Gas Milage?
I'm Trying To Find Out Does Gm Offers Any Trucks That Have Great Gas Milage Like My 2 Buddies 1996 Z-71 4x4 Silverado 5.7 They Get 25-28mph...
snipe1
Bar's Stop Leak For Cooling Systems
My Heater Core Went Out Driving My Car From California To Alaska Causing My Car To Overheat For Roughly 10min Until I Found A Place To Park...
chevrolet_camaro
98 Dodge Neon Issue... PLZ Help!
Hello All, I Have Just Recently Been Having A Problem With My Neon. Auto Transmission 110k Miles. Recently, When I Am Driving, I Will...
madcat424
Tranny Shifting Oddly
Once Again On My Mothers 2000 Buick Park Avenue I Notice After Driving It A While, When Shifting From Reverse To Drive, Or Park To Drive...
justinpaul411
94 Del Sol Code 4 Crank Angle Sensor (CKP)
My Car Gives Me This Code For The Ckp, Wich Is Inside The Dist And Controls The Timing For The Fuel Injection And Ignition On Each Cylinder...
chris tiell
HONDA DEL SOL
TROUBLE WITH MY CAR I JUST GOT
I Have A 1992 Acura Lengend My Check Engine Light And Abs Light Stays On. I Have Blue Or Gray Smoke Comming Out Of The Exhaust While I Am...
towens
HONDA OTHER
The Clutch Pedal Does Nothing When The Vehicle Is...
I Have A 86 S10 Blazer. The Clutch Pedal Does Nothing When The Vehicle Is Running. I Can Start The Vehicle By Depressing The Clutch And...
chuck
1992 Grand Am Stalling
When I Come To A Red Light Or Stop Sign My Car Stalls. Will Start Up Ok But Stalls When I Put It In Gear. Help Me Please , Thank You
prairie
ISUZU AMIGO Changed Radiator - Car Won't Start
I Recently Changed The Radiator In My 94 Isuzu Amigo (4wd, 2.6lt, 4cy) And I Started The Car With The Radiator Cap Open After I Put In...
jenny_latimer
Stutters While Accelerating
I Have A 90' Full Size Blazer - 145,000mi. Whenever I Accelerate The Whole Truck Seems To Vibrate. When I Let Off On The Gas The...
warlock
Battery Light Trouble
I Have A 2002/2003 Hyundai Sonata And The Battery Light Keeps Coming On. I Changed The Battery And The Light Still Hasn't Gone Off : I Don't...
Alucard
HYUNDAI OTHER
Honda Turn Signals
1993 Honda Accord Ex, Turn Signals Will Not Work. Flasher Burned Out; Replaced The Unit, Signals Worked Fine For A Time And Now, Again...
dlpark
Hello! I`M Here..
Hi Everyone! My Name Its Manuel, Im From Guadalajara Jalisco, Mexico I`m Mechanical Engineer And Im Working As A Maintenance Manager...
fisherman
Toyota Paseo 1993 Engine Problems
I Have A Problem With My Car Few Days Ago, I'm Not Shure If It's The Rain That Did It Or Not. Every Time My Motor Reach 2000 Rpm, No...
fralla2
TOYOTA PASEO
1999 Volkswagon Jetta Won't Shift Out Of First?
It's A 1999 Vw Jetta Automatic With No Power Windows. Yesterday I Armed The Car While I Was In It(by Accident), Didn't Think Too Much Of It...
typhoonk
Driver Door Wont Open!! :S
I Cannot Get My Driver Door To Open From The Outside But I Can Open It From Inside The Car, I Recently Installed An Audiovox Alarm, With...
Ronnyboi
Problem With Instrument Panel Lights And Brake Lights
I Have A 1989 Toyota Corolla My Intrument Panel Doesnt Work Same With My Brake Lights The Only Works When You Brake But When The Head Lights...
acura06
1992 Pontiac Lemans -- Poor Brakes
Customer Complained About Poor Brake Pedal. Exact Symptoms Of A Bad Master Cylinder. Replaced The Cylinder, Bled The Brakes At Each...
Squashtowner
PONTIAC LEMANS
99' Malibu
I Have A '99 Malibu, Approaching 150k. Last Month, I Had To Replace The Catalyic Converter. Now, A Month Later, My Engine Is Not Going...
wh1temage
Power Distribution Center 2002 Chrysler Voyager
I Am Troubleshooting A Headlamp (driver's Side) Problem. Based On The Wiring Diagram I Have, The Fuses For The Headlamp Are Contained...
rsedlock
CHRYSLER GRAND VOYAGER
1995 Nissan Altima Stumbles And Dies When Accelerating
I Have A 1995 Nissan Altima With 150000+ Miles On It. When The Car Has Reached Normal Operating Temp And You Press On The Gas The Engine...
fourbyjunkie
Water In Oil
1987 Chevy P/u 1/2 Ton 305 V/8, I"ve Got The Milkly Looking Oil Under The Oil Filler Cap But Not On The Dip Stick. Do You Thank Intake Or...
twocamarobill
1993 Altima_A Unique Challenge
Re: 1993 Nissan Altima. Problem: Difficult To Start, Rough Idle, And Low Rpm Hesitation /stalling. I Have Replaced Fuel Filter, Air...
thomas56a
Oil Usage Problems In 02 Corolla
I Have A 2002 Corolla W/ 77k Miles On It. It Is Using Up Oil Fairly Quickly Between Oil Changes. After Having It Checked At A Nearby...
EnFan
Pontiac Sunbird '93 Stuck In Park. Cable?
My 93 Pontiac Sunbird Is, For All Practical Purposes, Stuck In Park. Auto Transmission. You Have To Practically Hit It With A Hammer To...
lardca
20184
20185
20186
