A/C compressor replacement?
RYANMMCNUTT
  • 2007 TOYOTA CAMRY
  • 2.4L
  • 4 CYL
  • 176,000 MILES
Replaced ac compressor but the new one has an extra wiring plug on it that wasn't on the old one. How to replace the compressor and vacuum the system down?
Saturday, April 25th, 2015 AT 2:56 PM
WRENCHTECH
  • 20,758 POSTS
Here are guides and videos to help you do the job on your car.
Vacuum down and recharge video
https://youtu.be/4EqdrBVb0sY
This guide will help walk you through the repair with diagrams below to show you how on your car.
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Saturday, April 25th, 2015 AT 3:22 PM
KHANPROMO
  • 2004 TOYOTA CAMRY
  • 4 CYL
  • MANUAL
  • 311,045 MILES
I replaced three times AC compressor, but its always stuck (jam), last time I replaced compressor 1 week ago, but again stuck need replacement new. Mechanic also did not understand why compressor stucking always, please if you have any solution for it pls reply me soon.
Thanks
Mohammed Khan
Saturday, August 29th, 2020 AT 12:13 PM (Merged)
WRENCHTECH
  • 20,758 POSTS
That's because you don't understand A/C repairs and how they have to be done. When you have a compressor failure, all the torn up metal particles from the compressor spread throughout the system and if not resolved, they will ruin the new compressor with the extreme high pressures. Now you have had 3 compressors grenade into your system. You also have to balance the oil when this is done. At this point you will at the very least have to replace the condenser, dryer and expansion valve but you will also have to find out what made the first compressor fail. Contrary to popular belief, A/C repairs are not for the DIYer.
2CP-ARCHIVES
  • 4,540 POSTS
  • 2003 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • MANUAL
  • 89,000 MILES
2003 Toyota Camry mileage: 89,000. The air conditioning was working okay. But, now when I turn it on, the air conditioning knob lights up for about three to four seconds and then starts flashing. Now the compressor will not work.
2CP-ARCHIVES
  • 4,540 POSTS
There is obviously a problem in your air conditioning system. Scanning the computer that controls that system will reveal a fault code that should pin-point your problem.
BEN_OLUFSEN
  • 7 POSTS
  • 2003 TOYOTA CAMRY
  • 4 CYL
  • 50,000 MILES
The A/C compressor on my '03 model Toyota Camry LE does not stay on long enough to cool the interior of the car except when I'm driving fast on the interstate. When I'm stationary it keeps going on and off in intervals of less than a couple of minutes. I stay in the tropics and I have the thermostat set to the minimum temperature.
WRENCHTECH
  • 20,758 POSTS
The system has numerous safety features that could be kicking in because it has a problem. You need to get it checked using a professional set of gauges to determine the reason it is doing that.
BEN_OLUFSEN
  • 7 POSTS
Many thanks Wrenchtech. Any ideas as to what the possible problems might be because I do not have access to professionals where I am currently located.
WRENCHTECH
  • 20,758 POSTS
You don't have any choice. Until you analyze the pressures, there is no clue what is happening or why. You can do serious damage to the system if you continue to use it that way too.
BEN_OLUFSEN
  • 7 POSTS
Thank you. Will do.
ZEUS4669
  • 2001 TOYOTA CAMRY
  • 6 CYL
  • 185,000 MILES
Recently the air conditioning system in my Camry was operationing poorly. I added 27 oz's of Refrigerant and it blows extremely cold 38 degrees. I noticed that the blowers where not functioning to capacity. I removed the manual vents form the dash and I noticed inside the tunnels a wire screen. With my air compressor I blew out all four tunnels and three of the four are now operating to capacity. However, the drivers side the air flow appears to be blocked and fucntioning poorly. Any suggestions? Thank you Mike Karavolas.
Saturday, August 29th, 2020 AT 12:14 PM (Merged)
  • 108,320 POSTS
Remember, what ever you blew through the screen is still in the system. The only thing you can do is remove the ductwork to that vent and check it for obstruction.
THOMAS HAMMOCK
  • 1999 TOYOTA CAMRY
  • 2.4L
  • V6
  • TURBO
  • 350,000 MILES
I used a paper clip to bypass my A/C clutch relay, which turned on the A/C clutch. A/C clutch will not engage with just the relay. I replaced the relay with a new one, same results. So now that I know the clutch works by using a paper clip, where do I go from here?
  • 52,797 POSTS
Good afternoon,
I attached a wire diagram for you to view. The power for the control side comes from the same power as pin 30.
Do you have a test light or voltmeter to do some testing?
SHERRON
  • 1998 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 99,750 MILES
The AC compressor appears to run reversed and does not cool.
  • 31,937 POSTS
Hi there,
The way the compressor is set up it cannot run in reverse. So if you have a cooling problem I would have the pressures checked and if the com is not engaging at all you may have a leak in the system and the low pressure switch has activated isolated the compressor circuit.
Mark (mhpautos)
JEWELS62
  • 1998 TOYOTA CAMRY
  • 6 CYL
  • AWD
  • 270,000 MILES
Will the belt break and stop the car from running if you drive it when the compressor is out on the air conditioner?
Saturday, August 29th, 2020 AT 12:15 PM (Merged)
BILLYMAC
  • 2,204 POSTS
HI if your compressor is makeing a noise and you have a serpintene belt. Then yes it can lock up and break the belt. But if your aircondition compressor has a single belt that runs only the compressor then no prob. Billymac
STEVENKRONTZ
  • 1997 TOYOTA CAMRY
  • 4 CYL
  • 150,000 MILES
With A/C running my car in drive stopped at a stop light, foot on the break I can feel my car jerk and watch the rpm's drop and surge back up again quickly. I was wondering what on the air conditioning unit would make the car drop the tach slightly and jump back up again This only happens when the car is under a load in drive or reverse with the A/C on. With A/C off or the car in park there is no problems. Something on the A/C is what I am thinking and is it replaceable by itself because the A/C work great very cold, so I really was hoping not to have to replace the whole compressor since it works so good?
Saturday, August 29th, 2020 AT 12:16 PM (Merged)
  • 31,937 POSTS
Hi there,
Thank you for the donation,
On the end of the inlet manifold is the A/C idle up valve, this picks up the engine revs slightly whit the A/C on, I would say that this is not working, get your mechanic to check it out, it may only be a broken vacuum hose or a faulty valve, start here.
Mark (mhpautos)
