Car jerks and misfires?
SABELO
  • 2018 TOYOTA COROLLA
  • 1.6L
  • 54,000 MILES
Car starts perfectly but jerks and misfires for split second and switches off immediately after putting it in gear. It's a automatic transmission. I checked the oil levels it's fine. I have no idea where the problem may be. The car is listed above Quest model front wheel drive. Why does it misfire?
Monday, October 14th, 2019 AT 3:53 AM
We need to start with checking for codes however, I would make sure you have a dealer check this out because it may still be covered under warranty. If it is, there it would be ok to do some checking but if the dealer finds things out of place they may try to blame you for the issue. So you don't want to give them any reason to think that by digging to deep into it.
As for what it sounds like, it seems as if the torque converter is stuck so once you put it in gear, it stalls the unit. This is like putting a manual in gear and then letting off the clutch without accelerating and it just stalls the engine. While the torque converter operates differently than this, the idea is the same.
Here are two guides to help us fix it
and
https://www.2carpros.com/articles/stall-at-idle
Monday, October 14th, 2019 AT 4:35 PM
KENGARBRECHT
  • 2013 TOYOTA COROLLA
  • 109,000 MILES
Ive replaced spark plugs, and coil packs but my car is still reporting misfire in cylinder 3 and fuel ratio imbalace. Is there anything else to check?
Saturday, December 26th, 2020 AT 2:02 PM (Merged)
  • 108,310 POSTS
Can you provide the codes you are getting? Also, what engine size does the vehicle have? Is it a 1.8L or a 2.4L?
You could confirm fuel pump pressure is within spec. Here is a link that shows in general how it is done:
________________________________________
AHMEDBAGHDAD
  • 2010 TOYOTA COROLLA
  • 1.8L
  • 4 CYL
  • FWD
I have a problem that when I start my corolla there is hesitation in the beginning and when I press the pedal it will be fine. The obd result was p0302
HMAC300
  • 48,601 POSTS
I would start with a tune up using OEM parts to ensure quality. Here is a guide to help you after the job is done clear the codes.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
and to clear codes
https://youtu.be/ahK_eucFi-k
BOOPERIII
Thanks for this post I had this problem and the tune up fixed it, get video on how to clear codes BTW I Love this site.
WAYNE TERRY
  • 2009 TOYOTA COROLLA
  • 1.8L
  • 4 CYL
  • 211,789 MILES
Valves ping feels weak number one and number four cylinders not firing properly. Cannot seem to find out why cylinders are breaking. Replaced power packs and new iridium plugs still does it.
  • 31,937 POSTS
I would do a compression test first. check this link on how you can do it at home. Post your readings for further assistance.
KENTUCKYCOROLLA
  • 1.8L
  • 4 CYL
  • 195,000 MILES
Car started to miss badly and run poorly overall. Had car worked on by mechanic but to no avail. Have changed all four coil packs, new plugs, one new injector, gaskets all around, cleaned throttle body, checked for intake leaks, basically the whole nine yards and it still is misfiring. Before all the fixes, the car would not even hold idle without giving gas to engine. Could not come to a stop without shutting off. I have resorted to asking for other outside opinions since I have ran into a wall and do not want to keep throwing parts at it. It now holds a steady park idle at 1200-1300 RPM and once in gear holds at 800-900 RPM. This is much better than before but now after driving car for a bit, car will jerk and go into limp mode, limiting car to roughly 60 MPH. Need advice on what could possibly be wrong.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,057 POSTS
It sounds like you have a low compression issue but we should run the codes to see what comes up here is guide to get us started.
Cheers, Ken
KENTUCKYCOROLLA
The only codes that are present now are a cylinder four misfire. I cannot remember the exact number. But this is the code that originally was thrown. Compression test has been ran and seems to be fine.
KEN L
  • 43,057 POSTS
It sounds like it can be a camshaft issue does the engine sounds normal? I would remove the valve cover the make sure the valve springs and camshaft lobes are okay. Check all cylinders because then can affect #4.
This guide will get you started.
https://www.2carpros.com/articles/replace-valve-cover-gasket
OPERAKENNY
  • 2006 TOYOTA COROLLA
  • 1.8L
  • 4 CYL
  • 237 MILES
For sometime now, when ever I drive a long distance after a while when the engine is hot, the car will be jerking and it will be moving slowly, especially when I am in traffic hold, the car will jerk and go off on its own. I have change coil and bought two fuel pumps, but am still experiencing the same issue.
Please help.
KEN L
  • 43,057 POSTS
This sounds like you have an engine misfire issue. We should run the codes first have you installed new spark plugs?
and
https://www.2carpros.com/articles/how-to-change-spark-plugs
OPERAKENNY
After scanning the car, these are the code I got: P0010, P0012, P0328. Please what should I do?
KEN L
  • 43,057 POSTS
These are camshaft actuator errors which can be caused by dirty/low engine oil levels. can you check or change the oil? Here is a guide to help. Once complete please clear the codes and try it again.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
ZEESHAN
  • 2005 TOYOTA COROLLA
  • 6 CYL
  • FWD
  • MANUAL
  • 32,000 MILES
Dear sir
my car is very good in condition. But today its engine is race missing too much. Please help me
Saturday, December 26th, 2020 AT 2:04 PM (Merged)
MMPRINCE4000
  • 8,548 POSTS
If you are saying the engine idle is too high and engine is missing, it is most likely caused by a vacuum leak, this would be a big leak, like the intake manifold.
DKCOMM
  • 2004 TOYOTA COROLLA
  • 4 CYL
  • 95,000 MILES
If the engine is cold the car will idle okay until put in drive, then idle gets a little rough. Giving gas to drive off the car will choke out in a large burp like fashion. Engine does not shut off, it is like a total misfire or total half-second choke-out. This continues until engine is up to operating temperature. Never happens when driving highway speed fifty, sixty, seventy mph.
  • 108,310 POSTS
First I would like to know if there are any codes in the computer that may point us in the right direction. It sounds like there may be an issue with the coolant temperature sensor. If the engine thinks it already warm, the fuel mixture will be lean which can cause the issues you described.
