2000 Protege Tachometer
I Have A 2000 Protege Dx, Manual Transmission, And Unfortunatelly It Came Without A Tachometer In The Gauge Cluster. Is It Wired For A New...
shane836
99 Dodge Dakota
I Just Had An Interestig Problem With My Dakota, I Was Heading To Work, I Get Off The Expressway And Notice An Anti-freeze Odor And See...
dante50
'88 Ranger Hard Starting & Gas Fumes
High Miles, All Original 2.9l. Real Hard To Start And Lots Of Gas Fumes Until It Runs A Couple Minutes. Runs Ok When Warm. Acts Up When...
PutzinMS
1992 Silverado Right-side Tail Lights Not Working
I Had To Rock The Truck Pretty Hard To Get Out Of The Mud A Couple Weeks Ago And Afterwards My Right Blinker Indicator And Light Were...
Jordo
Engine Swap. KLZE And KLDE
1) I Have A 1993 Mazda 626 Es With A V6 Klde Engine (kl01) And Trans. I Want To Do An Engine And Tranny Swap Both To Klze's. Do I Need To...
NNPlayaz
MAZDA 626
Speakers Stop Working
Ok I Was Crusing Along One Day And I Heard Like Crackling Outta My Speakers Then 3 Sec Later They Didnt Work. I Was Like What The Heck Cuz...
hvyweight600
Car Wont Start
Hi I Have A 1995 Mazda Millenia, I Moved It Today To Clean It Out And When I Went To Started Back Up It Would Not Do It. It Makes A Cliking...
chuey
MAZDA OTHER
' 91 Tempo
'91 Tempo 2.3, Auto, A/c, Power Steering. Is It Possible To Remove The Inner Right Hand Side Tie Rod? I Need To Replace It Only, I Don't...
Eric
FORD TEMPO
F250 Idle Problem
I Have A 1999 F250 Truck That All Of A Sudden Started To Idle Up And Down When I Stop, Runs Fine When Im Going Down The Highway But Jerks...
Wintermg
1925
1993 Honda Cvic Speedometer 165000 Miles
My Daughters 93 Civic Speedometer Jumps Around When Speeds Of 70+ Are Reached. Any Advice What The Problem Is? Thanks Sam
spersell
1996 GMC Sonoma Creaked Head Gasket
My Problem Is I Have A Cracked Head Gasket And Maybe A Cracked Head. I Was Wondering How Hard Is This Job To Do Myself, Because I Don't...
gmyster76
GMC SONOMA
1999 Pontial Firebird Electrical Windows
My Son's 1999 Firebird's Driver's Door Window Quit Working Just As He Was Getting Ready To Leave Back To College. You Can Push The Button...
quick2cu
2000 Ford Expedition
I Can Hear A Klanging Noise In Front End Ihave Chan Ged Ujoints. Could It Be The Transfercase?
Ron
Camry '92 Ignition Problem
I Was Driving My '92 Camry And It Stopped Suddenly And I Had To Tow The Car To A Mechanic. The Mechanic Told Me There Is Problem With...
tv_sriram
Cold Start Problem
Hello Can Anyone Help Me Before I Set Fire To My Jag :x Its A 1998 Xj8 3.2 It Recently Had A Head Gasket Change And Ever Since Then I...
karawara88
JAGUAR XJ8
2000 F-350 4X4 Six Speed Manual
I Was Driving My Truck And When I Pushed The Clutch In Nothing Happened It Just Kept Pulling. And I Had A Hard Time Just Getting It Out Of...
mag3
Heater
I Had To Put A Piece Of Cardboard In Front Of My Radiator So Heater Would Get Hot. I Have Replaced Thermostat, Checked Vent In The Fan Box...
10foTuck
MAZDA OTHER
'87 Xj6 Fuel Pump Location
I Recently Purchased A 87 Xj6. Good Battery, Good Plugs, Good Spark. When I Filled The Tanks With Gas, The Fuel Did Not Reach The Fuel...
Oskeete
JAGUAR XJ6
98 Stutters After Washing Engine
I Washed The Engine Off My 98 626. It Ran Fine For About 10 Miles. Then After Having It Parked For About 1/2 Hour I Went To Leave & The Car...
gwayne100
1988 Nissan Sentra - No Spark
1988 Nissan Sentra, 98,000 Miles. Has No Spark To Spark Plugs. Replaced Coil, Power Transistor, Distributor Cap, Rotor, Plugs, Wires...
tennilledat
Will Not Move In Reverse
1st Question My Bronco Will Not Move In Reverse. It Will Go In Gear And It Tries To Move But Won't. You Can Put It In Neutral And It...
cbest2304
2003 Mustang Mach1 Stalls
After Countless Times Of Stalling While Driving I Took It Into The Dealership And The Replaced The Iac Valve. It Did Not Stall Once Until...
mach1gal
AC /Heater Blower
1993 Oldsmobile Regency 98 With Automatic Climate Control. The Blower Stopped Working. I Disconnected The Blower And Tested It With A Set Of...
larryinkc
2002 Ford Escort Oil Change/check Engine
My Boyfriend Changed The Fuel Filter, Air Filter, And Oil And Checked Some Other Things On My 2002 Ford Escort And A Little While Later My...
ashaalx
O2 Sensor
Hi Im New To Cars, I Just Got Done Getting A New O2 Sensor And I Cant Seem To Find Out Where To Put It. I Also Don't Have A Repair Manual...
red_fury_03
20202
20203
20204
