Front End Rattles And Clicks Specially When Turning?
Changed Drivers Cv Axle Twice And Going Through Tires Like Crazy, Why?
nancywallace36
HYUNDAI SANTA FE
Codes 920, 921, And 999, No Bus?
On My Fuse Block Under The Hood Has A 20-amp Fuse To Transmission Relay When Tested From Ground To Fuse There Is Nothing. When I Test...
Don Sikes
Loss Of Power To The Throttle?
This Weekend Alone I've Replaced The Cam And Crankshaft Sensors, Alternator, Starter, And Throttle Body. It Starts Up First Try Until...
Dbradley1998
DODGE JOURNEY
Transmission, Rough Shifting?
Transmission Seems To Shift Roughly Between Gears. Also, It Will Periodically Get Stuck In Too Low Of A Gear While Driving Down Road And...
Carrie Thomas Payne
Cannot Shift Into Any Gear?
Initially The Clutch Went Out. It Is A Hydraulic Clutch By The Way. It Was Replaced With A New One. Immediately Upon Test Drive All Gears...
jomed7
NISSAN HARDBODY
Replacement Key Activated The Security System?
I Lost My Key And I Have Another Key That Turns The Ignition, But It Shows That Security Theft. How Can I Get It To Start My Car?
Naomi7600
CADILLAC DEVILLE
Will Not Start?
I Was Given The Car Listed Above Because The Previous Owner Was Having Trouble. It Appeared To Have Been A Rundown Battery, So They Put In...
drobins11
VOLKSWAGEN BEETLE
Windshield Wipers Stopped Working?
I Changed The Fuse For The Wipers They Worked Briefly Then Just Stopped. They Worked Again A Few Days Later Then Stopped Working Again. How...
Aaron Thompson
Cylinder Valve Broken/Fractured?
I Had Been Driving Down A Highway For About 2 Hours And Then Stopped At A Rest Area And Left The Engine Idling. While The Engine Was...
jdevries64
34 IMAGES
Shut Off While Driving, Cranks But Does Not Start?
My Car Just Stopped One Day While Driving It. I've Replaced The Transmission Range Sensor, The Spark Plugs, The Timing Belt And Idler...
alinbradford
SUZUKI FORENZA
Ford Exploer
Changed Ignition Did The Sparkplugs Wires Oil And Idler And Fuel Filter And Pump. Changed Battery And Fuses Still Just Kicks With No Start....
Greg zamarron
Temperature Rising After Driving For Fifteen Minutes?
The Temperature Gauge Starts A Little Under Halfway But After About 15 Minutes The Gauge Starts Rising And The Car Starts Hesitating.
Desser Moton
HONDA CRV
Codes C0001-01-2B, C0020-71-68, C0082-48-2B, And...
One Day I Turned On The Car And Saw That The Abs, Tsc, And Brake Lights Were On. We Checked The Brake Fluid, And It Looked A Tiny Bit Low...
abyssal22
Crank No Start, Security Light Turns On?
The Car Will Turn Over And Crank But Only If You Spray Ether On Iban Now When You Try To Crank It The Security Light Comes On. Fuel Pressure...
Amizzell44
GMC JIMMY
P0725
2002 Dodge Dakota Trouble Code P0725. I Have Replaced The Crank Sensor And Speed Sensor. Put A New Fuel Sending Unit In. So The Fuel Gauge...
Earl91
Code P0725?
I Have Replaced The Crank Sensor And Speed Sensor. Put A New Fuel Sending Unit In. So, The Fuel Gauge Sometimes Works And When It Does The...
Earl91
A/C Blows Hot Air?
The A/c Is Blowing Hot All The Time Now, Which Is A New Issue. Ongoing A/c Issues, All Intermittent: 1) After Starting The Car And...
Desiree2323
LINCOLN TOWN CAR
After Replacing The Thermostat When Idling The Engine...
Hello And Thank You For Your Time. Okay, So My Truck Was Overheating For Quite A While. I Don’t Drive It Much, But When I Do, It’s...
Sir Dramasticly
NISSAN HARDBODY
If I Replace The BCM Can I Just Plug In And Play?
I Was Replacing Light Bulbs Inside The Car When One Broke Off In My Hand And Blew The Fuse. I Replaced The Fuse And Now The Interior Light...
papalavac
CHEVROLET CORVETTE
Poor Fuel Mileage After A Tune Up Was Done?
Before I Had A Tune Up, I Got 32 Miles A Gallon Highway. After The Tune Up I'm Only Getting 24 Miles A Gallon Highway. What Can The...
Myra Sandoval
HYUNDAI ELANTRA
No Spark?
No Spark.
Eddie 16843
OLDSMOBILE CALAIS
Ignition Swap?
Lost Key And I Want To Know If The Ignition Out Of My 2008 Will Work In It. What I'm Asking Is Can I Put An Ignition Out Of A 2008...
Jcnitro12
NISSAN MAXIMA
Will Not Start When At Operating Temperature Sometimes...
Won't Start At Operating Temp After Running For A While Sometimes And Floods Out.
Bryan Keeth
PCM Problem Code P0601?
Hi There, I Have The Car Listed Above Motorsport. I've Had It In Storage For The Last 9 Years In My Barn. I Ruined My Old...
Perrylee
DODGE INTREPID
The Driver's Seat Will Not Move At All Nor Will...
I Also Noticed The Tilt/periscope Steering Is Not Working. I'm Thinking They're Tied In Together.
mlrjones
CADILLAC DEVILLE DTS
595
596
597
