Left Side Parking Lights And Corner Light Does Not...
Front/rear Left Side Parking Lights And Front Left Corner Lights Don't Work. All Fuses Tested. Swapped Fuses 33 And 37 (left And Right-...
jglow
BMW Z3
Troubleshooting Codes P0497?
Hello 2 Days Ago, My Car's Check Engine Light Came Up. I Went To Autozone And Got My Car Scanned. The Code That Came Up Was P0497...
solracotos
A/C Condenser Replacement?
I Want To Know If A Specific A/c Condenser Will Work With My Vehicle Listed Above Sport Model. If Not, Which One I Can Use?
StevensNissan
NISSAN ROGUE
How To Reinstall The Wiring Harness?
I'm Needing To Know How To Reinstall The Wiring Harness To My Engine. Help!
DrWeeksJr76
CHEVROLET CHEYENNE
Where Is The Crank Sensor Located?
Engine Turns, No Spark, No Fuel. Just Replaced Plugs, Wires, Cap, Rotor, And Coil.
Silversac
CHEVROLET CHEYENNE
Key Will Not Disengage Consistently?
I Have The Vehicle Listed Above, Xe, And The Key Won’t Disengage. The Car Is In Park, But The Key Won’t Come Out. I Have Concluded...
SaturnAssist
SATURN VUE
Key Won’t Disengage
I Have A 2009 Saturn, Vue, Xe And The Key Won’t Disengage. The Car Is In Park, But The Key Won’t Come Out. I Have Concluded Where The...
SaturnAssist
SATURN VUE
Need To Replace Spindles, Can I Replace 30 Spline From...
I Brought The Truck To Mechanic Shop And Was Told The Bearings Needed Greased And The Threads Were Crossed On The Spindles, And They Said...
Dodgeman637
Keeps Blowing The Ignition Fuses, Why?
I I Have The Vehicle Listed Above 3500 Cutaway Van. The Ignition Fuses Keep Blowing Can Off Powertrain Transmission. Module Fuse Blows Once...
Truly87
CHEVROLET EXPRESS
Electronic Issues After Brother-in-law Used My Car To...
Car Radio Sometimes Turns Off While Driving. Car Radio Will Also Sometimes Turn Itself On When Car Is Off, And Keys Are Not Anywhere Near...
Nate Ruebens
FORD FLEX
Serpentine Belt Diagram Needed?
I Need The Diagram For The Car Listed Above, Police Package.
Bambition Osiris
Code U0129?
Randomly Started My Car Lights Start To Appear On The Dash. The Engine Light Comes On, Power Steering Goes Tough But Turns Off By Itself....
Zainrtm1
TOYOTA YARIS
Air Conditioner Not Blowing
The Air Conditioner Only Blows Out On The Defrost And On Your Feet Why Is That What Is Broken
Brad3998
Radio And Center Locking Not Working?
Ignition On Center Locking Works Radio Doesn't. Key Off Center Locking Doesn't Work.
Hndray
JEEP LIBERTY
When Turning Left It Is Making A Grinding Sound?
I Have Replaced Both Idler Arms, Drag Link, Both Inner And Outer Tie Rods, But Only On The Driver Side For The Tie Rod Replacement. The...
OmieTheHomie
CHEVROLET ASTRO
Engine Shuts Off While Driving, Will Start Again After...
I Was Driving My Truck One Afternoon And, At A Relatively Slow Speed, The Truck Shut Off. No Sputtering Or Anything, Just Shut Off. When...
hoff139
4wd Not Working?
I Have Had No 4wd In My Truck For Quite Some Time Now. The Service 4wd Light Is On. I Have Replaced Just About Every 4wd Component I Could...
Dodgeman637
RAM 1500
4wd Not Working
My Service 4wd Light Is On And I Can't Get My Truck To Go Into 4wd. The Light On The Switch Located On The Dash Doesn't Even Light...
Dodgeman637
RAM 1500
Liftgate Will Not Open, Is There Any Way To Open The...
When Any Of The 3 Ways To Activate The Liftgate Is Pressed: 1. Overhead Button. 2. Key Fob. 3. Latch On The Lower Outside Of Liftgate...
Ted Raab
CHRYSLER PACIFICA
A/C Stuck On Defrost?
Hello, My Truck's Vents Are Stuck On Defrost. I Have Found The Blend Door For The Temperature Changes, But It Works Fine. I Think I...
price1107
CHEVROLET COLORADO
Pmc Locations
Hi My Car Get Flooded One Month Ago Here In Florida Cuz The Rain And Storms That Pass By In April, The Anti Theft Get Ativated And A Lock...
Carlosa00123
A/C Only Blows Cold While Driving?
The Air Conditioner Only Blows Cold When Moving Anytime Stopped It Gets Hot Almost Immediately, I Have Checked The Freon It's In A Good...
jcraven7849
CHRYSLER TOWN AND COUNTRY
Still Grey Smoke , Couple Of Possible Issues, And...
So, I Noticed A Wire Hanging From Underneath The Cowl Plugged Into The Air Box Headed Into Throttle Body, Helped A Little With The Grey...
Michael Holodinski
Conditioning Fan
- Hi, Air Conditioning Fan. High Speed Doesn't Work
Mashary
Wipers Turn On With Headlight Switch?
Hi, I'm Thinking There's A Short In The Multi-function Switch Because A Week Ago The Wipers Started Turning On And The Two Turn...
88Muxowner
630
631
632
