95 Camaro Had Lines Disconnected From Box
Had To Do A Motor Change, Now I Dont Have Brakes, Do You Know How To Bleed Them. Someone Said With A Vac. Pump. Have 2 Bleeder Valves On...
cmiles1943
No Compression On 1992 Camaro V6
I Just Repace The Manifold Lower Gasket I Put It Back Together Now It Dont Start And No Compression Timing Is Right Anyone Have Idea?...
mgl01
Electrical Short?
I Have A 1992 Chevy Suburban, K1500 4wd. Lately We Have Been Having A Problem When Going To Start The Vehicle. After Sitting For A While...
purpleali
Oil Pressure On 1997 Ford Explorer
The Oil Pressure Gauge On My '97 Explorer Starting Fluctuating Between A Low Reading And The Middle Of The Gauge Approx. 6 Months Ago. I...
ccraigbrown
1999 Chevy Monte Carlo - What Could It Be?
I Drive A 1999 Monte Carlo With 69,000 Miles On It. Recently, My Car Started To "slip" Right Around 45-50 Mph Where It Shifts Into...
oldmil21
Rear Window Problem For A 1995 J30 Infinity
The Rear Window Continues To Stick On This 1995 J30 Infinity. Any Suggestions Will Be Greatly Appreciated.
cooldg
1996 Grand Am Will Crank But Will Not Start
1996 Grand Am Will Crank But Will Not Start. Car Just Stopped. Oxygen Sensor 2 Code Was Set Off For About 3 Weeks. Check Codes Again An It...
grandamtech
Door Problem
Gmc Suburban, 120k. My Driver Door Won't Open From The Inside. I Can Open By Opening The Window And Using The Outside Handle. It's Been...
Diego Covarrubias
2001 Grand Caravan Side Mirror
I Found A Cheap Replacement Mirror For My 01 Dodge Gr. Caravan (the Wife Backed Out Ot The Garage A Little Too Quickly One Day). Can Anyone...
mcisaacj
ENGINE TRYING TO SHUT DOWN
Acura Tl 2.5 1997 (90k Miles) - When I'm On Traffic Jams Or Vehicle Is Stationary, It's Revolutions Start Going Up And Down, Like Trying...
mark
Ford Escort Sticking
I Just Bought A Used 94 Ford Escort. It Is And Automatic But It Sticks Between 2nd And Third, And Runs The Rpm High. Now If I Start In Low...
way2kool
2000 GP-low Static Fuel Pressure But Is Fine When...
2000 Grand Prix Gt With 83,000 Miles. It Takes Several Tries To Start The Car After It Has Been Sitting For Over Four Hours. The Car Has...
Ramair
Hi I Need Some Help
I Got A 92 Grand Am 2.3 I Got Some Backfireing Going On I Doing Know What To Do I Need At Almost Anything I Could Think Of
markandmelissa514
Car Stalling
My 1990 Vw Jetta Seems To Either Almost Stall Or Fully Stall As I Slow Down To An Intersection. This Seems Even More Common After The Car...
lawsonsealey
2000 Alero Overheating
My 2000 Alero Has Been Having Cooling Troubles For About 1 Year. Currently, I Have Replaced The Thermostat And Water Pump; Blown Through...
Howls
171 Code
I Am Getting Code 171, Lean Trim Bank One. I Have A 1997 Cavalier 2.2l. I Have Changed The Number One O2 Sensor And Also Put In A Fuel...
MikeM
1917
94 Pontiac Sunbird 2.0 L, Leaking Antifreeze
Leaking Antifreeze From Front Of Engine. Is There A Bypass Hose On This Sohc Engine Or Can It Only Be From The Waterpump?
stevelutz425
PONTIAC SUNBIRD
1991 Corsica Ignition Prob.
Here It Is. I Lost The Keys To My Chevy Corsica So I Went To The Dealership And Got A Key Made. Got Back To My Car And The Key Didn't Work....
savage5150
Accelerator ??????throttle Body???
I Was Wondering If Anyone Knew What Could Be Wrong With My 91 Rodeo.I Tried Starting One Day And The Gas Pedal Was Stuck So Me Being Stupid...
soml2u
Spark Plug Gap? Valve Cover Replacement? 88 GMC V6
I Have An 88 Gmc With The V6 4.3l 262. I Need To Put New Spark Plug Wires, Plugs, Dis Cap And Rotor. My Question Is That They Come...
hotwheelsgmc
2000 Impala Electrical Question
Hello Everyone, I Was Driving Home Today From Work And Smoke Started Billowing From Under The Hood, Then Suddenly My Vehicle Had No...
mhphotographics1
NEED HELP: 87 Mazda RX-7
I Am Having Problems With The Car Over Heating. I Have Replaced The Thermostat, Temperature Sensor, Checked Fluids And Fans Work Properly...
chris tiell
MAZDA RX7
Just Broke A Piston Ring
Okay, My Daughter Has A 91 Amigo And Just When We Thought We Were Finally Out Of The "repair/replace" Woods, A Ring Busted In The Block....
pilincoln
1994 Ford Escort Lx, Hesitating
Hi There, I Am An Owner Of A 1994 Ford Escort Lx That I Have Owned Sine This Last June 05'. Just This Week I Have Encountered A Problem...
FordEscortGuy1
1988 Chevrolet Caprice Transmission
I Bought A 1988 Chevrolet Caprice With 88,000 Miles And My Old Boss Who I Bought It From Had A Transmission Problem And He Got Another...
Que24
20240
20241
20242
