Idle control
MCKINNEY
  • FORD TAURUS
1999 ford taurus with durotec engine. The mileage is at 108000.
It will idle on start up at 2000 rpms. For about a minute and I have already had a factory bypass motor put on it. I have had diagnostics put on the whole system by the dealer and they found nothing to help. I have checked the mass air flow sensor and it seems to be fine. My question is: Can you give me and indication of what would be causing it to idle at this high rpms whether the car is hot or cold?
Thank you
Do you
have the same problem?
Monday, February 27th, 2006 AT 11:37 AM
LOVESCARS
TPS IF SO EQUIPPED OR THE IAC
Monday, February 27th, 2006 AT 8:34 PM
Recommended Guides
