Inaccurate Temp Gauge Readings?
Some Days My Temp Will Be Normal Some Days My Temp Will Overspike Past Hot
Kylerodney
AC/heater Fan Not Working?
I Have A 1993 Mazda Protégé That Has An Intermittent Problem With The Ac/heater Fan Not Working. One Day The Ac/heater Fan Will Not Turn...
dycar2008
MAZDA PROTEGE
Car Won't Run?
Loud Knock, Followed By Gas Engine Stall. Electric Motor Has Run On Noise Very Fast Sounding. Gas Engine Won't Start. Car Won't...
Andrewszanto
HONDA ACCORD HYBRID
Code P0796, Where Is The Pressure Control Solenoid C...
My Car, Has A P0796 Code And It's Saying Its A Issue With The Pressure Control Solenoid C. I Haven't Been Able To Find It Online...
Rodrico
Resistance Felt In Front Wheels?
I Was Driving Down The Road And Came To A Stop Sign. After Taking A Left Turn And Trying To Accelerate, I Felt Some Resistance In The Front...
Hsmith190
Code P059F, What Fuse And Where Is It Located That...
Code P059f Indicates That The Active Grille Air Shutter "a" Had A Performance Problem Or Was Stuck Off For A Predetermined Period Of...
Tomas Herrera
NISSAN MURANO
All Of The Electronics Shut Off While I Am Driving?
The Dash And Entertainment Screen. It Turns Black For About 10 Seconds Then Reboots And Says To Start Engine, But I'm Still Driving. Is...
cswenson25
No Start, No Communication To OBD2, Cooling Fans On...
The Original Harness Was Cut Up And Chewed Up From Previous Owner Testing And From Rat Damage. I Replaced The Entire Harness And The Ipdm...
Ali Mahmoud
Radio Wiring Diagram Harness
Have A Wiring Harness And Can't Find Diagram Cuz I Have Different Colors Wires I Have A Red N White One And Orange Green With Yellow...
Charmainbrown
FORD FLEX
I Have The Vehicle Listed Above That Has An Intermittent Problem With The Ac/heater Fan Not Working. One Day The Ac/heater Fan Will Not...
dycar2008
MAZDA PROTEGE
Rear Axle Bearing?
I Have Been Told By A Mechanic My Driver Side Rear Wheel Bearing Needs Replaced. Its A Silverado With Drums In Rear. I've Driven On This...
Rwallace33
Code P2183, I Need Location And Part Number Of...
Need Location And Part Number Of Electronic Coolant Temperature Sensor #2 For 2015 Ford Fusion Energi To Fix Code P2183.
Brian Smith6
Shift To Park Message?
So I Was Driving My Vehicle Listed Above 1500 Denali, With The Badlander Upgrade To Take My Daughter's Friend Home, Which Was About. I...
alicia49white
Fuel Filter/Pump
My Car Is Not Idling And Shutting Off. Not Receiving Gas. The Machine Says Fuel Filter/pump. But Which One Do You Think I Should Try To...
rjacksiii
LAND ROVER EVOQUE
C1185 Abs Code?
Ok As You Know I Had My Brakes And Brake Booster Done Etc. (I Didn't Have Any Cel Error Codes Before My Brake Booster And Master...
Warren1814
FORD E-SERIES VAN
Directions For Removing The Brake Booster Needed?
I Cannot Remove The Brake Booster I Have Removed Everything I Can But I Seem To Be Missing Something. Can You Help Me With Directions To...
Peter kitt
BUICK LUCERNE
Not Cranking Over Issue?
So My Truck Not Turning Over And Won’t Start Up. I Don’t Know If It’s The Starter, Fuel Filter, Or Need A Tune Up.
howelltytus32
ABS Issue, Fuse To Keep Blowing?
Could A Bad A Abs Wheel Sensor Cause The Abs Fuse To Keep Blowing Every Time It's Installed?
divides
CHRYSLER TOWN AND COUNTRY
How Do I Get My Car Out Of Anti-theft?
I Have The Car Listed Above And It’s Stuck In Anti-theft Lock. The Car Will Crank But Not Start. I Tried To Reset It By Doing The 10...
Ash Marie
My Engine Misfires
What Do I Do First?
mypeired
CHEVROLET CAPRICE
Grinding Noise When Driving
The Car Was Recently Repaired After Being Hit In The Front Bumper, But Now It Is Making A Grinding Noise
CB-NBC
2025
Check Engine Light
Ok Guys A Ran My Scanner On My Van And Here Are The Codes It Had On There.
Warren1814
FORD E-SERIES VAN
Check Engine Light
Warren1814
FORD E-SERIES VAN
Car Not Pulling
My Car Does Not Pull Even If You Step The Accelerater To The End. I Have Been To The Repair Shop Several Times Yet No Positive Results
Terry Ayariga
Locking Problems
I Haven't Seen The Vehicle Personally But My Boss Tells Me That The Lock On The Key Will Lock The Front Doors But Will Not Lock The...
Travis Butler2
FORD TRANSIT
18
19
20
20253
