Codes C1632 And C3537?
2 Codes In The Car. C1632 And C3537.
kkellie88
DODGE JOURNEY
What Is The Best Coolant To Use?
Just Looking For What's The Best Coolant To Use In These 4.6 L.
Videogamer88
FORD THUNDERBIRD
Transmission Shift Issues?
When Driving The Car It Would Shift 1st 2nd And If You Are Passing A Car, It Would Stay And 8,000 Rpms And Not Shift And That Happen When I...
Ashes22
TOYOTA CAMRY SOLARA
Misfire On 2000 Ford Crown Victoria Lx
I Still Have A Misfire After Replacing Spark Plugs, Coil Packs, Fuel Injectors And Air Intake. Also New Maf, Egr Valve And Pressure/...
Richard Hough
FORD CROWN VICTORIA
Shuts Off While Driving?
I'll Be Driving Then The Car Will Stop Running. I Will Have To Wait A While For The Car To Start Again, It Always Happens When I Have...
Reuben Humphery Van Kempen
Reverse Lights On With Headlights, But Not In Reverse?
Earlier Last Year I Replaced The Stock Headlight And Taillight Assemblies With After Market Equipment As Well As Installing A Backup Camera...
Gareth Owings
DODGE MAGNUM
Stuck In Neutral
I Turned On My Car Put It Down To Drive And Accidentally Put It On The Last Gear Then Back To Drive And It Went Into Neutral. I Then Put It...
Gigglez420
No Start. Getting Fuel.
Cranks Will Not Start. No Spark. Where Is The Second Crank Sensor Going To The Icm. Getting Power To Module.
Tamara Bates
PONTIAC AZTEK
A/C Not Working Properly?
Hello, On A Hot Day Starting The Vehicle And Putting The A/c On Max It Does Not Blow Cold While The Vehicle Is Parked But Once I Start...
beetlepunk21
Crank No Start, Not Getting Fuel To The Fuel Rail?
About A Week And A Half Ago I Was Driving, And My Car Shut Off On Me While I Was Driving And Ever Since Then The Car Would Not Start. My...
2JZLexus
LEXUS IS 300
Someone Tried To Steal The Car And Broke The Ignition?
So, The Other Night Somebody Tried To Get In And Still My Car And Broke The Ignition Including Copper Wire That Connects To The Amplifier...
Dicksonred2
LEXUS ES 300
Driver Side Coolant Transmission Line
I Purchased A Doorman Driver Side Coolant Transmission Line Part Number 624-351. My Question Is Do I Need Doorman Line Connector Part Number...
Nibs5800
Issues With Driving Faster Than Five MPH, Transmission...
I Have The Car Listed Above, Its Having Problems Driving Faster Than 5 Mph, It Makes A Clunk When Putting It From Park To Rev And Sport...
Patyonemura80
4L60E Issues
My Husbands 05 Chevy Silverado 1500’s Pulling 2 P0700 Codes (transmission Malfunction). It’s A 4l60e Transmission. He Put It In A Ditch...
Dumbcargirl122
New Off-road Bumper Options?
While Researching Off-road Bumper Options For My Truck Listed Above, I've Noticed That Quality And Extra Features Are Critical. Can I...
MartinLemons
TOYOTA TACOMA
Car Runs But Starts Sputtering Then Loses Acceleration...
Okay, So, The Car Starts And Runs Then The Dashboard Lights Came On Oil/engine/brake, And All The Rest, But Then The Airbag Light...
Booth324
How To Rebuild The 302 Engine?
I Have The Vehicle Listed Above With An 302 5.0 Engine. I Was Wondering About How To Rebuild It Or Stroking It, But Also, I Have A 351...
Davila94
How To Remove The Evaporator Valve?
I Need To Change The Evaporator Valve Do I Have To Remove The Dash If So, Where Can I Get Directions?
jellentz
CHRYSLER PACIFICA
Crank No Start Issue After Replacing The Starter, Oil...
I Replaced A Starter And Oil Level Sensor, And Did An Oil Change And Now It Won't Start Only Turns Over.
robert6121975
Adaptive Headlight Is Out On Right Passenger But...
My Adaptive Headlight Is Out On The Right Pass Side. My Headlight Got Hit And The Plastic Cracked, And It Hasn’t Worked Since. I Tried To...
trillandtryst
BMW X5
What Are The Torque Specs For Cylinder Head And The...
Need To Know Torque Specs For Cylinder Head And The Valve Lashing For All Valves, Please.
Jasonburms
MAZDA 5
Pop Noise, Possible Axle Issue?
I Had My Axle Replaced Because It Was Worn. My Axles Have Been Replaced But When I Put The Truck In Reverse While Engine Is Running No...
chris001
There Is A Part Of The Lower Intake That I Need To...
I Took Apart The Lower Intake On My Vehicle Listed Above And Cleaned It Up. I Went To Put It Back Together And Cannot Find This Part And...
Kyle351
There Is A Clicking Noise Coming From Beside The...
I Had It Tested, And They Said Everything Is Running Fine, But It Still Blows Hot Air. There Is A Clicking Noise Coming From Beside The...
bevyg1
HYUNDAI TUCSON
Code P2645
I Have A 2015 Impala Ltz 4 Cylinder And My Check Engine Light Came On Randomly Yesterday Morning And Then Went Off Yesterday Afternoon And...
Jsutt5
660
661
662
20260
