There Is A Whining/screeching Noise When I Shift The...
Hello, When I Get It Past 5 Or 10 Mph It Goes Away But Comes Back At A Stop. The Sound Is Compared To A Belt Slipping I Would Say, But...
Zimbo
Codes P2111 And P2104?
I Was Data Logging My Truck And The Failsafe Mode Came On And Went To Idle Mode. I Got Home And Looked These Codes Up. I Changed The...
Jamie Smithey
How To Replace The Timing Belt?
I Was Changing The Water Pump And I Think I Messed Up On Putting The Timing Belt Back On Because Now The Car Won't Start, It Just Makes...
Polk
SUBARU SVX
A/C Compressor Stopped Working?
Mechanic Friend Checked Pressure, Which It Still Has (fyi, It Tastes And Smells Gross!). Not Sure If The Relay Is Not Working Or If There...
RenaV
TOYOTA SIENNA
Where Is The TPMS Module Located?
I Was Told My Tpms Module Is Broken. I Was Going To Change It Myself, But I Cannot Find It. It Wasn’t Behind My Glove Box Or In The Hatch...
jimtug
TOYOTA PRIUS
Code Issues After Transmission Replacement? The P1603...
Hi. My Transmission Stopped Working So I Purchased A Second Hand One. My Neighbor Installed It And Is Coming Up With Faults Drive Slow And...
Mattnz
MITSUBISHI OUTLANDER
Will Not Go Over 60 MPH And It Will Not Shift Gears...
Won’t Go Over 60mph And Transmission Won’t Shift Gears Past 2nd.
rmahon315
Water Pump
If The Water Pump Bearings Are Bad Does The Entire Water Pump Need To Be Replaced Or Just The Bearings?
Mcal012
BUICK ENCORE
Do I Need To Replace The Entire Water Pump If The...
Water Pump.
Mcal012
BUICK ENCORE
No Crank No Start
Will Not Crank No Power Going Out Of The Ignition Switch Except For When I Hit Start But Nothing Happens All The Fuses Are Good All The...
Joe Weigel
Exhaust
Can I Fit A 90s. Model Exhaust Onto My 2001 Model
Tubau123
MITSUBISHI PAJERO
Is It Safe To Change The Receiver Line Myself Or Do I...
Hello, So A Metal Tube Thing Broke And I Didn't Know The Name Of The Part Or The Name Of The Part It Was Connected To. After A Lot Of...
Avid Learner
Water Pump Replacement?
Leaking Water Pump.
Jeffrey Morris
24 IMAGES
After Replacing The Alernator And Battery There Is No...
I've Replaced The Alternator And Battery. All Wiring Seems Fine, But I Only Have Power When I Jump Start It. When I Do It Runs Fine But...
Grizz82
Why Will My Car Not Accelerate While Driving?
My Car Is Currently Broken. I Was Going Around A Roundabout When I Braked, My Car Slowed To 40 Mph. I Tried To Accelerate But My Car Wouldn...
Adorn
VOLKSWAGEN PASSAT
The Truck Started Not Wanting To Crank Over All The...
The Truck Started Not Wanting To Crank Over All The Time. Battery, Cables And Harness Have Been Replaced. Chevrolet Dealer Says Alternator...
jsta
Car Turns Off When The Brake Pedal Is Pressed?
The Car Is Running Okay, Then When I Press On The Brakes Or Turn On The Lights, The Radio Or A/c The Car's Engine Just Shuts Off. No...
Harry H
TOYOTA TERCEL
Replaced Fuel Pump And The Car Still Does Not Start?
The Check Engine Light Is On Two Same Codes Camshaft Position Sensor A Circuit Low Bank 1 Or Sensor. Already Replaced Crankshaft And...
azdanno04
Vehicle Doesn’t Start From One Day To The Next
My 05 X5 Bmw Suddenly Stopped Functioning. Drove It That Morning And Then By Afternoon Was Going To Pick Up Kiddos From School And My Car...
RG72
BMW X5
Passenger Side Vents Not Blowing Air According To Mode...
My Passenger Fan I Noticed Is Blowing Air On The Floor But Even When I Change The Mode To Blow Air In Front Vents It's Still Blowing Air...
Acuramarco
ACURA TL
Coolent Leaking On Floor Drivers Side
I Just Noticed This Morning There Is Coolent Leaking Onto The Drivers Side Floor And After Further Inspection I Noticed It Leaking From...
Matthew Cecil
FORD FALCON
Can Someone Tell Me What This Car Part Is Called?
A Piece Of Metal Pipe That Was Connected To Something That Looked Like A Mini Gas Water Heater Broke Off. The Thing That Looks Like A Mini...
Avid Learner
Dash And Taillights Not Working?
The Dash Lights Won't Come On And The Blinkers And Hazards Won't Work. I Have Check Fuses Relays And Grounds, But I Cannot Find...
Jhale
When The Transmission Is Shifted Into Reverse The...
The Vehicle Just Stopped, So Towed It Home, Replaced The Distributor. Started And Then When You Put It In Reverse It Turns Off.
Mochiefa75
Clunking Sound From Underneath?
Clunking Sound From Underneath Driver Side And I Have Replaced The Cv Axles And The Struts Were Done Just The Front. What Is The Issue? I...
Joshua Perdomo
624
625
626
