When The Transmission Is Shifted Into Reverse The...
The Vehicle Just Stopped, So Towed It Home, Replaced The Distributor. Started And Then When You Put It In Reverse It Turns Off.
Mochiefa75
Clunking Sound From Underneath?
Clunking Sound From Underneath Driver Side And I Have Replaced The Cv Axles And The Struts Were Done Just The Front. What Is The Issue? I...
Joshua Perdomo
After Replacing The Valve Cover Gasket, The Engine...
So, I Got This Vehicle And At The Time It Was Starting And Driving. Replaced The Valve Cover Gasket And It Stopped Starting. Replaced The...
Jimmyjay31
SUZUKI FORENZA
Replacing The A/C Compressor, Condenser And Expansion...
Hi, I Am Going To Do Maintenance For The A/c System In My Car. The A/c Compressor Is Not Working. So, I Need To Replace The A/c Compressor...
Mahmoud_Abido
No Electrical Power? Tried Charging Battery?
I Left The Cabin Light On Overnight And Didn’t Drive The Car For Another Day After That. The Car Was Completely Dead When I Went To Start...
Marky1971
HONDA FIT HYBRID
Car Starts Then Immediately Stops?
It's Been Driving Absolutely Fine, But Today As I Started It, It Began To Rev Up And Down. I Turned The Engine Off And Plugged In My...
Kebirdie
BMW X3
Will Not Pass Inspection After Battery Was Replaced?
I Have The Vehicle Listed Above Is A 2014. The Battery Was Replaced A Little While Back. I Am Retired, And Don't Drive Much (just...
Anne Myres
Starter
Okay I Have Been Changing Out The Starter On My Kia Sedona I Stay Changing Because I've Been Doing The Six Times And Every Time The New...
Patrick Greene2
KIA SEDONA
Low Air Flow Through Vents?
Low Air Flow Through Vents And You Can Barely Feel It.
Rock58cs
Power Steering, Abs, Traction Control, Tire Pressure...
Had A Broken Wheel Speed Sensor, Which Led To A Number Of Issues Including Almost All Lights Coming On. Replaced It And Cleared The Codes....
charlielovin
VOLKSWAGEN JETTA GLI
Intermittent Warning Lights And Electronic Systems...
When Stationary, Everything Functions As Intended. Power Steering Works, And No Other Lights Are On. In Car Setup, Everything Functions...
charlielovin
Engine Bogging?
I Have The Car Listed Above That I Run In A Crown Vic Series. I'm Having Engine Issues. When I Hit The Gas At Full Acceleration My Car...
brandorob0387
MERCURY GRAND MARQUIS
No Spark To The Coils And No Start?
I Was Fixing My Truck With A New A/c Compressor And The Truck Started Just Fine Before I Changed It And Now That I Put The New A/c...
Pilas1982
Key Fob Programming Not Working?
I Purchase This Car Without Any Key Fobs. I Purchased Two New Fobs And Plugged In A Diagnostic Tool And Is Unable To Program The Remotes. It...
Ronald DeVold
Cranks But Will Not Start?
I Replaced My Broken Ground Wire, Fuel Pump, Fuel Rail, Tried A New Computer And My Car Will Not Start. It Will Start On Starting Fluid...
540Donuts
NISSAN MAXIMA
Help Im Having To Slowly Accelerate My Truck Or It...
My Truck Just Started Bogging Down A Whole Bunch When I Accelerate Too Quickly. My Truck Actually Died On Me While Driving On A Ramp To Get...
Amanda Smith4
Factory Radio Wiring Harness Cut, Wiring Diagram...
How Can I Tell Which Color Wire Means What And Connects To What Wires On My Afternoon Stereo?
Adrian N Carlos
RPM Surges High While Driving Highway Speeds, Corrects...
2010 Buick Lacrosse Awd My Car Rpms Will Suddenly Surge Very High While Driving Highway Speeeds, No Warning Lights Are On, No...
ldwiltsey
BUICK LA CROSSE
Wiring Diagram To CAN Bus Needed?
My Vehicle Is Having Problems And Codes I Get Are Usually Related To Wires Contained Under The High-speed Can (hs Can). Can Someone Help Me...
Hudumasaud
29 IMAGES
Sometimes My Transmission Will Not Shift And Take Off?
Sometimes My Transmission Won't Change And Take Off And If You Turn It Off And Turn It Back On While You Going You Never Change And...
John Allard
FORD E-SERIES VAN
Engine Will Not Start
My Car Key Will Not Go In The Ignition And It Is Stuck On Acc Mode
hopeadkins
My Key Will Not Go In The Ignition, And It Is Stuck In...
My Key Will Not Go In My Ignition And It Is Stuck In The Acc Mode.
hopeadkins
I Have A Code Showing For Cylinder 5 Misfire?
For The Misfire. I Have A Code Showing For Cylinder 5 Misfire. Changed The Plugs And I Changed The Number Coil Pack And Still Having Misfire...
PMARTIN6
24 IMAGES
Code U0 101, Does Not Start?
Does Not Crank Shows Code U0 101.
bowers99
Overheating?
The Truck Listed Above Continues To Overheat Even After Replacing The Thermostat Housing And The Water Pump. No Coolant Leaks That Appear...
MatthewJon
NISSAN TITAN
625
626
627
