Brake Lights And Left Turn Signal Short Out And Blow...
My Brake Lights And Left Turn Signal Short Out And Blow Their Fuses Whenever I Use Them. Are They Connected Somehow?
db7108
GMC SONOMA
Oil Pressure Sensor
I Am Replacing The Oil Pressure Sensor. Where Is The Oil Pressure Sensor Located On A 1990 Merc Cougar Ls 3.8?
gabriel73
1996 Ford Probe GT Wont Start
I Have A 1996 Ford Probe Gt Automatic With About 140,000 Miles On It. Over The Last Half Year It Has Stopped Starting 3 Times, Each Time My...
tcman41
FORD PROBE
2002 Impala Water Pump
I Have To Replace My Water Pump, I Have Called A Parts Store And They Told Me It Would Be Around $30.00 For A New Water Pump. How Much...
kristine
Short Inside Of Alternator?
I Have A 1985 Mitsubishi Truck With 316,000 Miles. I Was Wondering What Are The Signs Of An Internal Short In The Alternator? Because I Have...
Amp9751
MITSUBISHI OTHER
1997 Mercury Sable
Is Blowing Water Droplets From Tailpipe. Runs Rough At Idle Or Slow Speeds. Check Engine Lite Is On. Codes Say 1 And 2 Cylinder Misfiring....
rich120865
MERCURY SABLE
1988 Plymouth Sundance, Idle Problems.
My Car Has Been Having Trouble Keeping A Smooth Idle. The Car Will Start And Then Die Immediately. If I Hold Down The Gas For A Few Seconds...
Esgaroth
PLYMOUTH OTHER
Now All It Does Is Turns Over But Wont Start Is...
I Have A 94 Toyota Camry Replaced The Ignition Coil In It. Run N Drove Fine. Bout 2 Months Later Was Goin Down The Road It Run Hot Blew The...
jeff38059
Safari Missing
I Had A Tune Up 6 Months Ago And The Mechanic Said The Spark Pugs Wires Were Bad And Wanted A Fortune To Replaced Them So I Did It Myself...
wmccreary
GMC SAFARI
Crown Vic Cuts Off
88' Crown Vic (302ci) Won't Stay Started, It Cuts Off As Soon As I Release The Key From The Start To The Run Position. I Changed Out My...
danielhaley
FORD CROWN VICTORIA
2001 Malibu
I Have A Question, I Bought This Car Almost 2 Years Ago And It Only Has 58,000 Miles Not Bad For A 5 Year Old Car. However Latly It Has...
eastboy1970
1993 F150 Poor Performance
My 1993 F150 5.0 Is Hard To Start Will Only Start If The Gas Pedal Is Held To The Floor. This Is What Was Done So Far, Cap, Rotor, Plug...
CLEMENRP
Electrical Problems
I Have A 99 Volkswagon Jetta, I Bought Used In The Year 2001. It Was Fine Up Until Just Recently I Was At 60,000 Miles And My Check Engine...
vwj99
95 Bonneville - 153,500 Miles - Will Not Start...
The Engine Seems To Run Fine And We Have No Gas Mileage Decrease. It Has Been Tuned Up And Serviced To Include Fuel Pump Replacment And...
Fred Hollis
'92 Jeep YJ Problems Update...
If Any Of You Have Been Reading About My Son's '92 Jeep Problems, Here Is An Update. I Will Tell You Everything That Was Done To Get The...
EvilWoman
CODE SCANNER
I Have A 1992 Pontiac Transport With A 3800 Buick Engine. I Am Interested In Purchasing A Code Reader As The Engine Light Comes On...
carignanr
2000 Mit Galant
I Have A 2000 Galant That Has Engine Over Heat When Traveling In Slow Traffic Or Stopped. The Fluids Are Up To Snuff And The Temp Returns To...
Dsundin
1998 Plymouth Grand Voyager Rear Coolant Leak
A Large Amount Of Coolant Is Leaking Near The Rear Passenger Tire And Appears To Be A Line From The Motor To The Back Washer. What Could Be...
fgwest
PLYMOUTH VOYAGER
Check Engine Light And Ideling
I Have A 1999 Mercury Grand Marquies. The Check Engine Light Came On I Checked The Gas Cap And All The Fluids All Thats Fine. Now It Won't...
Terrie
1989 Mazda 626 Stalling
I Have A 1989 Mazda 626 With 140, 00 Miles On It. When It Is Cold It Runs Fine. However When It Is Warm If I Let The Rpm Drop Bellow 1500...
nxess06
MAZDA 626
Driver's Side Only Wiring Problem 98 E-320 Wagon
I Have A 1998 Mercedes Benz E-320 4-matic Wagon. The Driver's Side Electric Window, Seat Adjust And Mirror Aren't Working Again. The...
chrisandb
MERCEDES BENZ OTHER
87 Maxima Alternator Belt
I Need Instructions On Changing My Alternator Belt. Please Help. I Cannot Get The Car To Move To Take It Anywhere. I Am On My Own. Any...
stewarttl
1987 Nissan Truck
I Have A 1987 Nissan Truck And When I Try To Start It, The Carb Will Just Fluild Out With Gas Where It Will Fill The Carb All The Way Up...
dwayne0028
NISSAN TRUCK
Power Steering Failing
While Driving Out Of My Driveway The Steering Just Quit On Me. I Couldn't Steer The Car. Luckily, I Continued To Go Staight And Then...
walker28
Antifreeze On The Floor
There Is Antifreeze On The Floor Drivers Side. The Car Smells Like Antifreeze And The Windows Fog Up From The Inside. My Brother In Law...
blk_kofi
20203
20204
20205
