I Cannot Get My Anti-theft To Turn Off Or Reset?
The Car Starts But Shuts Off Right Away And The Red Light Flashes The Entire Time.
Aaron-m
DODGE CHALLENGER
Transmission
Won’t Go In Gear Also What Other Cars Have Interchangeable Parts
stephaniechancler
Transmission Swap Compatibility?
Transmission Needs Replaced, What Other Cars Inter Change With This?
stephaniechancler
A/C Fan Only Works In Cooler Temperatures?
The A/c Compressor Is Engaged But The Fan Motor Is Not Running. Fan Motor Does Work In Mornings But Not In The Afternoons.
Mugsyreyes
AUDI A3
No Bus, Shut Off While Driving, Will Not Stay Running?
When I Was Driving Down The Road The Van Shut Off And Got It Started But Had To Get It Towed Because It Would Not Start. Later Once I Got It...
Stevekatie1219
2012 Chevy Impala Oil In Intake Manifold
Yes I Have A 2012 Chevy Impala And I Was Wondering What Would Be The Cause And Solution To Oil In My Intake Manifold, The Throttle Body Has...
Brianna Aleta
Does't Go Into Idle After Star Up
The Car Starts No Problem, Goes Into Idle For A Brief Moment, But Then Stalls. P1599 Code. I Have Cleaned The Throttle Body, Replaced...
SaturnCar
SATURN SC2
2007 Chrysler 300 Abs/tcm Issue
2007 Chrysler 300 Touring 3.5l V6 5 Speed Automatic Transmission Rwd 85k Miles My Issue Is: The Car Is In Limp Home Mode. The...
Jjmackinhard
A/C Not Working At Idle?
A/c Works While Driving Fine When You're At An Idle The A/c Compressor Turns Off And The Radiator Fan Does Not Work, Only With The A/c...
sudesh harinarine
Brakes
My Wheel Is Shaking When I Turn Left An Shakes When I Brake
Josh Twine
BMW 325I
Car Screeching When I Crank It?
Car Screeching When I Crank It. It Stops When I Rev It 2 Or 3 Times. It Only Does It Whenever I Crank The Car. After Revving It Stops. It...
Yelladude901
34 IMAGES
BMW 320I
Car Starts To Sputter, Shuts Off, And Will Not Restart...
I Have An Issue With It Running. I Put A New Fuel Tank, Fuel Pump, Fuel Filter, And A Fuel Pressure Regulator On It. Once I Put The Fuel...
Luke2004
PONTIAC FIREBIRD
What Type Of Oil I Should Use Or What It Takes?
Not Really A Problem Just Wondering What Type Of Oil I Should Use Or What It Takes.
Ruby Freeman
FORD CORSAIR
Car Stalls When Slowing Down/stopping, Codes U1000...
Vehicle Starts Up Great But Every Single Morning When The Engine Has Sat Overnight, I Will Start It Put It In Gear(reverse/drive) And It...
Jadeashley531
NISSAN MURANO
Are These Scratches New Or Old?
Chrissaenz
BUICK VERANO
I'm Wanting To Use The Transmission Out Of My 2000...
My Transmission Won't Shift Out Of First In My 2005 Dakota 3.7 So I'm Trying To Replace It With The One From A 2000 Durango 4.7 Will...
parkerrob
Can Someone Tell Me Where Is The Knock Sensor Of A Mitsubishi Eclipse 2001 Gt 3.0?
Brandon.09
MITSUBISHI ECLIPSE
Engine Shuts Off?
Starts Runs 2 Seconds Shuts Off. All Gauges Go To Off. Electric Failure Gauges Come On Within Seconds Have Light On Dash Shows Key And Lock.
Rogerenos
Wiring Color Code Diagram For The 02 Sensor Bank 1...
I Need A Color Code Wiring Harness Diagram For The Car Listed Above.
Wolfe4537
The Screen Sometimes Goes Black And Whatever Buttons...
The Screen Sometimes Goes Black And Whatever Buttons You Touch She Won't Awake, But I Still Have Radio Sound And All And If I Change...
MERCEDES BENZ E350
A/C Works But As Soon As I Get To A Red Light It Gets...
My A/c Works A Little Bit Cool When I Drive But As Soon As I Get To A Red Light It Gets Hot. Do You Know What That Could Be?
Wperry780
A/C Is Now Making This Chewbacca Like Noise On My...
My Car Just Had The Radiator, Radiator Hose, And Water Pump Belt After The Belt Coming Off Without Me Knowing And My Car Got Too Hot....
Liv Ross
KIA SPECTRA
70% Of Fuses With No Power?
I Just Bought The Car Listed Above But Didn't Check Dash Lights Or Radio. The Guy Said It Needed A Blower Motor For The A/c. I Put A New...
Jay Henderson
Place Foe Plug
Where Does The Orange And Black Female Plug Go.
Explain
HYUNDAI TIBURON
Car Will Not Fill Up With Gas All The Way?
Whenever I Fill Up My Car. The Gas Pump Will Stop When It Senses Its Full But When I Turn The Car On It Is Only 3/4 Way Full.
foursmiles
DODGE JOURNEY
592
593
594
