Front Left Driver Door Window Switch Question
Hello 2carpro Specialist, The 2012 Hyundai Elantra Owned Has A Front Left Driver Door Window Switch Panel With A Set Of 6 Buttons, And...
CarQ272
HYUNDAI ELANTRA
Toyota Avensis Diesel Knock At Times & Running...
Denso 89661-05d52 Ecu I Need A Pinout Diagram As Pin 4 On Rail Sensor Sig Is Spikey And May Not Be Reaching The Ecu
careys
TOYOTA AVENSIS
Emission Test Failed
Took My Car To Shop. They Hooked Up A Triton Scanner. For Emission, Scanner Returned, Not Supported Result.
brian2500
GMC SAVANA
I Need A Ecu Pinout Diagram, As I Suspect Rail Pin 4 With Spikey Output May Not Be Comunicating With Ecu, Thanking You Pat
careys
TOYOTA AVENSIS
Car Clicking After Changing Cv Axle And Wheel Bearing
My Car Was Bouncing From The Left Front And I Heard Bad Wheel Bearing Noises When Turning. So I Decided To Change The Wheel Bearing And In...
Kapten Frisk
SAAB 9-3
Kapten Frisk
SAAB 9-3
Rear Main
Does Anyone Have A Good Video Link On The Step By Step Process For Replacing The Rear Main And Oil Pan Gasket For My Particular Model? It...
Tankk2014
167 RELAY NONPOWER TO PIN 85
I Have A 2006 Audii A3 Hatchback. I Don't Have Communication With My Ecu. My Car Cranks But Won't Start. I Am Currently Checking All...
Fixitkelly
AUDI A3
I Have A 2006 A3 Hatchback, The Ecu Is Not Communicating. Fuse 28 And 29 Has Ignition Power But Pin 85 On The 167 Relay Has No Power So The...
Kellon B.
AUDI A3
Mazda 3 2011 Lost Original Fob And Extra Fob Doesn’t...
Hello. When I Bought The Car I Was Given 2 Fobs, One I Would Use Daily And An Extra. I Then Lost The Original Fob And It Appears The Extra...
yellowraccoon
Nobody Can Tell Me What Is Wrong
A Short While Back, I Was Driving Up The Interstate And My Car Was Running Just Fine And Out Of Nowhere It Started To Bog Down And...
1PsychoItalian
KIA RIO
Fuel Pump
Replaced Fuel Pump. It Started 4 Times Then I Tried Again And Nothing. It Cranks But Won't Start. 2006 Titan. Battery Is Charged, Fuel...
Turtle77
NISSAN TITAN
Replaced Fuel Pump And Won't Start
I Have A 2006 Titan I Replaced The Fuel Pump And It Started 4 Times, Then I Tried To Start It Again And It Won't Start. It Cranks But...
Turtle77
NISSAN TITAN
Transmission Shifting
Transmission Has Delayed Shifts And Will Only Shift Down Manually.
Familyman3910
GMC S15
My Car Was Bouncing From The Left Front And I Heard Bad Wheel Bearing Noises When Turning. So I Decided To Change The Left Wheel Bearing And...
Kapten Frisk
SAAB 9-3
Clicking Noise After Changing Wheel Bearing And Cv...
Kapten Frisk
SAAB 9-3
Ignition
My 2005 Dodge Grand Caravan Quit Firing In The 2 And 5 Cylinders. I Put 2 Different Coil Packs In And Got The Same Thing. My Car Is Showing...
Cliff Paden
Coolant
Coolant Is Coming Out Of The Top Of The Engine. I Believe It Is At The Fuel Injector. I Have A Picture.
wanglerbonnie
HVAC CLICKING NOISE
I Have Not Been On Here In A While. My Wife's Jeep Compass Has Just Recently Started Making A Clicking/ Slow Ratcheting Sound/ Might...
CJ MEDEVAC
JEEP COMPASS
Nobody Seems To Know
Ok, Here’s The Situation Little While Back. My Car Started Doing This Crazy Thing Where It’ll Be Driving Just Fine Whether It’s On...
1PsychoItalian
KIA RIO
Help Me Please
Need Help
CrazyColletti1975
KIA RIO
Nobody Can Explain This….
Ok, So This Is A Problem That Has Started To Occur Here Recently I Will Be Driving My Vehicle In Town On The Interstate Doesn’t Matter...
CrazyColletti50
KIA RIO
CrazyColletti50
KIA RIO
CrazyColletti50
KIA RIO
CrazyColletti50
KIA RIO
16
17
18
20253
