Engine "stumbles"when Cold
I Have A 1995 Ford Thunderbird /v8/auto/ 71,000 Miles. Check Engine Lite Came On 2000 Miles Ago. Tech Said It Was Maf Sensor. Car Runs...
JulieMay
FORD THUNDERBIRD
Oil Change Indicator Lights
I Have A 1994 318i With Approx. 230000 Miles. When You First Turn On The Ignition, A Display Lights Up In The Dash Showing How Close You...
pgrun
BMW 318
95 Olds Achieva Overheating
I Have A 95 Olds Achieva 2.3l. Quad 4 With 152,000 Miles. It Recently Had The Water Pump Go Out So It Was Replaces With All New Gaskets...
silverado boyz71
1994 Camaro Transmission Failure
I Have Been Told That My Transmission Is Torn Up. My '94 Camaro Will Crank And Run, But When I Go To Put It In A Gear It Dies Out. I Have...
shelley
Ran Over Something In The Raod And Passenger Side Tire
Is Approximately 1/2 Inch Further Back. How Much Of A Mess Do I Have. Is This An Easy Adjustment?
DGDanieljr
MERCEDES BENZ OTHER
Top 5 Most Common Installation Problem
Hello, I Am Trying To Gather Some Info About The Most Common Problems With Any Type Of Repair Underneath The Hood. Anybody That Would...
dave72923
2000 MAZDA MPV 70,000
I Have A 2000 Mazda Mpv That Will Not Idle; I Also Have Been Having Problems With A Load Humming Noise Coming From The Air Filter Box. I...
56kruse
MAZDA MPV
Engine Knocking 2002 Nissan Maxima
I Drive A 2002 Nissan Maxima Se Model With 30k. About A Week Ago I Noticed A Light Knocking When I Accelarate Between 2k To 3k Rpm And At...
hernandf
NISSAN MAXIMA
Car Problems
Recently My 1998 Mazda 626 Has Been Having Problems. First It Over Heated And The Oil Was Completly Empty. It Was Full. Then While Slowing...
jennyward
MAZDA 626
1999 Dodge Neon
The Radiator Fans (there Are 2, Neither One) Turn On. I Purchased A Haynes And The Info States They Both Should If The Air Conditioner Is...
plabi
Why Wont My Starter Catch To My Flywheel?
My Car Wont Start, And My Starter Is Good But It Just Wont Catch To My Flywheel. It Grinds Sometimes But Tries To Start Other Times. How Do...
Inlow1990
MITSUBISHI OTHER
93 Crown Vic
What Are The Best Replacement Valve Stem Seals. Thanks Tony
Tont D
Back Wheel Locking Up
I Have A 1993 Ford Explorer Which Has 171,000 Miles On It. My Problem Is The Rear Driver Side Tire Will Lock Up When Going Forward. It...
rum01
2001 S-Type 3.0 Jaguar
78,000 Miles, Bought Used In September. Noticed It Was Sometimes Hard To Get Out Of P And Put In Gear. Then, The Gear Shifter Got Stuck In...
cherylgrounds
JAGUAR XJS
Problem With My 95 Aurora
I Have A 1995 Olds Aurora And I Just Got My Oil Changed Last Week And Now My Computer Says Oil Level Sys Fault. I Dont Know What It Means...
cride187
Drivetrain Malfunction When Driving
My 2000 Crown Vic ( 61000 Miles ) Has Been Having Intermittent And Worsening Problems Shifting From Lower Speed Gear To Higher Speed Gear....
oicghd
FORD CROWN VICTORIA
1995 Mustang Manual Transmission
I Have About 120000 Miles On My 1995 Mustang 3.8ltr Car. Lately Ive Been Having More And More Trouble Shifting Gears. The Problem Seems...
sponge27
Low Cylinder Compression
Hey There, I Have A Nissan Silvia 88' Ca18det, The Engine Has Been Built With Forged Pistons And A 1.6 Mm Head Gasket. The Garage...
markymark_qt
NISSAN OTHER
Possible Engine And Brake Problems
I Just Bought A 1998 Ford Taurus. It Has 135,000 Miles On It. The Check Engine Light Recently Came On And The Brakes Have Started To Make...
1998fordowner
Brake
Hello, My Question I Sprobably Simple For Some Of You. I Changed My Front Right Brake Pads Not Too Long Ago And I Had Noticed They Had...
jaybird24
Brake Lights
I Have A 1990 Ford Aerostar. It Has 127,000 Miles. We Recently Broke Down On The Side Of The Road. When My Husband Went To Get It The...
ksash4
FORD AEROSTAR
1993 Pontiac Grand Am, Headlights Will NOT Turn Off (...
I Have A '93 Grand Am That Has A Strange Headlight Malfunction. They Will Not Turn Off. If The Battery Is Hooked Up, They Stay On, All The...
mechanic116
90 Toyota Tercel 3E- Cooling Fan Stays On After Weber...
I Replaced The Variable Venturi Carburator With A Weber Conversion 32-36 Dgve Kit# 751 I Unhooked And Pluged All Of The Vacuum Hoses And...
maddog2020
TOYOTA TERCEL
Got Timing Belt Change Drove It For 6 Days And Now...
Got Timing Belt Changed At 42,000 4 Years Old Drove It For About 6 Days No Problems The I Heard A Loud Knocking Noise Then Engine Wouldnt...
saffi
ABS Light Reset Switch
I Have A 1999 Eddie Baur Explorer. The Mechanic Says He Cannot Find The Reset Switch To Turn Off The Abs Light On The Instrument Panel....
disctance00
20157
20158
20159
