!
Your Turn
The Medic
