Timing A 79 Gm 305 While Dead
I Have A 79 305 Engine That Im Putting Back Together From A Rebuild( Dont Say It.I Have Money Issues) I Have The Timing Gears And Chain...
firemedicsafd
1979
1990 Buick Century...Fuel Or Air Problem?
I Have A 1990 Buick Century Custom. Once It Hits A Little Hill The Engine Bogs Down Like Its Feeding For Gas. While This Problem Is Occuring...
Sloppy Joe
BUICK CENTURY
Check Engine Oil Light Not Resetting
Vehicle Is 2005 Isuzu Ascender, 7 Passenger The Wife's Car, I Have The Oil Changed Properly By A Mechanic And This Still Happens. ...
BBechtel
Removing Oil Pan
Can The Oil Pan Of A 1991 Isuzu Trooper Be Removed Without Pulling The Motor?
cdb1
Brake System
I Have An 87 Jetta And The Brake Pedal Seemed To Go To The Floor Barely Stopping You. So I Replaced The Brake Booster And Bled 2 Of The 4...
minnich23
70 VW Beetle
I Recently Rebuilt The Engine In My Son's 70 Vw Beetle, Rebuild Went Fine But Have Ran Into A Snag Putting It Back In. I Have Got The...
SBowman57
1970
No Power
Seedrum Back, After Lots Of Thought, And Being An Electrician, I Couldn't Give Up. Went Through The Vehicle Again And...
seedrum
Protege 99 - Loud Squealing Noise On Startup
Hi, My 99 Protege Makes A Loud Squealing Noise On When It Is Started After It Has Been Parked For Two Or Three Hours. A Mechanic...
pradhan_tushar
Fuel Emmisions Problem W/1999 Ford Escort
I Have A 1999 Ford Escort With 82,500 Miles On It. I Love My Little Car, It Has Never Given Me Any Problems, Until Now. My Check Engine...
SANDRA
Lack Of Heat?
For Some Time Now I Have Had A Lack Of Real Heat. I Changed The Following, Heater Core, Radiator, Heater Return Hose, Thermostat...
dude
Won't Turn Over
My Friend Used My Car To Jump Start Another. He Did So Incorrectly, And My Battery Is Drained. Now, We Can't Get The Car To Turn Over...
flynnigan
The Engine Looses Power ?
Hi Everybody ! The Engine In My Van Looses Power ( Almost Like Out Of Gas ) But Still Keeps Running, Seems Like On Two Cylinders, The...
wilk
'88 190E 2.3 Engine Wiring
Hi, I Have An '88 190 E With The 2.3 Gas Engine. The Wiring Harness In The Enging Compartment Has A Couple Broken Wires And Is Missing...
speakertim
On Startup The Engine Revs Up To About 2200 RPM?
On Startup The Engine Revs Up To About 2200 Rpm And Then Settles Down To About 1200 Rpm. If It Is Placed In Park/neutral It Will Go To 1500...
goodmis
MERCURY MYSTIQUE
The Car Shut Of In The Middle Of The Road?
The Car Shut Of In The Middle Of The Road And Coasted To The Side Of The Road And Then We Try To Start It Caught A Couple Of Times And Run...
coldspyke
The Clutch Pedal Started Moving To The Floor When...
The Clutch Pedal Started Moving To The Floor When Depressed. I Replaced The Clutch Master And Slave Cylinders. After I Bled The System It...
gotjuice
Help The Starter Keeps Running When In Park ?
Help The Starter Keeps Running When In Park As If Someone Is Turning The Key. Does Not Happen In Drive Or Natural Does Any One Have Any...
Kimmi
GMC SAFARI
Constantly Flashing Rear Wiper Lights, How Do I Turn...
Just Bought Used 97 Dodge Caravan And Cannot Turn Off Blinking Rear Wiper Lights On Dash, Please Help.
keith62461
1993 Oldsmobile Achieva S Transmission PROBLEMS!!!
:x :x :x Please Lead Me In The Right Direction! I Have A 1993 Oldsmobile Achieva S. It Is An Automatic. It Has 129888 Miles And...
CarolinaLily
1995 VOLKSWAGON PASSAT
I Have A 95 Volkswagon Passat, It Has An Oil Leak, I Can See Where The Oil Is Leaking Underneath, But The Oil Is Leaking Out As I Drive...
BILLYCLYDE
Transmission Recently, The Drive Light Has Begun...
My A/c Went Out About 2 Years Ago, But Just This Past Summer When I Tried To Get That Fixed, I Noticed A Change With The Transmission. It...
christiney
1986 Mazda Rx7 Not Starting
I Stopped Drivin My 1986 Rx7 Gs For About A Year So I Go Out 2 Start It But It Wont Turn Over So I Changed The Spark Plugs And Put Some Gas...
mrbreez
MAZDA RX7
Gmc 1998 Safari
Help The Starter Keeps Starting When The Van Is In Park. The Van Is Already Started When It Does This. It Does Not Do While You Are...
Kimmi
GMC SAFARI
5.3 Vortec Driver's Side Plugs Black & Sooty
2003 Tahoe 4x4 Z71 5.3 Vortec Flex Fuel. Odb 2 Codes P0300 (multiple Misfires) And P0134 (o2 Sensor Low Or No Voltage) 56,000 Miles...
mh01884
Dcl On 1991 Lincoln Continental
Hi, The Dcl Light On The Dash Lights Up. Can You Tell Me What Dcl Stands For And What The Problem May Be Or What To Look For? Thanks...
Cathy
LINCOLN CONTINENTAL
20241
20242
20243
