A/C Compressor Control Relay Location?
GREAL
  • 2005 HONDA ODYSSEY
  • 106,000 MILES
Where is the Honda Odyssey 2005 A/C Compressor Control Relay Standard Ry-737 located in the fuse box There are several relays in the fuse box. Which one is it.
Tuesday, March 27th, 2012 AT 6:22 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,054 POSTS
Here is a guide to help you test the fuses and relays (DIAGRAMS BELOW)
and
and
Looks like you need #12
Under Hood Fuse/Relay Box Fuse
Fuse Number Fuse Name Amps Component or Circuit Protected
1 L H/L LO 10A Left Headlight (Low)
2 RR DEFROSTER COIL 30A Relay Control Module
3 L H/L HI 10A Left Headlight (High)
4 SMALL LIGHT 15A Taillight Relay
5 R H/L HI 10A Right Headlight (High)
6 R H/L LO 10A Right Headlight (Low)
7 BACK UP 7.5A Relay Control Module
8 FI ECU 15A PGM FI Main Relay, DLC
9 CONDENSER FAN 30A A/C Condenser Fan Relay
10 Not Used
11 COOLING FAN 30A Radiator Fan Relay
12 MG CLUTCH 7.5A A/C Compressor Clutch Relay
13 HORN, STOP 20A Brake Pedal Position Switch, Horn Relay, Ignition Key Switch/Key Light
14 RR DEFROSTER 30A Rear Window Defogger Relay
15 BACK UP, ACC 40A Fuse 7 in Under hood Fuse/Relay Box, Fuses 5, 6, 7, 8 and 9 in Driver's Fuse/Relay Box
16 HAZARD 15A Hazard Warning Switch, Turn Signal/Hazard Relay
17 VSA MOTOR 30A VSA Modulator Control Unit
18 VSA 30A VSA Modulator Control Unit
19 OPTION 1 30A Fuses 1, 2, 3 and 4 in Driver's Fuse/Relay Box
20 OPTION 2 40A Fuses 12, 13, 14, 15, 16 and 17 in Driver's Fuse/Relay Box
21 HEATER MOTOR 40A Blower Motor Relay
22 BATTERY 120A Battery, Power Distribution
+B AS F/B 70A Fuses 1, 2, 3, 4, 5, 8 and 9 in Passenger's Fuse/Relay Box
23 +B IG1 MAIN 50A Fuse 33 in Driver's Fuse/Relay Box, Ignition Switch
POWER WINDOW 40A (LX) Fuses 27 and 28 in Driver's Fuse/Relay Box, Power Window Relay
50A (EX, EX L, Touring)
Check out the diagrams (Below)
Cheers, Ken
Thursday, December 21st, 2017 AT 8:17 PM
MTLOWRY
  • 6 CYL
  • 72,000 MILES
Since I bought the car, it has had the Compressor Clutch Field Coil replaced every year. And once again the air just started to blow hot air again. Is there something else that can cause it to break?
Thursday, June 20th, 2019 AT 7:55 PM (Merged)
HONDA TECH 1818
  • 536 POSTS
There could be a leak in the AC system, have your mechanic put dye in the AC sysem and check for leaks.
EHOERBER
  • 6 CYL
  • FWD
  • 55,000 MILES
Odessey is EX model and A/C works great on passenger side but not on driver's side. Airmix control motor, in-car temp sensor, sunlight sensor and climate control panel all work properly and have been bench tested. No DTCs or trouble codes in the climate control panel have been displayed. The refrigerant pressure is good and nothing our of the ordinary as far as sounds or smells. Any suggestions?
KHLOW2008
  • 41,814 POSTS
Hi ehoerber,
Thanks for the donation.
Try turning on the control to the heater and then moving back to the AC.
If it does not help, the air-mix vent seals could be leaking or linkages stuck. You need to check the heater core vents.
EHOERBER
The air mix control mechanism is not stuck and the seals are fine as I can visually check them and see them actuate on both sthe driver side and the passenger sides at the same time. However, one side is cold and the other hot. Periodically I will get cold air from the driverside, but is very infrequent. Is there a regulating valve that controls the refrigerant to the evaporator core that would inhibit the refrigerant from getting to that side intermittently? Or any other suggestions?
KHLOW2008
  • 41,814 POSTS
Hi ehoerber,
Did you perform a sensor test on the driver air mix opening? There is also the Driver Vent Temperature Air Out sensor.
I believe these two items must be giving some error.
LOUISIANA74
  • 2004 HONDA ODYSSEY
  • 6 CYL
  • 86,000 MILES
Yesterday my A/C was working fine. Today when I went to use my van I noticed my A/C wasn't cooling. It is blowing but no cool air. When my compressor kicks on I can hear it but its not kicking on. I am looking for a mechanic to hook it up to the computer to see what it says but we just got hit with a hurricane and no one is open. What could the problem be and what would be the worse case scenario and how much it will cost me?
Thanks
SERVICE WRITER
  • 9,123 POSTS
Cost can be anywhere. Need to find the source.
Sounds like it blew open a leak. Need to see if it will hold vacuum.
JWALIA
  • 2003 HONDA ODYSSEY
  • 92,000 MILES
My 2003 odyssey blows hot air, but my fan does work in all settings. I checked the low side pressure and it was around 120 psi which is very high. I did not recharge the system. When I turn on the a/c the clutch engages but I just get hot air. I tried the following test but I did not get any codes
Turn the Ignition switch ON (II).
2. Press the AUTO button and then press the OFF button. Continue to hold both buttons down for 1 minute.
Please help.
Thanks
Jack
  • 108,300 POSTS
If the system is charged and the pressure is that high on the low side, it sounds like there is a blockage somewhere in the system. Try having it evacuated and recharged to see if that helps.
HONDATECH1983
  • 109 POSTS
You stated the low side pressure, but what about the high side? Is it reading close to the same pressure? If so, your compressor may have failed internally. It may not be generating any pressure/suction causing you to have static readings.
CHRISISHERE
  • 1995 HONDA ODYSSEY
  • 4 CYL
  • FWD
  • 183,500 MILES
I tuned on my air for the second or third time his year. The front ac stopped working and now blows warm to hot air. I had radiator replaced with a Performance brand, aftermarket one about two weeks ago. The ceiling ac in the back blows cold air. What could the problem be? Thanks for any help. Chris
KHLOW2008
  • 41,814 POSTS
Hi chrisishere,
Thank you for the donation.
Problem is most likely due to the air mix cable out of adjustment. Here are the procedures for adjusting.
AIR MIX CABLE
Remove clip and heater duct from heater unit. At air mix door linkage (bottom right side of heater case), disengage cable housing from clamp and disconnect cable wire from control arm. At heater control panel, select maximum cool position and hold it in this position. At air mix door linkage, reconnect cable wire to control arm. Gently slide cable housing back to eliminate slack, then snap cable housing into clamp. Adjust heater valve cable.
CHRISISHERE
I leave it on fresh air only and do not use recirc. Afraid if I use recirc it is going to break on me again. Does this help confirm the diagnosis?
KHLOW2008
  • 41,814 POSTS
The fresh air vent and air mix are 2 different thing and are not related to the warm air.
Only the air mix door would affect the cold and warm air from the A/C.
XCALIBER937
  • 6 CYL
  • FWD
  • 70,000 MILES
A couple of weeks ago the a/c went out in my car. I have tried to work on it to fix it or get an idea of whats wrong before I bring it into the shop to get it fixed. Pretty much the fans work but no cold air comes out. Ive tested the electrical parts like the fuse no luck there, they were all working fine also tried adding freon but it said it was to much already. So im think it has to do with the compressor or there is something clogging up the hoses to maybe create the high pressure. I by passed the fuse with some wire and it was working for like a min with cold air before the compressor started smoking then I stopped. I was wondering if that sounds like the cause of the malfuntcion of the a/c and how to go at the problem to fix it myself or how much it would cost to if I brought it to a shop.
CHRISISHERE
Ac in front works for a while, but withoutout warning it starts blowing warm/hot air in the front. The air works fine in the ceiling ducts for the back seats and do not lose their ac cooling ability.
I am writing again just to confirm that you think it is the air mix door being out of adjustment. The mechanic I am using has been unable to fix the problem. He said if it were the air-mix door then the problem wouldn't be intermittent, but constant instead.
Could it be anything else?
KHLOW2008
  • 41,814 POSTS
Hi xcaliber937,
You mentioned passing the fuse with wires, which fuse was it?
Did you try engaging the compressor with a fuse power supply to test?
Are the cooling fans working when A/C is turned on?
KHLOW2008
  • 41,814 POSTS
Did your mechaninc perform the air mix cable adjustment? If he refuses to perform the adjustment, time to get a new mechanic.
Apart from the air mix cable, the other cable to adjust would be the heater valve cable.
System is not automatic climate control so apart from the above mentioned, there is no other things that can affect the temperature as the rear are blowing cold indicating the A/C system is not at fault.
The orther possible fault would be the air mix door sponge has deteriorated and is not providing sufficient sealing when closed. Repair would require the heater housing to be removed and that means taking the whole dash out.
Thursday, June 20th, 2019 AT 7:56 PM (Merged)
