Crank No Start
The Car Was Working Perfectly The Day Prior, Then One Day It Started, And Then Shortly After, It Died. It Started Up Three Times And Died...
chungobungo
TOYOTA CELICA
One Day It Started, And Then Shortly After, It Shut...
The Car Was Working Perfectly The Day Prior, Then One Day It Started, And Then Shortly After, It Shut Off. It Started Up Three Times And...
chungobungo
TOYOTA CELICA
HVAC Blender Issues
Hello, My 2014 Ram 2500 Is Blowing Hot On Drivers Side And Cool And Passenger. It's Not A Dual Climate Control So I Believe It Only Has...
Aforww
RAM 2500
Torque Spec For Clutch?
Can You Please Find Out What The Torque Is For The Pressure Plate To The Flywheel? I Also Noticed That The Flywheel Is Like A 2 Piece, The...
MAZDA 6
Code P305, Misfire On Restart?
Car Misfires When Restarted Only Never In Morning When First Driven. I Can Drive For An Hour It Doesn't Happen Only On Restart And Doesn...
Ryan M.
Alternator Not Charging?
I've Looked Over The Comments And Replies To This Subject. I've Checked Both Fuses And Fusible Link As Well As Batt Indicator Bulb...
Matthew Autrey
NISSAN TRUCK
Fuse #32 Keeps Blowing?
This One Is A Doozy… 40,000on New Engine. Drove To Work In The Morning Fine. Started Vehicle In The Hot Afternoon And The Overdrive...
beetlepunk21
16 IMAGES
Car Stereo Constant Voltage Wire?
Dears, I Put An Amplifier In The Trunk, And Connected It With The Original Radio Constant + Wire (orange, Black) Because It Was Free (the...
wish30
FORD COUGAR
Ran Transmission Dry Briefly, Still Works But Fifth...
Ran Transmission Dry Briefly. Still Works But 5th Gear Is Now Singing. Want To Replace Damaged Internal Parts. What Do You Believe Is...
vincennes44
HONDA ELEMENT
What Will I Do When I Have Transmission Friction...
I Have Transmission Friction Element A Stuck On. Continuous Memory Dtc.
JC01
FORD ECOSPORT
DTC Status
What Will I Do When I Have Transmission Friction Element A Stuck On Dtc Status. Continuous Memory Dtc
JC01
FORD ECOSPORT
Codes U0072, P0606, And U0101, Throttle Suddenly...
The Vehicle Moves Fine, And It Will Suddenly Seize The Throttle And The Rpms Will Be Between 1,000 And 2,000 And Display At On The...
Hudumasaud
Crank, No Start, Also No Bus On Odometer?
I Have Good +5.2 Volts On Both Of The Sensor Supplies From The Pcm, - I Have Disconnected Tps, Isc, Cam, Crank, Transmission, Some...
oldsc400
DODGE DURANGO
Replaced Heater Core
I Have Replaced Heatercore And All Parts Put Back And Connected. Tried To Start And Dash Lights Up And Cycles But Not Start Noticed Pats...
DA.Butler
Code P0717, Lost Speed Signal To Input Speed Sensor?
The Truck Listed Above Is A 6500 Hd, Brand New. Randomly Threw This Code And Won't Shift Out Of First Gear. I Was Looking For A Tcm...
Ngran
16 IMAGES
2022
Engine Cranks But Will Not Start, Suspect Bad Wiring?
1997 Motorhome With 454 Vortec, Battery Is A New 650 Cca Charged At 12.6 Was Starting Up Last Week With No Issues But Now Won't Turn...
siennawise
Backfiring And Sputtering?
My Car Listed Above Is Making A Popping Sound When I Accelerate, And It Is Sputtering And Barely Goes But When It's In Park Or Neutral...
Chevy5.7
CHEVROLET CAPRICE
Stuck In 4 Low?
The Other Day When I Started Up My Vehicle And Began Driving Something Totally Fell Off On My Vehicle. I Then Realized That The 4 Low Light...
Dodgeman637
DODGE DURANGO
Looking For The Air Conditioner Relay
Air Conditioner Has Power And Appropriate Levels Of Freon But The Compressor Won't Engage
John rush
VOLKSWAGEN JETTA
ENGINE OIL TYPE
What Is Recommended?
SUBARU OUTBACK
Black Smoke Coming Out Of Exhaust Less Power Not...
Black Smoke.
MonsterMunch3991
AUDI A3
What Could Be Causing My Car To Not Be Able To Start?
The Engine Was Just Replaced Last Year. It Started Just Fine This Morning And Then About 30 Minutes Later Nothing. My Car Won't Start. I...
emilyrose8599
CHEVROLET CAPTIVA
Idles High When Transmission Is In Neutral And In Park...
Hi, I Have Replaced The Egr Valve, Iac, And The Tps. It Has New Plugs And Wires And It Still Has The Same Issue.
Steffy831
BUICK SKYLARK
What Could My Problem Be
Just When You Put Water Into The Radiator Reservoir It Goes Straight To The Oil Pan
Ginnycollins11
While Driving The A/C Suddenly Stopped Blowing Cold...
I Was Driving And My Air Just Suddenly Stopped Blowing Cold. We Checked The Refrigerant And It's Charged. Fans Are Blowing But...
Antoinette Cunningham
NISSAN ROGUE
628
629
630
