Stuck In Reverse?
On The Way Home Last Night During A Thunderstorm, I Hit Some High Water. Two Miles Later, We Got To The Apartment Complex Where I Was Able...
BlackCloud22
CHEVROLET AVALANCHE
Can You Siphon Transmission Fluid And Replace It With...
I Can't Afford A Full Change But It's Brown. So Can I Siphon A Few Qts And Replace It With No Problems Until Incandescent Change It...
Robert Clark2
Confused On Changing Rims To Plus + From OEM Size?
So, L Just Bought My First Car Listed Above Gx. I'm Very Excited About Learning About The Car, Especially It Being Manual. I Have Some...
iszzieanna
Code P2004, Check Engine Light On?
Initial Problem, When Driving At A Certain Point, I Want To Have More Speed So I Put The Pedal To The Floor, The Rpm Will Go Up, But The...
denish58
Startup Warning Lights Not Turning On?
Unexplainable Today In The Morning My Warning/ Information Red, Yellow, Blue Lights Worked Fine. Now When I Turn The Key On, I Get Zero...
Jodicole1970
Engine Losing Power At 3/4 Throttle?
Supercharged 3.8 Cu. Runs Good Most Of The Time. When I Give It A Good Amount Of Throttle, Not Wot, Sometimes It Bucks Hard While Losing...
98gtp
A/C Blows Hot Air?
A/c Was Working Fine Then The Next Morning It Was Not. I Checked The Refrigerant, It Is Full, The Compressor Is Turning Fine But It Just...
Avilla48
After Changing The Oil, Oil Filter, And The Air Filter...
I Just Changed My Oil And Oil Filter, Also The Air Filter On My Car. Well, It Starts And Shifts Into Gear But Won't Move In Drive, It...
Chrisscotto
After Changing The Oil, Oil Filter And The Air Filter...
Chrisscotto
2021 Hyundai Kona Question
I Was Driving My Car It Started But Then My Radio Went Black And Would Not Turn On I Turned Off Car And Tried To Turn Back On Once Parked...
Smcdonald
HYUNDAI KONA
Why Does My Car Not Start?
I Was Driving My Car It Started But Then My Radio Was Black And Would Not Turn On. I Turned Off The Car Once Parked, And The Car Would Not...
Smcdonald
HYUNDAI KONA
Codes P0740 And P078a, Transmission?
The Problems I've Had With This Car Have Been Countless, But Until Recently Every Problem I've Had Has Been Okay Enough To At Least...
olivereric423
No Power On The Odb2 Port?
As The Subject Says The Odb2 Port Is Not Supplying Power To My Scanner. I Looked At The Fuses Inside The Cab But Didn't See One That...
jhare213
Can You Get Me A Good Picture Of All The Vacuum Lines...
Can You Get Me A Good Picture Of All The Vacuum Lines And Where They Go To? Thank You So Much.
Big Joe24$$
VOLVO XC90
Codes P0700 And P0717, Input/Turbine Shaft Speed...
Hello! My Truck Is Giving A P0700 And P0717 Code. Based On My Understanding, The P0700 Is The Generic Transmission Code And The P0717...
rciv_1
Fuse Box Problems?
I'm Having To Unlatch The Fuse Box Over The Battery And Push It Down And Latch It Back To Get It To Start.
english88
DODGE JOURNEY
The Cooling Fans Will Not Come On At All?
I Have Checked The Relay And Fan Motor With Jumper Wires, And They Seem To Be In Working Condition. My Check Engine Light Is Not On. I Have...
est91
Engine Swap?
I Was All Set To Buy A Remanufactured Engine From Tri-star, But They/i Had Delays And Now I Am Asking More Questions. I Feel The Need...
lpulsifer
What Is The Name Of The Part That Connects To The...
It’s Two Metal Pipes With Connections On Both Sides (one For Evap Core And One For Expansion Valve). The Expansion Valve Needs To Be...
Kaythames02
HONDA CRV
Passenger Side Blinker Does Not Work?
Front Bulb And Side Mirror Blink Fast. Replaced Bulbs And Even Switched From Other Side. Definitely Not Bulbs. Looked At Connector And Did...
Speedog
Poor Fuel Economy?
Hi, I Have The Vehicle Listed Above (japan Made) I Bought It Second Hand. I Bought It For What The Manufacturer Claims That It Can Make 44...
Said84
LEXUS ES 300H
Engine Not Cranking?
Hey, My Name Is Roderick And I Have The Vehicle Listed Above. I Recently Bought It And It Had Some Things Wrong With It So I Jumped Into...
roddey
LEXUS LS 400
ABS Module Replacement?
Had Diagnostic Done. Abs Control Module Is Bad, But The Big Named Shop Said They Have To Replace Brakes And Rotors All The Way Around Car....
Sweetpea1973
MAZDA TRIBUTE
Happy Fathers Day!
Time To Break Out The Bbq And Cooler And Take A Break :) Nobody Needs It More Than We Do!
Ken L
A/C Issue?
My Air Conditioner When Engaged Will Blow Through The Vents Then Stop And Start Blowing Through The Floor Vents Then Stop And Blow Through...
Derrick West
CHEVROLET LUMINA
607
608
609
