HVAC wiring diagrams please?
DAVID WYATT
  • 2013 CHRYSLER TOWN AND COUNTRY
  • 3.6L
  • V6
  • 212,000 MILES
The wiring schematics in the Haynes manual don't reflect my van listed above. I have a front blower problem and have traced all the wires to no avail. In the Haynes it says the circuit goes to the TIPM's circuit board but mine goes to a relay. I have successfully ran a fused ignition feed to the blower motor control module to get everything to work correctly. But I can't figure out the relay feed back from the blower control module. A schematic for the whole car would be appreciated because I purchased a factory manual on line but it only goes to 2011 not to 2014 as advertised and the wiring schematic doesn't work for my van too.
My van is listed above with the digital heating system with right and left and rear HVAC.
Thank you again, David W
Thursday, October 29th, 2020 AT 2:05 AM
  • 52,797 POSTS
Good morning,
The relay is for the rear blower, not the front blower motor.
I attached the wiring diagram for you to view. The front blower module is powered by the dark blue wire from the TIPM. You need to verify power is to the module from the module.
If there is, then the module is bad. If there is not, then the TIPM is the issue.
Open hood.
Disconnect and isolate the battery negative cable.
Release the Totally Integrated Power Module (TIPM) cover retaining clips and open the TIPM cover.
Remove the TIPM positive cable retaining nut and remove the cable from the stud.
Depress the four mounting clips to disengage and remove the TIPM housing from its mounting bracket.
Disconnect the wire harness connectors.
Remove the TIPM from the vehicle.
Thursday, October 29th, 2020 AT 2:29 AM
DAVID WYATT
Howdy Roy, where to begin. That is the same wiring schematic that I have but it doesn't seem to be correct for my digital HVAC system. Last thing first, I have ran a fused jumper wire in the TIPM from a fused ignition feed to the dark blue wire feeding the blower resister module and everything works correctly but not with the relay in place. The relay was replaced with 2 known working relays but did not fix my problem. I actually took the TIPM out and tore it down plate by plate looking for corrosion (scary) but did not see a problem still. I scanned the HVAC system and it told me all the switches in the dash were working correctly, my scanner will actually activate the heater controls one by one to see them working. So I took the heater controls out and traced the wiring there too, they were okay also. The relay in the TIPM if removed has no effect on the operation for the rear HVAC. That relay ( K9 ) is between fuse M36, M13 and M25 in the TIPM it also is where I jumped the dark blue wire from the blower resister control module in the TIPM to a good fused ignition feed. The relay socket has a good ignition feed on 2 legs a good HVAC system (dark blue wire) system going out of it but I don't know where the other 2 wires going out of the relay go to. I have been looking at different schematics for different years hoping for a correct schematic, none of them show a relay feed going to the dark blue wire going the my HVAC system! Right now my system is working correctly but not the way it was built :(. Sorry for being so long with details but it is driving me crazy, lol. As you can see my van in spot K9 actually has a relay for the front HVAC relay so I don't know why I can't find a schematic for this van.
Thank you again frustrated, David W
Thursday, October 29th, 2020 AT 11:31 AM
  • 52,797 POSTS
Got it.
From all your testing, I still think you need the TIPM.
Thursday, October 29th, 2020 AT 11:57 AM
DAVID WYATT
Thank you Roy. Any idea where I can find a schematic for this system?
Thursday, October 29th, 2020 AT 12:25 PM
  • 52,797 POSTS
Alldata and Mitchel have the same diagrams I sent you.
You could go to the dealer and ask them for one.
Thursday, October 29th, 2020 AT 12:33 PM
DAVID WYATT
Thank you Roy, sometimes it's hard having a one off car. :(
Thursday, October 29th, 2020 AT 11:34 PM
  • 52,797 POSTS
You are welcome.
Always glad to help.
Friday, October 30th, 2020 AT 4:09 AM
CINSCO23
  • 2008 CHRYSLER TOWN AND COUNTRY
  • 3.8L
  • 6 CYL
  • 160,000 MILES
I want to replace three zone manual climate control (p55111804) with three zone automatic climate control. They have different wiring harnesses. I need to get the wiring schematics for each unit to line up the correct wires. Do you have them? Do you think it will work?
Saturday, February 27th, 2021 AT 10:29 AM (Merged)
CINSCO23
Three zone automatic is p55111807. I forgot that in original post.
STEVE W.
  • 13,018 POSTS
It is not just the harness that is different. You will need to change the BCM programming and the TIPM will need to be changed to enable the controls because the different options use different power and ground circuits.
The automatic system also has extra sensors that you would need to install and a different control module.
If you really want to see what is involved you should get a subscription to Alldata or Mitchell. Those show all the wiring and how it is routed as well as the various parts. From experience repairing both systems you can plan on stripping out the entire dash to get to all the wiring and controls. The rear unit is common to both.
Before I did all that I would find one that has the ATC in it already, with fewer miles.
CINSCO23
Thanks for the information Steve. Looks like I will not be doing that upgrade to the car! Not going to get a different car. I have a lifetime factory power-train warranty and the car is in great condition. I plan on keeping it "forever" and was looking to do a few "upgrades" to the interior!
STEVE W.
  • 13,018 POSTS
Been there done that. I hate replacing vehicles. I have done a lot to get some where I want them but once you get past about 2005 or so all the technology gets in the way. In some ways it is nice but it all creates a mess when you want to alter it or it starts to fail.
VMOLMEN
  • 2000 CHRYSLER TOWN AND COUNTRY
  • 3.3L
  • 6 CYL
  • 110,000 MILES
Blower motor will not run. Replace the resistor, heater switch test/replaced.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,074 POSTS
Hey VMOLMEN,
I have found these wiring diagrams for you to help with the testing. Check the blower fan first then use these guides to continue testing.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
and
Here are some diagrams to help.
Please let us know what you find so it will help others.
Best, Ken
