Nobody Can Explain This….
Ok, So This Is A Problem That Has Started To Occur Here Recently I Will Be Driving My Vehicle In Town On The Interstate Doesn’t Matter...
CrazyColletti50
KIA RIO
CrazyColletti50
KIA RIO
I’ve Asked Everyone And Nobody Can Figure It Out
So Here Very Recently I Will Be Driving My Car And She’ll Be Driving Just Fine And Then Out Of Nowhere She’ll Begin To Bog Down And...
CrazyColletti50
KIA RIO
35, 34 In Front And Rear Driver Side Tires?
Went To Dealer To Have Everything Inspected And Noticed Psi Was 35, 34 In Front And Rear Driver Side Tires And Then The Passenger Side Tires...
alylarosa485
2025
KIA FORTE
Fluid Levels
I Like To Keep Up On My New 2021 Ram And I Do Not Know How Often To Change Fluids. I Drive Only 7000 Miles A Year. I Went In For Tire...
dellunaa
RAM 1500
Straight 6 Crank No Start After Changing Oil Pump...
2002 Laredo 4.0 Straight 6 Crank No Start After Changing Oil Pump Gasket, Rear Main Seal, Pan Gasket, Cam Sensor, Crank Sensor, And...
arianadanielle5345
JEEP GRAND CHEROKEE LAREDO
My Side Mirror Has Harness With 9 Pins?
My Side Mirror Has Harness With 9 Pins, I Can See 2 Pins For Signal Light, One With Pink Wire Other With White Wire, Which Is Ground And...
bebobebo
TOYOTA CAMRY HYBRID
Used An O2 Spacer. P0420
Car Has Been Well Maintained With Records. I Got A P0420 Code. Ran A Couple Treatments With Cataclean. P0420. Used An O2 Spacer. P0420....
dc70
BUICK LA CROSSE
Step-By-Step Instructions On How How To Remove And...
Hi There I'm Looking For Step-by-step Instructions On How To Remove And Replace A 2006 Hyundai Santa Fe V6 Alternator
Tiannareye33
HYUNDAI SANTA FE
Warning Sound Without Any Warning Lights Or Messages...
The Vehicle Sounds A Warning Long Beep Every Time You Get In Shut The Drivers Door And Start The Vehicle Without Any Warning Lights Or...
HGWK
NISSAN ROGUE
Oil Leak Somewhere?
I Took My Car To Get An Oil Change And The Dealership Informed Me That The Car May Have An Oil Leak Somewhere. I Had Them Diagnose The Car...
DodgeGirl96
2011 Chevrolet Malibu Occasionally Getting Code U0101-...
2011 Chevrolet Malibu Randomly Getting Code U0101-00 Lost Communication With Transmission Control Module. It Would Run Fine For Long Periods...
HGWK
Wire Diagrams For Front Drivers Side Door/ Which Fuses
Short Story Is - I Can't Control The Windows From The Drivers Side Although All The Window Switches Work For Each Door. I Also Can't...
Leeloo
CHEVROLET CRUZE
How To Remove The AC Compressor
I Need To Replace My Ac Compressor, I Just Don't Know How To Access It.
Paulsenjake
Started This Morning, Then No Success Less Than An...
Hi, I Am Not Super Mechanically Inclined So I'll Try My Best To Describe. Recently, The Truck Has Been Taking Longer Time To Start...
manderson0501
NISSAN XTERRA
Front-Left CV Axle Assembly
I Went To Brakeplus To Check For A Clunking Metal To Metal Noise And It Turns Out My Front-left Cv Axle Assembly Needs Replacing. I See They...
DIYcarguy25
2022
FORD EDGE
Paddle Shifters On Cvt
I Recently Got A 2023 Nissan Altima Sr 2.5 And Did A Muffler And Resonator Delete And I Often Use The Paddle Shifters Because When Coming To...
ChristianMonro
2023
Cannot Find Location
kellythaxton
JEEP LIBERTY RENEGADE
Test
Tester54545
mypeired
CITROEN PICASSO
Transmission Issue?
Not Sure Why They Made A 6 Speed And An 8 Speed Transmission On These Cars, One Is The Z 6 Speed, If I Decide To Change The Transmission...
divides
HYUNDAI GENESIS
Replace Headlights To LED
I Have A 2012 535i. The Headlights Really Date The Car And Not All Are Functioning. I Want Converge To Led. My Adaptive Are Malfunctioned...
Selinda Etheredge
BMW 535I
Diagnostic Nightmare!
I Finally Got Myself A Cadillac. A Dream Of Mine For Many Years Now. Unfortunately, The Northstar V8 Has Lived Up To It's Reputation...
SWilliams25
CADILLAC DEVILLE
Alternator Not Charging
I Removed The Alternator, Had It Bench Tested At Three Different Outputs, 160,180 And 220 Amps. Passed All 3. Battery Voltage At Main...
Jeff Herman
AC/Heater Box Actuator Issue
I Have An Actuator That Runs Continuously Regardless If System Is On. Hard To Tell Which Actuator Is Making The Sound, But My Guess Is...
DannyBoy5474
Inaccurate Temp Gauge Readings?
Some Days My Temp Will Be Normal Some Days My Temp Will Overspike Past Hot
Kylerodney
17
18
19
20253
