4L60E Issues
My Husbands 05 Chevy Silverado 1500’s Pulling 2 P0700 Codes (transmission Malfunction). It’s A 4l60e Transmission. He Put It In A Ditch...
Dumbcargirl122
New Off-road Bumper Options?
While Researching Off-road Bumper Options For My Truck Listed Above, I've Noticed That Quality And Extra Features Are Critical. Can I...
MartinLemons
TOYOTA TACOMA
Car Runs But Starts Sputtering Then Loses Acceleration...
Okay, So, The Car Starts And Runs Then The Dashboard Lights Came On Oil/engine/brake, And All The Rest, But Then The Airbag Light...
Booth324
How To Rebuild The 302 Engine?
I Have The Vehicle Listed Above With An 302 5.0 Engine. I Was Wondering About How To Rebuild It Or Stroking It, But Also, I Have A 351...
Davila94
How To Remove The Evaporator Valve?
I Need To Change The Evaporator Valve Do I Have To Remove The Dash If So, Where Can I Get Directions?
jellentz
CHRYSLER PACIFICA
Crank No Start Issue After Replacing The Starter, Oil...
I Replaced A Starter And Oil Level Sensor, And Did An Oil Change And Now It Won't Start Only Turns Over.
robert6121975
Adaptive Headlight Is Out On Right Passenger But...
My Adaptive Headlight Is Out On The Right Pass Side. My Headlight Got Hit And The Plastic Cracked, And It Hasn’t Worked Since. I Tried To...
trillandtryst
BMW X5
What Are The Torque Specs For Cylinder Head And The...
Need To Know Torque Specs For Cylinder Head And The Valve Lashing For All Valves, Please.
Jasonburms
MAZDA 5
Pop Noise, Possible Axle Issue?
I Had My Axle Replaced Because It Was Worn. My Axles Have Been Replaced But When I Put The Truck In Reverse While Engine Is Running No...
chris001
There Is A Part Of The Lower Intake That I Need To...
I Took Apart The Lower Intake On My Vehicle Listed Above And Cleaned It Up. I Went To Put It Back Together And Cannot Find This Part And...
Kyle351
There Is A Clicking Noise Coming From Beside The...
I Had It Tested, And They Said Everything Is Running Fine, But It Still Blows Hot Air. There Is A Clicking Noise Coming From Beside The...
bevyg1
HYUNDAI TUCSON
Code P2645
I Have A 2015 Impala Ltz 4 Cylinder And My Check Engine Light Came On Randomly Yesterday Morning And Then Went Off Yesterday Afternoon And...
Jsutt5
How To Replace The Front Passenger Seat Switch?
Please Show How To Replace The Front Passenger Seat Switch On The Vehicle Listed Above. Thanks
Talonluvswifi
INFINITI QX60
Please Show Me With Detailed Steps And Pictures How To Replace The Front Passenger Seat Switch. Thanks
Talonluvswifi
INFINITI QX60
Can I Get The Wiring Diagram For The Inside Drivers...
I Cut The Wires On The Headlight Assembly And Forgot To Write Down Where They All Came From And Where On The Plug They Go.
Lance214
Transmission Shift Issues?
The Car Listed Above Is A Coupe. The Car Will Take Off And Shift Up Through All The Gears However If You Come To A Stop Or Slow Down It Will...
Bob 55
No Start
My Car Cranks But Doesn't Start
Tyreej
Hesitation After Replacing The ICV And MAP Sensor...
I Replaced The Icv (idle Control Valve) And Map Sensor, And Now It Hesitates When I Drive, Lunges Forward, Before It Would Stall On Me...
js5878
Codes After Brake And Rotor Replacement?
I Had A Break Job With Pads And Rotors Done At A National Chain. As Soon As I Drove Away My Abs And Traction Control Lights Came On. The...
Mtrue
JEEP WRANGLER
The Passenger Side Caliper Locks And Will Not Release...
Hello, We Replaced The Flex Line To The Caliper, Installed A New Caliper Rotor And Pads, But The Problem Is Still There! I Later Found...
Cazznovah
CHEVROLET UPLANDER
Slow Acceleration?
Idle And Revs Up Fine In Park But Slow Acceleration For First 100 Ft Or So, Then At Times Most If Not All Power Is Restored When Reaching...
Razoray
Multiple Codes After Brake Job.
Had A Break Job With Pads And Rotors Done At A National Chain. As Soon As I Drove Away My Abs And Traction Control Lights Came On. The Brake...
Mtrue
JEEP WRANGLER
Engine Running Rough?
I Have The Truck Listed Above Silverado 2500hd With 6.0 Gap Engine. I Was Driving Home One-night The Next Day Woke Up Started My Truck And...
1rednck
Engine Running Rough, Code Po300?
1rednck
Wiring?
On The Front Actuator -what Do The 4 Wires (that Plug In ) Go To?
b1bern1
661
662
663
20260
