Cabin air filter replacement and location
ANONYMOUS
  • 2010 NISSAN ALTIMA
  • 22,000 MILES
Want to replace my 2010 Nissan Altima cabin air filter. Removed glove box but can't find cabin air filter housing. What is correct location of the cabin filter housing?
Thursday, November 1st, 2012 AT 12:14 AM
REMOVAL
Remove the glove box assembly. Refer to See: Body and FrameInterior Moulding / TrimDashboard / Instrument PanelService and RepairRemoval And Installation.
Remove the console side finisher RH. Refer to See: Body and FrameInterior Moulding / TrimDashboard / Instrument PanelService and RepairExploded View.
Disengage the filter cover tab (1) to remove the filter cover.
Remove the in-cabin microfilter from the blower unit.
INSTALLATION
Installation is in the reverse order of removal. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Thursday, November 1st, 2012 AT 12:38 AM
CAR NANA
  • 148,000 MILES
We dropped the glove box. There was no filter cover much less a filter. We have had a bad odor for a long time. Is it possible the 2010 model has the in cabin filter somewhere besides behind the glove box?
Tuesday, May 25th, 2021 AT 11:16 AM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
Yes it does have an in cabin air filter. It is located behind the glove box, in back of the right hand side console finisher. I have included an exploded view of your vehicle's instrument panel/console as well as step by step instructions from your vehicle's manufacturer on In cabin air filter removal and installation in the diagrams below. Please let us know how it turns out and if there is anything else that we can help you with.
Thanks,
Alex
2CarPros
BUMBLEBEE82
  • 2009 NISSAN ALTIMA
  • 4 CYL
  • 15,000 MILES
Where is my in cabin air filter and how do I replace it?
BLUELIGHTNIN6
  • 16,542 POSTS
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2218.jpg
BUMBLEBEE82
Thank you for your help!
LUAP1955
  • 2008 NISSAN ALTIMA
  • 4 CYL
  • 40,000 MILES
How do I change the cabin air filter in a 2008 altima 2.5s? I removed the glove box but do not see where it is.
WRENCHTECH
  • 20,761 POSTS
Here is a guid that will walk you through the steps and the diagrams below will show you how on your car.
RON ADAMS
How to install cabin filter
STEVEW84
  • 673 POSTS
Remove the in-cabin microfilter from the blower unit by using the pull tab on the bottom of the filter.
https://www.2carpros.com/forum/automotive_pictures/170495_cabin_air_1.gif
JACOLL1356
  • 4 CYL
  • 33,000 MILES
How do you replace the in cabin air filter?
BMRFIXIT
  • 19,053 POSTS
Remove the glove box assembly:
Remove both the console rear screw covers, then remove the rear screws (A), then remove the console assembly. See Fig. 1
Open the glove box door, remove the upper and lower glove box assembly screws (A). See Fig. 2.
Then remove gloce box.
Remove the right hand console side finisher.
Remove the in-cabin microfilter from the blower unit by using the pull-tab on the bottom of the filter.
To install, reverse removal procedure.
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic_50.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_545.jpg
BUSED1964
  • 2007 NISSAN ALTIMA
Where do you find the in cabin air filter
See below and reverse removal process
https://www.2carpros.com/forum/automotive_pictures/12900_cabin_filter3_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_cabin_filter4_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_cabin_filter5_1.jpg
GREGPL
  • 2005 NISSAN ALTIMA
  • 4 CYL
  • 24,000 MILES
I don't want to pay $100+ to have a shop change my cabin air filter. Where (website) can I find a step-by-step instruction or diagrams showing how to do it myself?
Thanks.
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1659.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_516.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_3_36.jpg
WBRUCE
  • 2002 NISSAN ALTIMA
  • 4 CYL
  • FWD
  • 59,000 MILES
Where is the cabin air filter located on this model?
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_02altimacabin_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_02altimacabin1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_02altimacabin2_1.jpg
THAGN25
  • 2001 NISSAN ALTIMA
I tried to replace cabin air filter. I did remove the glove box assembly and could not see a filter cover tab. Do I have to completely remove the black box next to the fan?
Thanks
http://www.2carpros.com/forum/automotive_pictures/396352_08142009140_1.jpg
BLUELIGHTNIN6
  • 16,542 POSTS
Your car does not have a cabin filter you are seeing the mesh that protects the evaporator.
Tuesday, May 25th, 2021 AT 11:17 AM (Merged)
