I Have Terrible Luck With Tires?
As You Probably Already Know It Is Very Hard To Find 15-in Tires. I Have Terrible Luck With Tires And I'm In Need Of Some And Thought...
Sarah Wood
CHEVROLET BLAZER
Oxygen Sensor
Where Is The Bank One O2 Sensor Located And How To Replace It?
THE OWL
VOLVO S60
Need A Recommendation For A Good Code Reader For My...
My Chevy Impala Has A Wiring Issue Somewhere In The Traction Controll Or Abs Wiring. I've Replaced The Wheel Hub Assembly That Has The...
Davenoob
140 Amp Breaker Blew?
The 140 Amp Breaker Blew. The Car Battery Had Died A Few Weeks Earlier. I Had The Load Tested On The Batter And It Showed 100%, But The...
crodgers
Body Control Module Battery A Couple Times?
I Have A 2011 Hyundai Veracruz That Has Drained The Battery A Couple Times. The Local Hyundai Service Department Dianosed The Body Control...
dgeiver
HYUNDAI VERACRUZ
Crank No Start After It Got Cold Out Side?
I Tried To Start My Car After It Got Cold Out Side An It Tried To Start A Few Times Which Its Hard Start Always The Car Trys But When It...
kayleepoe141922
HYUNDAI ACCENT
Where Is The Lower Alternator Bolt On A Shematic?
I Am Having Trouble Locating The Part Number For The Lower Alternator Bolt. I Can Find The Top One On Diagrams (m10 X 150mm), But The Lower...
Christopher Sa
BMW 320
Engine Stalls While Driving?
When I Am Driving After A Fill My Tank Up About A Day Or So The Engine Will Hesitate And Die On Interstate As Well. Its Starts Right Back Up...
arockdasupa
Seized Spark Plugs
Spark Plugs Is Hard To Remove What Is The Best Way To Remove Them?
joe1953
CHEVROLET MONTE CARLO
Misfire Cyl. 1 , High STFT?
Just Replaced Spider Injectors With The Upgraded Injectors Can Still Feel A Slight Misfire At Idle And While Driving I'm Getting...
Totalmc
GMC JIMMY
PCM Cut Wiring Harness?
I Have A 1999 Jeep Cherokee Sport 4x4 4.0. Someone Cut My Wife's Wire Harness And Took I Think C3 Plug I Can't Find Out What Wire...
Rome509er
TIPM Oem Part Number?
What Is The New Oem Number For The Totally Integrated Power Module For My 2011 Jgc Laredo? The Old Oem Is Discontinued (68244850aa) Vin:...
RezaS
JEEP GRAND CHEROKEE LAREDO
Alternator Amperage?
Hi There, I Wanna Know The Exact Alternator Amperage Of My 2011 Jgc Laredo. I Guess It Must Be 180 Amp. But I'm Not Shure. Hope You Can...
RezaS
Heated / Cooled Seats Not Working?
2013 Navigator Heated And Cooled Seats Not Working. Both Passenger And Driver Are Not Working. Rear Heated Seat Works. For The Front...
Roosterjuice
LINCOLN NAVIGATOR
Stereo Not Working Display Just Flashes?
My Stereo All Of A Sudden Is Not Working There's Sound & When Turned On The Display Just Flashes Every Couple Seconds & The Only Button...
Seichin
LINCOLN MKZ
Front Defrosters No Air Output?
The Windows Fog Up In Cold Weather, And No Air Or Very Little Air Comes Out Of The Defrosters. Just Wondering If The Blend Door Is Stuck Or...
Safecracker
TOYOTA VENZA
Water/coolant Mixing With Oil?
Oil Dipstick And Oil Cap Look Milky, And White Smoke Coming Out Tailpipe.
joe1953
CHEVROLET CRUZE
No Spark, Just Cranks?
Changed Fuel Pumps, Crank Shaft Sensor, Checked Ignition, Changed Spark Plugs And Qualpack Checked Starter, Fuse #10(starter) Is Pulsing...
Dean 3131
DODGE CALIBER
No Crank No Start No Power At Instrument Cluster?
Had A Fuel Problem Which Turned Out To Be The Tipm, So I Replaced It With One From A Salvage Yard. Same Thing Happened So I Returned It And...
bill.leroux
Change The Rear Main And Oil Pan Gasket?
Does Anyone Have A Link To A Video For My Specific Model On How To Change The Rear Main And Oil Pan Gasket? I Can't Seem To Find One....
Tankk2014
O2 Sensor Faults When Throttle Is Applied?
I Have A 2017 Ford Focus And We’ve Had Our History, Replaced A Clutch, Catalytic Converter, And Other Things. I Truly Love This Car...
Tmreger2022
Control Module Replacement And Location
I Bought A Control Module From Another 2016 Cadillac Srx And Im Going To Install It In Mine And Need To Know Where The Location Is And If...
Scott Picklesimer
CADILLAC SRX
C0074 Error Code
Recently, My Car Needed A Jump Start, And I Found The Battery Voltage Was Low. I Replaced The Battery And Also Changed The Brake Pads At...
vetmohit89
SUBARU OUTBACK
Any Update On Image Posting?
Seems To Be Still Down Across The Site. Multiple Posts That Require Images.
Steve W.
Blend Door Actuator Number And Location(s)?
Are There More Than One Blend Door Actuators In A 2008 Kia Sorento, One For Passenger, One For Driver?
ryanheart93
KIA SORENTO
10
11
12
20252
