Lost Phone Behind Center Glovebox Of The Car Listed...
Lost Phone Behind Center Glovebox Of The Car Listed Above.
Bweluc26
BUICK ENCORE
Growling When Accelerating And Turning?
I've Noticed In The Last Few Weeks That When Accelerating On The Highway Or From A Red Light My Car Makes A Growling Sound (the Only Way...
Lakiladonahue
KIA SOUL
Cannot Seem To Get The Computer To Give The Fault Code...
I Turn On The Key, Turn The Switch To The Diagnostic Mode, One, Blink, Two Blink, Three Blink, Four Blink, Then Turn The Switch Back...
tinylimo
NISSAN TRUCK
Used Transmission Installed In Car, It Shifts...
I Just Bought This Car For A Friend; Previous Owner Got A Lower Mileage Used Transmission From The Exact Same Model And Installed It Into...
Danxtrem
VOLKSWAGEN JETTA GLI
Hard Starting Issue?
It Doesn't Seem To Have A Reason But It's Getting Worse Sometimes Fire Up Normal Other Times It Just Keeps Turning Over Shut The Key...
Karl fisher
JEEP LIBERTY
Third Brake Light Removal?
I Have Water Entering My Trunk Whenever It Rains. It Seems Like It May Be Coming From The Left Side Of The 3rd Brake Light. I Tried Removing...
Ezex
KIA SEDONA
Will Not Start, When Cranking It Backfires?
I Recently Rebuilt The Engine. The Truck Won’t Start I Crank It And It Backfires. It Flooded The Spark Plugs So I Replaced Them With New...
Rubengr541
TOYOTA PICKUP
Overheating When I Turn On The A/C?
So, We Got Our First Hot Day And I Turned On My A/c. After Doing So I Noticed My Temperature Gauge Begin To Rise. The A/c Began Blowing Hot...
bdab68
HYUNDAI TUCSON
Won’t Start Backfires
Recently Rebuilt The Engine And Heads. The Timing Is Correct. When I Crank It To Start It Won’t And Backfires. Pulled The Spark Plugs Out...
Ruben541x13
TOYOTA PICKUP
Headlight Do Not Turn Off Even With The Car Is Turned...
My Headlights Are On. I Believe They’re The Low Beams. They Will Not Turn Off Even With The Car Off In The Key Out Of The Ignition. The...
J Cruise
LINCOLN TOWN CAR
Whistling Sound After It Has Warmed Up, It Sounds Like...
It Is Steady Hi Pitched. Does Not Change When Throttling Up. Can't Seem To Locate The Problem. Obd Plug In Will Not Let Me Jump It. Does...
Clownroyale
The Truck Is Bogging Down When I Give It Gas And Won’t Let Me Go Over 20-30 Mph. When I Give It Gas It’s Like It’s Not Getting Enough...
bird24102
TOYOTA TACOMA
Will Not Start, Electrical Issues?
I Purchased My 2013 Holden Captiva Last Year Through A Car Yard, My Elderly Father Found It As We Were At Different Ends Of The State He...
mechanicalmiss89
HOLDEN CAPTIVA
Codes P1588, P1589, P1588, And P1589, What Do These...
I Have Some Codes And I Don’t Know What They Mean. P1588 P1589 P1588 P1589.
Timatree
MINI COUNTRYMAN
A/C Intermittently Not Blowing Cold Air?
I Got The Car With 56,000. Around 60,000 I Started To Notice My A/c Will Stop Blowing Cold. I’ve Done An A/c Recharge. It Was A Little Low...
Mroulet1
HYUNDAI TUCSON
Ac
I Got The Car With 56,000. Around 60,000 I Started To Notice My Ac Will Stop Blowing Cold. I’ve Done A Ac Recharge It Was A Little Low Not...
Mroulet1
HYUNDAI TUCSON
Will Not Start And Leaking Some Type Of Liquid?
So, Recently I Had Gotten My Car Worked On And The Only Two Issues I Was Having At The Time Were The Catalytic Converter And Carbon Build...
b_jennings87
AUDI A4
Radiator Cooling Fan?
I Had Someone Replace My Radiator For Me And They Did Not Fix It To The Fan Shroud And The Fan Shroud Fell Forward Or Backwards. I Mean Into...
Anita Troy
DODGE INTREPID
How To Change The A/C Roof Vent?
Hi, Wondering If You Could Help Need To Change A Roof Vent Rear Of Seat Alhambra. Would You Be Able To Assist Me In Doing So. Any Advice...
Njc75
SEAT ALHAMBRA
Oil Leak After Having My Tires Balanced?
I Had My Oil Changed 5 Days Ago And They Said Everything Looked Good. I Had My Tires Balanced Yesterday And That Night I Noticed There Was A...
TinyDancer01
TOYOTA C-HR
The Battery Light Turns On And Off?
I Took My Car To An Autozone For The Battery Light Being On And He Had Me Turn My Car Off And On And Then Said It Read That My Alternator...
Jaxson1212
MAZDA 6
Start Signal?
I Had To Replace The Starter And The Battery At The Same Time. The New Starter Is Wired In The Same As The Old One (which Worked But Was...
John Fullilove
The AT Light On My Car Is On?
When I Drive The Gears Slip And Stutter Slightly Between First And Second Gear And When I Come To A Stop It Drops From Third Gear To First...
Jaxson1212
MAZDA 6
How To Patch A Hole In The Coolant Reservoir Tank?
Car Was Smoking And Found The Coolant Reservoir Empty, And Everything Was Wet. Found A Nickel Size Hole In The Tank. I Want To Do A...
jacsbratt
CHRYSLER PACIFICA
Fuel Leak?
The Fuel Line Has A Hole In It Up Where You Put The Gas In It. He Wants To Do A 2 In To 2in Connector To Fix This. Would It Work Or Any...
Tony Loki Lacroix
606
607
608
