Codes P0340 and P0344, can I get a diagram of the camshaft position sensor?
DANNYBOY5474
  • 39 POSTS
Oh, ok. Are you saying test the harness unplugged at the sensor while at idle and then 3k rpm or test the sensor unplugged?
Sunday, June 29th, 2025 AT 9:25 PM
STEVE W.
  • 15,676 POSTS
Unplug the sensor and test on the sensor terminals not the harness and see if you get a voltage at both rpms. Now say you get 1 volt on sensor 2, and you get 1 volt on the "bad" sensor 1 as well, you know that the sensor is working.
Monday, June 30th, 2025 AT 1:52 PM
