A/C blows hot air
BRANDYCORD33
  • 2012 CHEVROLET MALIBU
  • 6 CYL
  • FWD
  • 70,098 MILES
I started my car and turned on air it was cold at first then it got hot I watched my gages and nothing changed and now there is a clicking sound and seems like the car wants to die
Monday, June 29th, 2015 AT 8:53 PM
WRENCHTECH
  • 20,757 POSTS
Sounds like the compressor maybe having a problem. This guide should help
Monday, June 24th, 2019 AT 6:53 PM
DSTOCKL
  • 6 CYL
  • 21,000 MILES
The AC works while at a stop or idling, but blows warm/hot while driving. The pressure gauge show the Freon to be at a psi of 45-50 on the low side. Outside temp at the time was mid 80's. Compressor kicks on and off for about 3 or 4 minutes after first starting the car. Any ideas what might be the cause of this?
Monday, June 29th, 2020 AT 12:59 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,973 POSTS
This sounds like a classic case of the system being down on charge. Here are a few guides to help you get the cool back going again.
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
and
https://www.2carpros.com/articles/air-conditioner-leak-detection
and
and
https://www.2carpros.com/articles/replace-air-conditioner-compressor
The low side charge port is on the hose/tube going from the firewall to the back of the compressor.
Cheers, Ken
SSLOVER
  • 2009 CHEVROLET MALIBU
  • 2.4L
  • 4 CYL
  • FWD
  • 98,000 MILES
My car is the LT model. It stopped blowing cold air when A/C was on. Is somewhat of a hot day so I noticed this fairly quickly. Right when this happened I also noticed the temp gauge pointing on "C". No previous A/C issues as just yesterday was functioning properly blowing ice cold air. I have already inspected for any leaks, coolant is full. But both of these seem to go hand and hand (AC/temperature gauge). Also, seemed to have happened randomly. Any suggestions on what this could be?
Monday, June 29th, 2020 AT 1:24 PM (Merged)
KEN L
  • 42,973 POSTS
It sounds like the coolant temperature sensor has gone bad causing both of you problems, Here is a guide that will give you an idea on how to fix it.
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Cheers, Ken
TOMEIL
  • 2008 CHEVROLET MALIBU
  • 4 CYL
  • FWD
  • 33,000 MILES
Like other 2008 malibu owners, I too have a problem with my ac only blowing out hot air. The car has 33,000 miles that I have put on it. Why would this be if the car is still reletivly new. Is it the freont?
  • 31,937 POSTS
Hi there,
The first thing to check is low refrigerant as this is often the cause of this problem, start here.
Mark (mhpautos)
DEBBIE AZBILL
  • 2007 CHEVROLET MALIBU
  • 2.2L
  • 4 CYL
  • 160,000 MILES
Air conditioner was recharged and it took a while before becoming cold. Drove about fifty miles as soon as I slowed down to turn the A/C started to blow hot air. If car is turned off then when restarted and A/C started will blow hot air until windows are put down, like drawing cool air out. Why? Possible plugged/blocked hose?
KEN L
  • 42,973 POSTS
When the cold air stops can you use a flashlight with the engine running and the ac on check to see if the compressor clutch is turning, this will help us narrow down the problem.
Here is a guide that will help
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
TRASHJR85
  • 132,200 MILES
It cooled really good for about 2 years, then would cool off and on, then would only cool while sitting still, now doesn't cool at all. Full of freon, the clutch cuts in like it is supposed to, the air temp control door is working like it is supposed to. The temp gauge is working, the fans are working. Not sure if it is a switch or expansion valve? 104° outside is just too hot for not having a/c in the car.
Monday, June 29th, 2020 AT 1:25 PM (Merged)
CJ MEDEVAC
  • 11,004 POSTS
Is the larger of the 2 hoses under the hood getting cold?
Maybe a blend door issue
THE MEDIC
TRASHJR85
Hoses do not get cold. The blend door is working as designed.
CJ MEDEVAC
  • 11,004 POSTS
How did you determine the charge was correct?
THE MEDIC
TRASHJR85
My brother charged it with freon - that is when it was cooling just when it was sitting still. I am going to have him put his gauges on it tomorrow night so I can get what the pressure readings are. That is probably gonna be a question that comes up at some point.
CJ MEDEVAC
  • 11,004 POSTS
Heres a video on charging your system
http://www.youtube.com/watch?v=CWN6oX3jtOY
THE MEDIC
TRASHJR85
Probably not a good thing, but the high and low pressures are both at 70.
FIXITMR
  • 9,990 POSTS
  • 2011 CHEVROLET MALIBU
  • 2.4L
  • 4 CYL
  • 100,000 MILES
During hot humid weather AC sometimes blows warm and temperature gauge quits. Seems a common problem but no common answer. Car gets to temperature normally and fan comes on when AC is used. In other words no strange symptoms besides quitting. Turning car off and back on does not cure it. Check engine lights when this occurs. Also had code read and p0128 was only code. But thermostat looks to be behaving correctly! This problem only shows on hotter than normal days over eighty degrees and humid. Temperature gauge wiring looks okay, although plastic harness shielding is rotted away from heating. AC system has never been touched from original, car has never been wrenched on other than brakes tires oil changes. When it works it blows cold.
KEN L
  • 42,973 POSTS
This sounds like a classic ac compressor clutch coil that is failing. When the AC is blowing warm check to see if the clutch is spinning.
Here are a few guides to help you get the problem fixed:
and
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
FIXITMR
  • 9,990 POSTS
What I would like to know is if and where there is a relay for the compressor?
KEN L
  • 42,973 POSTS
Here is the fuse box (below) with some guide to help you do some testing
and
Cheers, Ken
