Fuel Filter Location And Replacement?
Where Is The Fuel Filter Located And Are There Any Videos Out There For " How To Replace"? Is This A Simple Process Without Dropping...
blackhawkmo31
When Accelerating There Is A Screeching Noise?
Screeching Noise When Accelerate.
Michael Manerchia
Code P0401?
My Truck Has Been Giving Me Problems With This Code. It’s An Egr Valve. I Changed Out The Part It Says. I Cleaned Out The Throttle Body To...
Big_ben_20
After Running A Cable Directly From The Front Power...
Hi, The Car Listed Above Is A Police Pursuit Model. I'm Having An Issue Tracking Down A Short And The Alternator Not Charging The...
RICKT76
Fuel Pump Not Working?
Every Time I Turn Over The Key It Burns The Fuel Pump Fuse Out, Now The Fuel Pump Does Have Power To It, But It Is Not Working.
Nathanielbuss308
CADILLAC SEVILLE
Codes P0300, C0561-71, U0140-00, And U0121-00, Engine...
My Suv Listed Above Is Running Rough And Has A P0300 Code For Random Misfire. It Has A Couple Of Other Codes As Well. A C0561-71and U0140-00...
Screwloose13
Temperature Would Fluctuate Between 210 Mark And...
The Truck Listed Above Is An Ls Extended Cab. My Truck Had A Small Coolant Leak From The Water Pump And The Temperature Would Fluctuate...
rjones91s
A/C Compressor Swap?
Hello, I Have The Car Listed Above Whose A/c Compressor Is Bad And I Looked For It In My Local Spare Parts Shop, New Or Old I Couldn...
SaMi AhMed
CHEVROLET CAPRICE
A/C Clutch On Off, Not Staying On?
A/c Pressure Is Good, Not High Or Low. Radiator Fan Is Good But Not Coming On When A/c Is On. I Unplugged High Pressure Switch And Cooling...
Jamie Crider
ABS Brake Module Replaced Does It Need To Be Flashed?
If I Replace My Entire Abs Module, Pump And All, And Buy A Used One With All The Same Numbers Etc; Will I Have To Have It Reprogrammed/...
SHADETREE1952
NISSAN FRONTIER
Rear Knuckle Bushing Replacement?
I Am Replacing The Rear Trailing Arms On The Car Listed Above And My Local Toyota Dealer Does Not Stock The Bushing Which Connects The...
jay_sanchezz15
No Codes Now, No Engine Power?
Have Replaces Spark Plugs And Coils, Idle Sensor, Throttle Position Sensor, Intake Is New And Put It Back Together And Idles At 2,600...
needassistance
Bumping Noise On Passenger Side Front Wheel?
Bumping Noise On Passenger Side Front Wheel When Driving On Any Uneven Road?
Rodneyk12
DODGE DART
Car Has No Electrical Power After Ignition Switch...
I Changed The Ignition Switch And Got No Power To The Vehicle. No Crank, No Start, No Lights On Dash.
ZachAuto96
VOLKSWAGEN PASSAT
Idle Fluctuate Or Idle Surge?
I Received A Call About 6pm Today From A Fellow Engineer To Come Over And Check A Car And Rectify The Problem. I Asked The Car Owner As Well...
David Davo Essien
A/C Would Be Cool For 5 Minutes And Then Gets Hot?
I'm Noticing That My Coolant Fans Will Not Operate. I'm Not Overheating, And I Tend To Idle For Long Periods Of Time, And They...
1993Fordboy88
HYUNDAI TUCSON
Wipers, 30 Fuse Was Blown?
My Name Is Kate. I Have The Car Listed Above. My Wipers Were Slow Then Wouldn’t Move. I Changed The Wiper Motor And They Worked For A...
Kmcauliffe
Engine Noise, Exhaust Leak From Back Of The Motor?
Have You Seen These With An Exhaust Leak From The Back Of The Motor? Sounds Like It, This Is The 4 Cylinder One.
Driveshaft Carrier Bearing Replacement?
I Found That My Center Carrier Bearing Needs To Be Replaced. We've Already Gotten The Driveline Off And Have Come To The Issue Of Not...
Sarah Jurek
DODGE JOURNEY
Where Is The Cabin Filter Located?
Cannot Find Where Cabin Filter Goes?
Dionte214
2022
FORD F-650
Brakes Locked Up Three Times At Slow Speed?
I Went About A Mile From Home And Then Back Home, Because Three Times, As I Was Pulling Away From A Stop, As I Got Up To 5-10 Mph, It...
GPbigtruck
My Car Just Run 40 Mph.
I Replace The Camp Shaft Left Abs Speed Sensor. I Do The Tune Up And Still Running 40mph. Now I'm Trying To Replace The Transmission...
Johanson Purugganan
Car Not Staying On
I Start The Car And Two Mins Later It Shuts Down, Believe It’s The Pcm Cuz My Blinkers Don’t Work And My Wipers Don’t Work As Well...
Hardworkyah
DODGE MAGNUM
Crank No Start Issue?
Thanks For Any Help First Of All, 2the Truck Listed Above Is 1500. Crank But No Start, No Reading On Fuel Gauge. Started One Morning For...
Ciscodlr
Blinkers, Windshield Wipers, Interior Lights, Not...
My Blinkers, Windshield Wipers, Interior Lights, Are Not Working, And Now My Car Starts Up And Shuts Down. Plz Help
Hardworkyah
DODGE MAGNUM
596
597
598
