Will Not Stay Running?
Greetings. I Have The Vehicle Listed Above Z18xe. It Starts And Shuts Off. Checked Fuel Relay/pump Turns On. I Have Spark. Replaced Cam And...
Eclectic Eclectic
OPEL ZAFIRA
No Power Near 2,500 RPMs Or Above?
Vehicle Shut Off While Making A Turn, Started Right Up Without Difficulty. Stepped On Accelerator To Speed Up, Engine Bogged And No Power...
Firetender
NISSAN XTERRA
Window Would Go Up And Down But Tilt Sideways?
Without Giving A Long Story The Window Would Go Up And Down But Tilt Sideways. I Took The Lower Track Out And Replaced The Roller In The...
bw74
BUICK REGAL
My Car Would No Longer Start, I Went Through Trying To...
One Day After I Got Home From Work My Car Would No Longer Start, I Went Through Trying To Find Out If It Was Fuel Or Spark. I Could Hear...
Jj garza
29 IMAGES
OBD2 Code U0155?
The Car Starts Fine. Stays Running In Park, Reverse And Neutral. When I Put In Drive, It Stalls. I Changed The Fuel Pump, Checked The New...
Anthony Ruggiero
ACURA TL
Driveshaft Will Not Turn In Neutral?
Attempting To Replace Spider Gear In My Truck Listed Above 2500hd. Parts Are Coming On Monday But Wanted To Get The Project Going So That...
olivereric423
Starts But Will Not Stay Running?
Truck Was Running Fine With A Small Misfire Then I Decided To Check The Codes With An Obd2 Scanner. Well, It Pulled Up The Same Ones It Had...
1998z71
A/C Blower Stopped Working?
The Guy At Autozone Tried To Help Me Determine The Root Of The Problem He Hooked Up A Multimeter To My Resistor And Stated That The Resistor...
Faith Watt
CHEVROLET TRAX
No Power To The Fuel Pump?
Just Bought A Mini Whinnie. Test Drive Was Fine. Giving It A Go Through I Found A Cracked Pos Battery Term, When Replacing It The Starter...
Mama Kin
FORD E-SERIES VAN
How Many O2 Sensors For My Car?
Changed Out O2 Sensor While I Changed Out Radiator Fan. Now Check Engine Light Is On So Trying To Figure Out How Many O2 Sensors There Are.
j2wice
16 IMAGES
Codes P0303, P1063, P1062, And P0300,car Has Been...
Recently My Car Has Been Losing Coolant As Soon As It's Poured In. I Haven't Found Any Leaks, But The Exhaust Pipe Is Producing A...
User001
JEEP COMPASS
Blue Smoke?
Can't See Apparent Leak From Engine Just Usual Dirt. Blue Smoke From Exhaust, More When Accelerated. No Milking Color In Oil Do Need...
Simonjohnson445
VAUXHALL ZAFIRA
Coolant Leak
My Coolant Is Leaking Causing My Car To Overheat
Norma Jean
CHRYSLER 200
Fuel Injector Connector?
Heys Guys, It’s Me Again With My Car Listed Above. Replacing The Intake Manifold Gaskets And Noticed The Fuel Injectors Were Dirty, So I...
Ryan Levingston
Fuel Pump
Fuel Pump Location For A 2006 Clk 500 Amg
Ohmy19782020
MERCEDES BENZ CLK500
Radio Not Working?
My Truck Just Got Work Done On It And It Was In The Shop For 6 Days And I’ve Had It Back For 4 Days And My Battery Drained, And I Had To...
Spool14
Code P2767, Turbine Speed Sensor?
I'm Still Getting That Code P2767. Fluid Is Right 180* At 70mm. Changed Fluid And Filter. Drives Fine For A Day Or 2 Then Limp Mold With...
Willie Hurlocker
22 IMAGES
DODGE MAGNUM
HVAC Only Blows One Temperature, Stops Blowing And...
The Temperature Will More Will Stay A Consistent Warm Feeling From About 60 To 80ish Before The A/c Switches Over Into The Heating Setting....
yng
ACURA MDX
Headgasket
Blowing White Smoke I Checked The Oil On The Dipstick I Saw Milky Oil
Custom rides
GEO TRACKER
Oil Leak?
Have An Oil Leak, Not Sure Where It Is Yet, But It's On The Oil Pan. The Previous Owner Had The Oil Pan Replaced, So I Don't...
will31333
HONDA ODYSSEY
Blinking Interior Lights, Clicking Sounds, And Trouble...
Hi, Let Me Begin With, I'm Not A Mechanic, But I Can Follow Directions. One Day The Car Was Fine, And The Next, It Wouldn't...
MicheleH
CHRYSLER PACIFICA
Transmission Will Not Shift Out Of First Gear, Where...
Hi, I Think I Need To Change The Transmission Oil Pressure Sensor, But I Can't Find It On My Vehicle. Please Help.
ms.sgt.21
16 IMAGES
CHRYSLER 200
Alternator Wiring Issue?
So. You Know How You Put In An Alternator In The Vehicle Listed Above, Well I Got It In But Then When It Came Down To The Wires That You...
Oldman1954
MERCEDES BENZ ML320
Transmission DTC Code P0768?
I Need The Wiring Schematics For The Pcm Going To The Tcm Going To The Shift Solenoids. I'm Chasing A Short And Can't Find The...
javaqueen70
Code U0100, In Gear Car Does Not Accelerate Beyond 1...
In Parking Acceleration Is Fine. Error Code U0100 In Tcm; No Engine Check Light And Autostart Dash Light Blinking. Cleared The Code Then...
NZaidi
NISSAN SERENA
569
570
571
