Multiple Codes After Brake Job.
Had A Break Job With Pads And Rotors Done At A National Chain. As Soon As I Drove Away My Abs And Traction Control Lights Came On. The Brake...
Mtrue
JEEP WRANGLER
Engine Running Rough?
I Have The Truck Listed Above Silverado 2500hd With 6.0 Gap Engine. I Was Driving Home One-night The Next Day Woke Up Started My Truck And...
1rednck
Engine Running Rough, Code Po300?
1rednck
Wiring?
On The Front Actuator -what Do The 4 Wires (that Plug In ) Go To?
b1bern1
Ground And Battery Issue And Knock Noise?
The Truck Listed Above Is A C1500. I Had Some Electrical Problems, I Think. Hope They're Simple. I Was Having Grounding Issues And...
EMoneybags
Flywheel/Starter Replacement?
I Had To Replace My Clutch In My Vehicle. While Replacing The Clutch It Was Advised The Type Of Place To Flywheel. This Is Where My...
Mistertucci
KIA SOUL
99 Dodge Dakota Water Pump Issue
I Had A Bad Water Pump So I Bought A New One. I Installed It Using Gasket Maker And It Leaked And Over Heated. I Took It Off Clean Off All...
Roy1978p
Crankshaft Position Sensor Location?
Where Would My Crankshaft Position Sensor Be Located? I Am Trying To Replace It My Self But I Can’t Find Any Videos On Where It Would Be...
Bossupacura
ACURA ILX
Starting
I Start It And It Putters Out As Soon As Started, What Is The Problem Please Help
Capone9833
Codes P0430 And 61-11?
Someone Said I Need To Replace The Catalytic Converter. Looking For Your Suggestions.
cbiswas16
Black Smoke From Exhaust?
Infiniti Service Said A Dirty Engine Air Filter Could Be The Cause Of It Running Rich, So I Replaced It And Did An Engine Performance...
Infinitiandbeyond96
INFINITI QX60
Code U010, Crank No Start?
Okay, So This Problem All Started Because I Was Having Battery Issues. My Battery Kept Draining, So I Got It Tested, Came Out To Be Bad...
copqerhead
23 IMAGES
Code P0430 And 61-11
Engine Light Is On And Identified The Following Code P0430 And 61-11. What Should I Do Now? I Went To Repair Shop And They Said That...
cbiswas16
Inner Tie Rod Removal Issue?
I Removed My Left Control Arm And Released The Outer Tie Rod, But My Inner Tie Rod End Is Stuck, Now Matter How Tight Removal Tool Is It...
Gary J.c.godin
DODGE CALIBER
Vehicle Won't Start Despite It's Efforts
My Outlander Won't Turn Over. I Have Replaced The Crankshaft Position Sensor, I'm Aiming For The Camshaft Position Sensor (s) I Am...
Krystalw
MITSUBISHI OUTLANDER
Car Won’t Start But Lights Come On.
So The Valve Solenoids Were Replaced. All But The Park Solenoids Were Replaced. After Putting It Back Together The Car Won’t Turn Over....
Hscott9876
BMW 750LI
Master Cylinder Cap Opened?
Hi. How Long Does It Take For Air To Get Inside A Master Cylinder If The Seal Is Not Closed. Will Air Get Inside Even If The Hood Is Closed?
Joshedwardjohnson
2022
PEUGEOT 2008
Hi. How Long Does It Take For Air To Get Inside The Master Cylinder If The Seal Or Cap Is Not Closed?
Rahul Ramputty
2022
PEUGEOT 2008
Hi. How Long Does It Take For The Brake Master Cylinder To Get Air Inside If The Master Cylinder Is Not Sealed
Joshedwardjohnson
PEUGEOT 2008
Alternator White Wire?
Hi, I Had To Replace The Alternator. But The Connector Was Damaged So I Had To Replace It, I Sort Of Connect The Wires Except One That I...
Rasconu
SUZUKI XL7
White Wire
I Had To Replace The Alternator And The Wires Were Damaged So I Pull Them Out I Had To Buy A New Connector. I Sorta Connect Thecwires But I...
Rasconu
SUZUKI XL7
Reverse Light Stays On?
My Reverse Light Stays On But As Soon As I Put It In Reverse, The Light Goes Away. I Checked The Vehicle Back Up Fuse Is Good And As Soon...
Cris661
A/C Compressor Is Always On?
The A/c Compressor Will Start Running Whenever I Turn The A/c On. However, It Is Not Cycling On And Off. I Tried Removing The Low-...
Eyad Alherz
GMC SUBURBAN
Lower Intake Bolt Pattern
Cannot Find Bolt Pattern
jtrsmc
CHEVROLET TRACKER
Code PO871, Where Is The Transmission Fluid Pressure...
Engine Code Po871 Transmission Fluid Pressure Sensor/switch "c" Circuit Range/performance. Where Is The Location Of This Sensor...
ryurei4444
CHEVROLET SPARK
662
663
664
20260
