The Fuel Gauge Is Not Working After Replacing The Fuel...
Changed Fuel Pump And Steering Column And Now Fuel Gauge Not Working.
Angi Allard
Wheel Bearing, Rotor Grinding Scraping Noise?
Yes, I Changed My Wheel Bearing First. It Was Fine Until Driving It About 30 Miles. Then It Started Making Noise. I Got Another Wheel...
susanreneea
KIA RIO
Clutch Problems??
I Have A 2004 Dodge Neon Sxt With A 5 Speed Manual Transmission. I Took A Road Trip Recently And Found Out That My Vehicle Will Not Move No...
Sergio100slam
Clutch Problem?
I Have The Car Listed Above Sxt Fwd 5 Speed Manual Transmission. I Took A Road Trip And Now All Of A Sudden, The Vehicle Doesn’t Move At...
Sergio100slam
Codes P0106 And P0109, MAP Sensor?
I've Been Told The Map Sensor Is Either Tied Into The Egr Valve Or The Fuel Pressure Regulator. I Have A Slightly Erratic Idle, Poor...
Profanon
FORD CROWN VICTORIA
HVAC Not Working Properly?
I Have 2 Hvac Issues. 1- I Charged The A/c Yesterday And The Air Still Isn't Very Cold Like It Should Be. 2- The Air Flow Doesn...
Jmay629
No Crank?
It Will Not Crank. New Starter, New Starter Relay, 12.6 Volts In Battery. 12.5 Volts At Starter.
Tinman66
1976
DODGE VAN
No Crank No Start Issue?
It's My Brother In-law Truck And The Problem Was Intermittent At First But Now It Does Nothing, He's Already Thrown A Bunch Of...
Jr47
Code U0101, Check Engine Light On?
Hey, I Drive The Vehicle Listed Above, I Have A Check Engine Light, When Diagnosed It Shows The U0101 Code. Occasionally The...
darvikkunalbanda
2010 Hyundai Sonata U0101 Code
Heyy, I Own A 2010 Hyundai Sonata, And The Check Engine Light Has Come Up And, When Diagnosed, Shows Up The U0101 Code. But The Car...
darvikkunalbanda
Shut Off While Driving On The Freeway?
I Noticed Rpm Needle Was Jumping Around. Coasted Off The Freeway, Check Engine Light Came On When I Tried To Start Again. Wouldn’t Start...
Sbixler
Rear Taill Ight
I Tried To Use An Improper Bulb, Didn't Work. Put Original Bulb Back In Now Have No Right Rear Tail Light, Turn Signal Or Brake Light...
Hemipoet69
DODGE AVENGER
Right Rear Taillight And Brake Light Do Not Work?
Right Rear Taillight, Turn Signal And Brake Light Don't Work. I Went To Put In A Blinking Brake Light Which Was The Wrong Bulb And Went...
Hemipoet69
DODGE AVENGER
Connecting Rode Bairngs
What Is The Twerk And The Specs On The Lifer? And The Bottom Bolts Of Engine?
Jozza ray
TOYOTA MATRIX
The CD (6 Discs) Stopped Working?
The Unit Turns On, The Volume Dials Show Increase When Applied But There Is No Sound. What Could Be Causing This? It Is A 4-speaker System...
BOB%
CHEVROLET HHR
On Board Diagnostic, How Long It Will Take To Drive It...
I Just Purchased This Van And To Transfer The Title I Need To Pass The Emissions Test. I Took It In And I Was Told That It Reads "not...
Tamara_M
Stiff Brake Pedal?
Changed Front Brake Pads After Hearing Scraping Sound. After Getting New Pads Installed, I Got A Friend To Assist In Bleeding Brake Lines....
bigmax
17 IMAGES
CHEVROLET COLORADO
Drl
No High Or Low Beam. Rining Lights Do Not Come On.
WW1949
A/C Gauges Are Reading Retard On Low Side And 250 On...
A/c Is Blowing Cold, But Gauges Are Reading Retard On Low Side And 250 On High Side. Also, The Compressor Isn’t Cycling.
Cwilson25
What Are The Torque Specs For The Clutch Pressure...
Torque Spec For Clutch Needed.
MAZDA 6
Fuel Reset
When I Hit A Bump The Car Shuts Down After Waiting For Sometimes Approx 30 Min It Will Start What's Up Thank U
Randy spears
PLYMOUTH ACCLAIM
Shut Off Engine It Backpressure Fills The Expansion...
It's A Vulcan Engine U In Vin. New Water Pump, New Thermostat, 185 Temperature. The Fans Work, Hoses Good, No Cylinder Miss....
Faith Hancock
A/C Drain Hose Leaking?
A/c Drain Hose Leaking Water And Won't Stop. Passenger Side Floor Is Not Wet.
David1961
2022
Rubbing Sound In Front End?
Rubbing Sound Hear From Front End When Drive Almost 15 To 20 Km.
Gayanm
NISSAN SUNNY
The Fuel Pump Is Not Pumping?
Fuel Pump Isn't Pumping And It's New Also The Relay Is New.
EllisJ
CADILLAC FLEETWOOD
626
627
628
