Electric windows quit working?
LFUL2441
We here is that 30amp fuse an the power rely located at on the car.
Saturday, May 30th, 2020 AT 12:03 PM (Merged)
2CEXPT
Its inside junction block no.1 left side of instrument panel. Also check main ground at master switch white and black wire and ground point G200 left kick panel
JMART
  • 1994 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 3,540,000 MILES
1994 toyota camry le. The first thing that happen was the cig. Lighter quit working. Then the dome light keeps blowing. Now the passenger window doesn't not work. Except it will go up but down. Not at all on the master switch. Replaced the master switch and passenger side switch. No change. Checked the window motor and regulator. Those are all fine. Fuses are fine. Found no broken wire so far.
FIXITMR
  • EXPERT
Sometimes wires break internally but not externally to make them obvious. They just feel weak/flexxy at the break spot. Between door jambs is most likely place.
MBRIDGES2
  • 1993 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 235,000 MILES
Battery was disconnected for 24 hours then reconnected. The window went down using passenger door switch, but won't go back up. Passenger window control switch on drivers door did nothing. All other windows are strong up and down.
KHLOW2008
  • EXPERT
Hi mbridges2,
Thank you for the donation.
There are 3 possible cause that I can think of.
1. Faulty master control switch
2. Faulty passenger door switch.
3. Failed motor.
Passenger side door switch has same connector as other rear doors. Swap with one of them and restest to confirm that it is not the passenger door switch that is at fault.
MBRIDGES2
After 235,000 flawless miles, why would the switch or motor suddenly fail just from having the battery disconnected? Is there a fuse and/or relay somewhere that could have failed instead?
KHLOW2008
  • EXPERT
Electrical components can fail any time so it could be coincidence it occurred.
A common fuse is used for all the windows so it should not be th cause.
GENTRY13
  • 1993 TOYOTA CAMRY
Electrical problem
1993 Toyota Camry 4 cyl Two Wheel Drive Automatic
lately my camry has been losing power and dying. The headlights, interior lights, and dash lights will all dim and the radio will go off before it dies. The mph/rpm gauges will rapidly move and my windows wont go up or down right before it dies. I have replaced the battery and the alternator but the problem hasnt stoped. It will restart after a jump but doesnt hold the charge for more then a few miles. The problem seems to be worse when my head lights are on. Any ideas?
Saturday, May 30th, 2020 AT 12:04 PM (Merged)
SERVICE WRITER
  • EXPERT
You need to have the alternater checked.
Yeah I know you replaced it.I am very particular to the brand I use. Lotta crap out there. I'm thinking you have a bad rebuild off the shelf.
INANEIGHLY
  • 1993 TOYOTA CAMRY
Electrical problem
1993 Toyota Camry 4 cyl Front Wheel Drive Automatic
passanger side window will go down but not up.
  • EXPERT
These are a switch over motor, that is the pos and neg switch polarity to change direction, so if the window will go in one direction the motor will be ok, so I would be checking the switch first.
Mark (mhpautos)
INANEIGHLY
Window rolls down check it and it is getting power and the switch will work for the window to go down but not up. Could their be a short in the wiring that could not be making a connection to it going up but it works for it to go down.
INANEIGHLY
The switch works hooked it up to the back window and tested it and it works.
  • EXPERT
Does it work from the drivers master switch?
Mark (mhpautos)
INANEIGHLY
Yes it went down with that switch but not up.
NORRIS GILES
  • 1993 TOYOTA CAMRY
  • 4 CYL
  • 16,800 MILES
My driver side window went down and would not go back up, all the others worked my son in law tried to hot wire it to get the window up, which was unsuccesfull now that I bought the main switch and plug it in nothing works windows or door locks im thinking he blowed or shorted something out.I have checked fuses under hood and dash what can I do?
  • EXPERT
Hi there,
Unplug the window motor and check for power with button pushed in, as it only has 2 wires the power switches from one to the other for up and down, so to power the motor, attach power to one wire and earth the other if it goes the wrong way swap around, if nothing happens the motor has failed.
Mark (mhpautos)
  • EXPERT
Last time I had one of there with this problem it was a faulty switch pack, but this will have to be tested by a mechanic.
Mark (mhpautos)
UNCLE BOB
  • 1993 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 128,000 MILES
This car runs like a jet. No problems at all. Until today.
All of a sudden the drivers pwr. Window controls don't work, passenger and back seat window controls still work fine.
If it was a fuse, none of the window controls would work right? A switch ? How tough to fix myself?
Any suggestions?
Thanks guys, appreciate your help.(When santa drops, I'll send a donation your way. Ok?
Sincerely
Bob S.
