1999 Dodge Durango Not Starting Error Message "no Bus&...
1999 Dodge Durango Is Not Starting Giving Error Message "no Bus"
Rick Casanova
DODGE DURANGO
94 Silverado Rear End Noise
I Have A 94 Chevy Silverado, 6.5l Diesel, With 200k On It. Recently I've Been Noticing That Whenever I Accelerate A Whining Noise Seems To...
steddle
How Do I Remove Rear Brake Rotor?
I Am Doing A Brake Job On My 1995 Isuzu Rodeo, 3.2 V6, 4wd And Need To Know How To Remove The Rear Brake Rotors. I Have Already Removed...
wench
Spark Plugs
I Just Replaced My Spark Plugs And Was Told Be Two Different People What Gap They Should Be, But For Some Reason I Got Two Different Gaps :...
Babe
Good Problem Solvers!
I Need A Good Problem Solver. I Have A Pretty Good Idea What Might Be Wrong With My Car, But I'd Certainly Like To Hear From Bmw Community...
nb0474
BMW OTHER
97 Dodge Intriped.
This Car Surges At Any Constant Speed. Why? I Also Have A Po305 Code, But Have Changed The Plugs And Wires. It Was Gone For Two Days And...
Thunderhorse
DODGE OTHER
Fuelpump-sendingunit For 2000gmc Yukon
Need Imfo On 2000 Gmc Yukon Fuel Pump-sending Unit
michael_hernandez12
Spark Plugs
Spark Plug Broke Off. How Can I Get It Out
todds
My Car "Coughs" When Stopped -- Help!
Hi, I Have A 1992 Toyota Camry (automatic, V6) With About 151,000 Miles. The Past Two Weeks I Have Noticed That My Car Shakes...
rburr001
1989 Acura Leagend
Check The Transmission On The Wipers Motor And The Arm Are You Sure The Motor Its Turning?
fisherman
HONDA OTHER
Idle Drop
Hi I Have A 2002 Dodge Dakota 4.7 V-8 Auto Tranny. After Engine Warms Up, When I Stop At A Light, Engine Drops From 700 To 500 Rpms. I...
modocdave
Dashboard Warning Lights
After Starting The Car The Following Red Warning Lights At The Dashboard Will Stay On: Brake, Battery All Car Doors Open Initially...
satbhardwaj
Pcv Valve
I Have A 1993 Lumina. Where Is The Pcv Valve?
dealer819
1997 Ford Taurus Gl Sway Bar
I Have A 97 Ford Taurus Gl With About 70k Milles. I Took It To The Dealer To Get The Oil Changed And They Told Me That My Front Sway Bar...
dsberger
Mazda 1998 Protege EGR Valve
I Have A 1998 Mazda Protege Lx, 1.5 L Engine, 133000 Mile. The Check Engine Light Came On And We Were Told The Egr Valve And Catalytic...
zeke
MAZDA PROTEGE
Y NO Response
I Have Posted A Legitimate Question/concern Regarding An Engine Swap That I Am In The Middle Of. Why Has Nobody Responded Or Offered Any...
zac1823
MAZDA OTHER
2000 Mazda Protege Floorboard Leak
The Floorboard Of My Mazda Protege Is Leaking On The Front, Passanger's Side. I Noticed It Because My Padding As Drenched With Clear Water...
Jewles
MAZDA PROTEGE
Code P0432
Hi I Have A 2001 Jeep Wrangler Set Code P0432 This Jeep Has 4.0l Motor It Has Two Mini Cats As Well As The Main Cat Jeep Is Running Fine...
burr
JEEP WRANGLER
Idle Control
1999 Ford Taurus With Durotec Engine. The Mileage Is At 108000. It Will Idle On Start Up At 2000 Rpms. For About A Minute And I Have...
mckinney
Battery Light
I Have A 1989 Honda Accord Lx 175,000 Miles. I Had The Battery Light Come On Last Week. Checked Battery And Alternator, All Good. This...
kcstang
Bronco Front Shocks
1993 Ford Bromco, Full Size, 5.8 Litre. 160,000 Miles Quad Shocks. When You Order Shocks The Rear Are, Of Course, Rear Shocks And The...
chilienojado
Radio Loses Stations Preset
After Overnight Parking, When I Start My 2000 Camry (100,000) Miles And Turn On The Radio, All Previous Programed Stations Are Lost. What...
pipin
1996 Ford Taurs LX
Having Problems Driving Over 45mph ( The Last Gear Won't Change) The Rpms Are Goining Up And Up.[/B]
sip
Odometer Increased 115K After Servicing
I Took My 1992 Form E150 Van To The Local Garage And After Being Serviced (for $700) The Odometer Read 115k Miles More Than When I Took It...
fordvan
Question About My 1994 Pontiac Grandam Temperature...
The Temperature Gauge Barely Even Gets Past The 100 Mark. Im Not Sure What The Problem Is, It Has Been This Way Since The End Of Last...
willhanning1
20158
20159
20160
