The "Service Zone Detection System" Warning Light Is...
I Inherited This Vehicle One Month Ago. The "service Zone Detection System" Warning Light Is Lit On The Instrument Cluster. Mounted...
USPatriot1963
Stuck Personal Charging Gun Inside Charging Port
My Personal Charging Gun Is Currently Stuck Inside My Car's Charging Port, I Need To Know Where The Emergency Charging Gun Release...
Wolfgard556
HYUNDAI IONIQ ELECTRIC
Wolfgard556
Hi, My Personal Charging Gun Is Currently Stuck Inside The Car's Charging Port, I Need To Know Where The Emergency Charging Gun...
Wolfgard556
New Brake Pads Installed, When The Car Heats Up The...
I Just Had New Brake Pads Installed, And Now Only When The Car Heats Up, After A While The Pads Start Squealing When I Apply The Brakes....
Franky Silvia
Faulty Air Suspension?
Hello, I Have An Aftermarket Air Suspension Installed On My Toyota Hilux Truck. The Issue I Am Having Is When I Press The Button To Put Air...
TroyBone
TOYOTA TACOMA
I Believe All Of The Electronics Have Stayed On...
I Drove My Truck 62 Miles. Everything Was Working Fine. I Stopped At A Gas Station, Parked It And Turned It Off. I Was Then Heading Outside...
BigSarge95
The Wind Blows My Windshield Wiper Off The Track?
The Wind Blows My Windshield Wiper Off The Track And The Wipers Stop Moving. The Wiper Motor Is Still Working. Do I Replace The Wipers Or...
Tp21
Front Brake Groaning/squeak Noise When Braking At Very...
I Have Recently Started Hearing This Groaning Noise When Coming To A Stop And At Low Speeds (light Pressure On The Brake Pedal And At Speeds...
SurgeImpulse
Engine Cranks But Won't N Turn Over Suspect Bad...
Battery Is A New 650 Cca Charged At 12.6 Was Starting Up Last Week With No Issues But Now Won't Turn Over, Drops Down To 12.4, Black...
siennawise
Electrical Components On The Left Side Of The Car Do...
Hello And Thank You In Advance To Whoever Takes The Time To Help Me Out. I Have The Vehicle Listed Above Coupe Sport (non-cabriolet)....
Rob Eivin
MERCEDES BENZ CLK320
Cylinder 3 Or 2 Misfire?
Cylinder 3 Misfiring, So Switched Out Spark Plugs, Coil Pack, And Ignition Cylinder With New Working Parts. Cylinder 3 Is Now Good, But...
Awalker121212
Serpentine Belt Diagram Needed?
Long Story Short- My Head Gasket Blew, And My Retired Mechanic Father Wanted To Help With The Repair. Everything Went Great Until Time To...
rockernurse
DODGE JOURNEY
Car Stopped While Driving
I Was Going 55 Mph And The Car Stopped Accelerating And When I Pulled Over And Cut The Car Off And Tried To Restart It Won’t Start Please...
Aumond Ware
Replacing Coolant Sensor?
I Took My Truck To Get The Coolant Gauge Fix Because It’s Been Two Months Driving It With It Not Reading. Therefore, They Fixed It They...
Jessica24tovar
RAM 1500
Where Is The Fuel Pump Relay Located?
I Can’t Figure Out Where The Location For The Fuel Pump Relay Is.
33Frank33
MAZDA PROTEGE
I Have A Low Coolant Light On My Dashboard?
I Have Replaced The Antifreeze Reservoir. I Have A Low Coolant Light On My Dashboard. Could It Be The Ac Pressure Switch? I Have Put Some...
Tim Heaton
CHEVROLET VENTURE
Cost Estimate For Sway Bar Bushings - Rear Links And...
Hi, I Would Like To Know About What I Should Expect To Pay At An Independent Repair Shop In Order To Compare With My Inflated Dealership...
Keg90
SUBARU WRX
Replace Defective Hydraulic Cooling Fan With Electric...
Factory Replacement Hydraulic Fan Costs $750.00 From Japan. Not Worth That. I See Electric Fan Kits On The Internet. I'm A Reasonably...
James.b.potter
LEXUS ES 300
Parking Brake Warning Lights Comes On When I Drive?
Hi, Whenever I Start The Car And Drive It, The Display Shows "release Parking Brake" And It Beeps Even Parking Brake Is Not On...
arshnew487
MERCEDES BENZ C180
Engine Not Cranking?
I Replaced The Fuel Pump Because It Wasn't Firing, Well Now That I Have Do E That My Car Still Won't Crank I Was Thinking Sensor...
Lillieduncan
TOYOTA AVALON
Soft Brake Pedal And I Tried Multiple Times As I Press...
I Have Changed Brake Pads And Disc At Rear Passenger Side. During The Change Piston Was Not Push Back So I Press The Brake Few Time Piston...
Usman89
HONDA JAZZ
Hybrid High Voltage Battery Will Not Charge Above...
My Battery Won’t Charge Above Halfway. Is There Any Way I Could Fix Or Alleviate The Issue Without Replacing The Battery? And What...
Leopn262
LINCOLN MKZ HYBRID
Power Steering
Replace Power Steering Pressure Line On 2009 Sl63 Mag
Clarence buckle
MERCEDES BENZ SL63
Left Side Parking Lights And Corner Light Does Not...
Front/rear Left Side Parking Lights And Front Left Corner Lights Don't Work. All Fuses Tested. Swapped Fuses 33 And 37 (left And Right-...
jglow
BMW Z3
629
630
631
