It Just And Cranks, Then Sounds Like Free Spooling?
Replaced The Front Crankshaft Seal. Started Up With Super High Idle So, I Turned It Off, Went To Turn Back On To Adjust And Cranks, Then...
Jamesp9557
Related Codes?
C1111-00 C1111-04 C111d-1c C1140-04 U1002-01 P059f Active Shutter Functions Properly. Completely Drivable. Brakes Function...
Rolo91
Code P0221, Throttle Position Code EPC Light And Check...
Hello. I Own The Vehicle Listed Above With A 2.0 Turbo. Unfortunately, I’ve Had Lots Of Mechanical And Electrical Problems With The Car....
Mrocha1
AUDI A3
Rear Brake Replacement?
I Recently Saw Your Video Titled "how To Replace Front Brake Pads And Rotors Ford Focus 2008-2011 - Easy!" And It Was Very...
ktheodoseau
Driver Side Window Clicks But Will Not Move
I’ve Tried New Parts Looked At The Fuses And Still Can’t Seem To Figure Out The Problem The Window Motor Is New Like Most The Windows...
des05
HONDA PILOT
Carjacked Y Pipe Leaking To Manifold And Catalytic...
The Y Pipe Leading To My Cat And Manifold Has Come Away From The Bracket, That Same Pipe Has Started To Crack. I Just Want To Replace That...
Steven A Wilson
Brake Torque Specs Needed?
I’m Going To Change The Brake Rotors And Pads On The Vehicle Listed Above. I Just Need All Of The Caliper Torque Specs Please. I Used To...
Ryan Lobb
LEXUS ES 300
PCV Replacement?
Hello, Install New Pcv, The New One Is A Little Bit Slack. Strange Because Seems The Same Product (see Attached). Regards
Yosef Levy
SUZUKI SWIFT
ECM Connector, How Do I Find Out Exactly What Each...
2 Pins On My Ecm Are Bad. How Do I Find Out Exactly What Each Wire Going To Connector Is For And Color. We Bought A New Connector And...
Shawnawayne
PONTIAC G6
Sensor
My Manifold Intake And Catalytic Converter And Sensor Are All Having Problems I Need To Know Which One Should I Get Fixed First
Osife45
NISSAN ARMADA
Parking Brake Lever Broken?
So, I Was Trying To Get Out Of My Car This Morning, And I Noticed It Rolled A Bit Forward Towards Another Persona Car. So, I Tried...
Rosellia
CADILLAC DEVILLE
Crank No Start? Just Got A Brand New Battery?
Got My Car In Match Driver It To Texas Like 3 Times And Back To Louisiana. I Got An Oil Change The Next Week After I Got It In March, No...
eishiakelley19
No Spark? I've Replaced The Crank Sensor
I've Replaced The Crank Sensor And The Complete Distributor From A Running Jeep And Coil. I Have Tried To Change Computer. Also, I Left...
Pmartin237166
Fuel
Takes Too Long To Start. Once Running Ok. Problem Only After Been Sitting For Couple Hrs. Fuel Pump Replaced About 3 Or 4 Yrs Ago. I Think...
Bob Miskelly
Car Running Hot?
Car Engine Coolant Over Temperature.
ezzarprice
FORD EDGE
Shaking While Braking From 45-55 MPH?
Hi, My Truck Shakes When I Brake From High Speeds. Specifically, 45-55 Mph But Less Violent Shakes At Other Speeds. It Doesn't...
Jacob Marino
Door Bushing Replacement?
I Have The Vehicle Listed Above Ls Model. I Took Off Driver Door And Third Door Off To Replace The Rocker Panel Now I Am Putting It Back...
Robert Zegers2
In Car Dash Fuse Box Diagram
I Need Fuse Box Diagram For Drivers Side Dash
Nash6160
ISUZU RODEO
Shut Off While Driving, Will Not Start, And There Is...
So, Coming Home From New Orleans My Car Stopped On The Side Of The Road Shut Off Completely And White Smoke Was Coming From The Passenger...
confusedmom92
JEEP COMPASS
Car Shut Off While Driving. Crank No Start
Car Shut Off While Driving. It Was Idling High From Time To Time. Now It Cranks But Won’t Start. Replaced Fuses Under Hood But When I Test...
Nash6160
ISUZU RODEO
Is It Possible To Remove The Rear Drum Brake And Close...
I Was Wondering If You Could Take Off The Drum Brakes On The Rear And Close Off The Brake Line To Where It Only Goes To The Front Brakes.
waynegameing
How To Reassemble Alternator
After Opening My Alternator To Clean Out The Debris And Grit, Of Which There Was A Lot, I Cannot Get The Brushes To Stay Recessed Enough...
Tsestak45
Alternator Reassemble
I Opened Up My Alternator To Clean Out All The Debris And Grit In It, Of Which There Was A Lot. I'm Now Having A Hard Time Keeping The...
Tsestak45
Too Much Oil
I Just Bought It A Month Ago And The Guy Said He Did An Oil Change But A Week Later, I Was Empty. Or So The Dipstick Read. I Added Two...
Judipeloquin
GMC ENVOY
Intermittently Issue Of The Car Shaking Back Forth...
Hi, My Car Rapidly Shakes Back And Forth, (ie, Judders/jerks), Every Now And Then, When Driving On The Highway. The Check Engine...
zar1
NISSAN VERSA
633
634
635
