WHERES THE THERMOSTAT?
Well I Just Shot My Thermostat On 89 Honda Civic, So I Am Wondering Where Would It Be. I Believe I Found It Right Behind The Fan In The...
clunk_thehood
88 Firebird- No Start-HELP!!
My 88 Firebird (with 250,000 Mi) 305 Tbi, Engine Was Rebuilt @ About 200,000 Was Running Ok. Started To Run Rough Like A Wet Distributor....
dragginwaggin
PONTIAC FIREBIRD
Body Control Module?
About 4 Times Now, On My 2001 Chevy Blazer 4x4, I Have Had My Drivers Side Power Window Stop Working Once It Has Gone To The Down Position...
cshaw
Fuel Pump Relay Switch
Where Is It Located On A 1991 3.0l Mercury Sable? The Deal - Car Wont Start 'sometimes' Due To Battery Not Being Charged. Especially...
smartinez8
Altima 2002 Heating Problem
Hi. Need Your Help On Fixing My Car Heating. The Heater Was Doing Fine Till A Couple Weeks Back. Then One Day I Turned On The Car And...
domainexpert
Chevy Suburban Engine Sevice Light
1999 Chevy Suburban. Whenever I Climb A Good Sized Hill Or Grade, The Suburban Looses Power, Bucks And The Engine Service Light Comes On...
mikevio
Knocking Sound In 1999 Saturn
My 1999 Saturn Sl (130k Miles) Knocks Loudly Every Time I Turn Off The Ignition And Shudders To A Stop As If I Had Stalled Out, Whether I...
rzlcad
Discovery ABS Modulator
On A 2002 Discovery The Dealer Informs Me That The Error Code Of 11, 4 Is Appearing. They Cleared It And It Hasn't Returned But They Tell...
ejstadler
93 PARK AVE CHARGING PROBLEMS
I Have A 93 Park Avenue And Have Been Having A Charging Problem For Some Time Now. I Have Replaced The Alternator Positive Cable Checked...
bluedevil27
Can Someone Help Me!?
I Drive A 1999 Monte Carlo With 69,000 Miles On It. Recently, My Car Started To "slip" Right Around 45-50 Mph Where It Shifts Into...
oldmil21
Hooking Up Trailer Lights For 93 Chevy Astro Van
I Have Not Been Able To Figure Out How To Hook Up My Trailer Lights For My 93 Chevy Astro Van. I Took The Van To A Mechanic And He Says That...
pflick
CHEVROLET ASTRO
Car Stumbles On Accelleraton
I Am Rebuilding A 67 Camaro. I Have Installed A 350 Chvy Crate Motor And A 4 Speed Automatic Trans. Headers, Dual Exhaust Flowmasters. I Am...
Brent Farris
1999 Ford Mustang Clutch!
I Have A 1999 Ford Mustang (6 Cylinder) And Recently When I Go To Engage The Clutch It Makes A Grinding Sound, Then While The Clutch Is...
robman24
92 Ford Escort Running Hot
My Question Is Why Does My Escort Run Really Hot When I Drive On The Streets And When I Drive On The Highway It Stays Cool. But If I Drive...
racedad117
Heater Not Getting Hot?
My Heater Doesn't Get Very Hot. The Knob That Turns The Tempature To Hot Does Not Turn Easily. Could This Be The Only Problem, Or...
1wiley
Vehicle Vibration On Cold Start For Approximately 20...
Hello, I Am An Owner Of A C320. This Car Has A Strong Vibration Especially Felt In The Steering Wheel When I Begin Driving It Each Morning...
tectalbeak
1920
Price For Replacing 1992 Isuzu Rodeo Engine
I Want To Replace My 1992 Isuzu Rodeo Engine. It Is The 3.1 V6. It Like Online I See A Range Of 1100 To 2000 Dollars. How Much Should I...
bareajul
1999 GEO - Heater Doesnt Work / Wiper Fluid Not...
Heater: The Heater Stopped Working, For Awhile The Heater Worked Only If You Put It On The Maximum Blowing Setting, But None Of The Lower...
Christian_Moore
2003 Impreza RS Automatic Transmission
My 2003 Impreza Rs With Automatic Transmission Has 87,000 Miles And Is Making A Whining Sound On Acceleration, But Not When Coasting. My...
tlusto
SUBARU OTHER
Cleaning Of The Manifold Sensor
Hi, I Have A Problem With My N Reg Fiesta 16v. The Car Starts Fine But Then Shortly After Starting The Revs Start To Drop Until It Cuts...
fiesta jay
Water Pump Problems
Hey Guys. I Recently Bought A Used '93 Jetta Gls From A Friend Of A Friend. The Car However Seems To Have Needed A Lot Of Tlc Because I've...
ccastle412
2001 Chev S-10 Stored And Now Won't Start
I've Been Storing My Truck Since I Baught It In 01, Never Had A Problem Before With Starting It Through The Winter Months, Until This Year...
hepworthd
FORD F-350
Strange Clicking Sound
Hi I Have 93 Subaru Legacy, 2ltr Turbo Auto Wagon. Every Mornign When I Start It Up I Let It Warm Up For Ten Minuted Befor Heading Out....
rjwoodie
MY Car Now Pulls To The Left When I Brake?
My Car Now Pulls To The Left When I Brake, Its A Pretty Aggressive Pull. Sometimes When I Back Up I Hear A Bang From My Front Right Side...
Oofie
95 Camaro Had Lines Disconnected From Box
Had To Do A Motor Change, Now I Dont Have Brakes, Do You Know How To Bleed Them. Someone Said With A Vac. Pump. Have 2 Bleeder Valves On...
cmiles1943
20239
20240
20241
