Identify An Oil Leak?
I've Got An Oil Leak From The Engine. There's A Belt Driven Component That's Covered In Oil, But I Can't Identify It. I Did...
Starbuck106
TOYOTA CAMRY SOLARA
Written Clutch Replacement Instructions Needed?
I Am Totally Blind; I Am Requesting A Written Description Of How To Remove The Transmission, Replace The Clutch And Replace All Removed...
tomwarta
MAZDA MIATA
Fuse Box Wiring Color Correnaded
Wiring Pattern Under The Hood To Reconnect Wires From One Box To Another.
KingofKings11
PLYMOUTH BREEZE
Theft Light Comes On When I Turn The Key To The Run...
The Theft Light Comes On When I Turn The Key To The Run Position, The Theft Light Comes On, Which Never Happened Before. It’s Not...
John Fullilove
Top Idler Pulley Removal?
Hello, So, I Have A Somewhat Complex Issue. I Am Changing The Top Idler Pulley, The Top Bolt That Holds The Bracket Is Almost Rounded...
mstormin919
MAZDA MILLENIA
Starting System
(car Won't Stay Running.)I Was Sitting With Car Idling When It Cut Off. I Noticed Gas Light Was On And Walked To Get Gas. Put It In And...
Julie Powers Johnson
CHEVROLET CLASSIC
Steering Column Swap
Wi) The Steering Column From A 2.2l S10 Work In My 4.3l S10 Same Year Model
StumbledIn
Camshaft Position Sensor Bank 1 Sensor A Trouble Code?
I Have Replaced The Camshaft Position Sensor With A New One. I Have Cleared The Codes And Run The Engine. The Same Code Is Reported. I...
MBAUMHOFF
TOYOTA SIENNA
Rough Idling Acceleration Issue Foul Exhaust Smell Bad...
It Rough Idles From 1k To Like 400 And It Has Accelerating Issue. When I Press The Gas Revs Go Up But Not The Speed. There Is Just A Random...
Bx1
Rough Idling Bad Fuel Economy Bad Acceleration Foul...
It Rough Idles From 1k To Like 400 And It Has Accelerating Issue When I Press The Gas Revs Go Up But Not The Speed And There Just A Random...
Bx1
Rough Idling Hard To Accelerate Bad Fuel Economy
So It Is Rough Idling Like I Said And When I Accelerate It Goes Up In Revs But Not In Speed Also Fuel Economy Is Not So Good I Went On A 2...
Bx1
Changed The Coils In My Car And After That I Cannot...
Okay, So, I Went And Changed The Coils In My Car And After That I Couldn't Start My Car At All, I Put The Key In And Turned It And...
michaelmaxwell420559
BMW 530I
Head Bolt Torque
I’m Looking For Head Bolt Torque Specs On A 2013 Chevy Cruze 2.0 Diesel
Runt1919
CHEVROLET CRUZE
Head Bolt Torque
I Am Looking For Head Bolt Torque Specs On A 2013 Chevy Cruze 2.0 Diesel
Runt1919
CHEVROLET CRUZE
After A Steering Column Change, Ignition Switch Powers...
The Ignition Mechanism Down Inside The Og Column Was Seized Up. I’ve Since Switched With A Matching Column From The Wrecker And All Things...
codykarey
Air Blend Door Actuator, How To Remove Floor Duct To...
I Have Removed The Glove Box And I Need To Know How To Remove Floor Duct To Access The Actuator?
Neaves69
After Making An Aggressive Braking Move The Car Would...
This Morning I Had To Make A Pretty Aggressive Brake And After Doing So My Car Stopped Working As In, I Would Press The Gas Pedal And It...
kcheng
KIA SEDONA
Chassis Grease Recommendation?
I Service 3 Different Fleets With Different Vehicles: Freightliner, Workhorse, Mack, Ford, International Etc, And Wanted A...
mtrdudes
INTERNATIONAL TRUCK
Will Not Start?
I Was Leaving For Work One Morning And I Discovered My Car Wouldn’t Start. I First Thought It Was The Battery, But I Had All My Indicator...
Melysec04
VOLKSWAGEN BEETLE
Alternator Overcharging?
New Battery And Alternator And It's Still Showing On The Dash 16 Volts. Don't Over 16 But Does Drop To 15.4 But Goes Right Back To...
Ken Johnson
Temperature Gauge Reads Center, Then Works Towards Hot...
So, A New Water Pump Installed In October Of 2022, This Past Week A New Thermostat And Coolant Temperature Sensor Installed As Well As A...
jdstarner
Piston Connect To Crankshaft?
I Need To Send Block To Machine Shop For New Cam Bearings, But I Would Need To Take Off Piston And Crankshaft. I Can Take It Off But I'...
Ayymatthew
Well My Cam Bearing Are Wore Out So I Need To Take It To A Machine Shop, Due To Insufficient Funds Best Thing Is To Send A Bare Block And...
Ayymatthew
After Installing New Spark Plugs, Wires And A New Coil...
I Put New Spark Plugs And Spark Plugs, Wires, And A New Coil Pack And Now It's Back Firing. What Could Make It Backfire?
lauratroy05
Transfer Case Stuck In 4w Low
Hello, I Was Wondering If I Can Get A Wiring Schematic On A 2007.5 With The Sqf. Looking To See If The Tcase Has A Lock? I Have Removed...
Jdub6567fleet
594
595
596
