Fuse panel location picture of the flasher relay
RENEE AUSBUN
  • 2001 JEEP CHEROKEE
  • 200,000 MILES
Would like to see a picture of the flasher relay panel.
Sunday, October 27th, 2019 AT 9:05 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,032 POSTS
Here is a guide to help you check the fuse and the fuse panel with locations as well:
and
https://www.2carpros.com/articles/turn-signals-not-working-blinker
Monday, October 28th, 2019 AT 1:50 PM
DJHARTZ1
  • 1999 JEEP CHEROKEE
Where can I get a printout of the fuse box control panel please I love this site :)
Tuesday, August 4th, 2020 AT 5:55 PM (Merged)
JESHEARER
  • 9 POSTS
Should be but there not, GREAT QUESTION! The repair manuals don't even have them. Djhartz1 did you get one if so where?
BMRFIXIT
  • 19,053 POSTS
Fuse box /power distribution center. Click on the images below to enlarge them:
KEN L
  • 43,032 POSTS
Here is a guide and more diagrams (below) to help you get the job done and fix the problem.
and
Please let us know what you find.
JANDREWS
  • 6 CYL
  • 4WD
  • 153,000 MILES
I would like a diagram of some sort to tell me what fuses go to what.
Tuesday, August 4th, 2020 AT 5:56 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Interior fuse block legend is attaced
MICHELLENTODD
  • 1998 JEEP CHEROKEE
Electrical problem
1998 Jeep Cherokee 6 cyl Four Wheel Drive Automatic 150k miles
Both of my brake lights are out, I assume it's the fuse, but I don't have the manual. I need to know which fuse. Thanks
Check fuse no.22 if okay and there's power at the pink and dark blue -adjust or replace the brake switch
CHOCTAW
The factory installed Tow package (Class 111 Hitch) on my 1998 Jeep Cherokee Sport, 6cylinder engine does not work. Fuse checks good but cannot locate the the circuit breaker located near the fuse panel because I can't find the ID number forthis item. Local Jeep Dealers cannot help!
JAY1970
Have you found out the answer to your problem. I recently bought a used 1996 and I have running lights at the rear connection, but no turn signals or brake lights. Thank you.
CHOCTAW
Cannot find location of Circuit Breaker for the towing function. Have looked in" Mitchells" used by Repair Shops. No Luck and No tail, brake, or turn lights either. Good luck!
JAY1970
I have a 96 Cherokee Sport. Behind the spare tire, behind the trim panel is the wiring and the three relays and circuit breaker for my tow package option. Simple test for the circuit breaker is either a test light or DVM to test for 12vdc (ground one lead, touch other lead to both sides of circuit breaker). All three of my relays were internally rusted. Probably from condensation over time. Napa has the relay for under 12 dollars each. My Jeep had relay part number AR634. Check Napaonline. Com for correct relay for your year and model Jeep.
Good Luck!
CHOCTAW
Jay Thanks a lot. Just found out about the rear panel from a Guy last week.
YANKEEFRANK
  • 13 POSTS
  • 1995 JEEP CHEROKEE
  • 4.0L
  • 6 CYL
  • 4WD
  • MANUAL
  • 285,600 MILES
I remove a small black relay instead of the red one that I needed. Now I do not know which slot it goes into.
Tuesday, August 4th, 2020 AT 5:57 PM (Merged)
JDL
  • 16,098 POSTS
Here is a guide to help you check the fuses and the the fuse panel location and diagrams below.
Check out the diagrams (Below). Please let us know what you find.
YANKEEFRANK
  • 13 POSTS
Yes it helps a bit. However, the diagram you provided is correct to a point. Instead of being the horn relay, I have a blue relay (Chrysler #56007348) that is the dual flasher (which I assume does both hazard AND turn signals)
Regards,
Yankeefrank
JDL
  • 16,098 POSTS
Hi, which Cherokee is it, sport--limited--or what? I would think they would be the same? I'll take another look.
JDL
  • 16,098 POSTS
Yes, 93--94, the horn relay is correct. 95--the flasher is in that spot, and the horn relay is in top left empty spot, diagram, no. 5 spot.
I just didn't read far enough in the info.
YANKEEFRANK
  • 13 POSTS
Replaced the relay in it's correct spot, still don't know why turn signals don't work.
