A/C problems?
BIGGAME JAMES
  • 1995 CADILLAC DEVILLE
Hello, I just charged up my a/c on my 95 cadillac sedan deville first of all it is a used compressor first I was having problems with oring leaks on back of the compressor I pulled a vaccum every time I thiught I fixed the leak well finally I fixed the leak now when I charged the it up I charged it up to about 40 psi ok now while the car is at idle every thing is fine a/c blows cold but when I drive the car just around the block the compressor cuts off now if I take the battery cable off and back on it will reset and come back on but when I drive it it cuts off againg. PLEASE HELP IT IS GETTING HOT
Friday, May 7th, 2010 AT 11:02 PM
FACTORYJACK
  • 4,159 POSTS
Does the control panel switch to 'econ' when the compressor cuts off, auto mode being unselectable? Charging to 40 psi, is that a static pressure, or the low side pressure when the compressor runs? Typically, the a/c system is charged by weight, not pressure. Your system would require 2.0 lbs of refrigerant. The system pressure when static, almost equals ambient temperature, so if it is 40 degrees outside, and the system is not running, then the pressure may read 40 psi. What does the pressure do when the compressor cycles on? Assuming you are tapped to the low side, it should drop. If it drops too fast, and below 20 almost to zero, then it may be undercharged. Does it display a message on the info center, perhaps A/C OFF-LOW REFRIGERANT, or SERVICE A/C SYSTEM?
This guide can help us fix it
Friday, May 7th, 2010 AT 11:26 PM
BIGGAME JAMES
No the econ light doesnt come on. The 40 psi I charged it up to is wile the compressor is cylcling on. As long as the car is on park and idleing every thing is fine but when I drive it thats when it cuts off
Sunday, May 9th, 2010 AT 7:17 PM
FACTORYJACK
  • 4,159 POSTS
I would be curious to see what the pressure does when you raise the speed. Also, do you know how to access your on-boards and check for trouble codes. If you press off and warmer on you climate panel, after a few seconds it should go into a segment check. After this check it will start displaying codes. Record the codes, particularly ECM, and ACM codes. See if that shows anything.
Tuesday, May 11th, 2010 AT 11:10 PM
ANDREW ONDIK
  • 145,000 MILES
Got 95 caddy deville - Cant get the ac compressor to come on I tried jumping the pressure switch did not work any ideas dash board says compressor is off I tried to jump pressure switch and did not kick compressor on will not take coolant?
Tuesday, July 21st, 2020 AT 11:05 AM (Merged)
WRENCHTECH
  • 20,758 POSTS
Disconnecting the battery for a few minutes will reset the computer but whatever shut it off in the first place has to be resolved ASAP or it will set the code and shut down again.
BADBOYMARCUS
  • 71 POSTS
  • V8
  • FWD
  • 125,000 MILES
Why does a/c blow through normal vents. Then starts blowing through defrost and floor vents.I just replace a/c fan blower motor.
FACTORYJACK
  • 4,159 POSTS
If it is operating in 'auto' mode, it will change mode positions based on requested temperature vs in car temperature. At approximately 75, it should be blowing out of dash outlets and continue as cooler temp are requested. As warmer temps are requested, it should blend toward the floor. Improper operation could be from faulty in-car sensor readings, low refrigerant, or possibly a programmer issue.
JULE ROBERTS
Air Conditioning problem
1995 Cadillac Deville V8 Front Wheel Drive Automatic 150K miles
When I first turn on the a/c, it may or may not blow out of the a/c vents. If it does, the first bump we hit, or acceleration and the a/c will blow only out the defrost vents at the front windshield, and there it stays. I have had the car at the Cadillac dealership, and two differenc a/c specialists, they say they have never seen this problem before, and don't have a clue. I am helpless. Have you ever heard of this, and what could cause this. Cadillac said they checked the whole a/c system, and all of the modules. I am on disability and really can't take the heat here in Florida.
DOCFIXIT
  • 18,828 POSTS
Have them check out the check valve to controller see diagram
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_545.jpg
BILLYBOB99406
how do I know which us the low pressure line on a/c so I can add 134a
Tuesday, July 21st, 2020 AT 11:06 AM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
The charge hose will only fit the low pressure/charge side of the system.
In some systems the Low Pressure side cap is Blue. It is also smaller than the High Pressure side.
SCHANNON
  • 1994 CADILLAC DEVILLE
1994 Cadillac Deville Automatic 170000 miles
I recently bought a 1994 Cadillac Deville, and the previous owner told me that the car needed a fuse for that a/c to work. It's a good thing I work for an air conditioning company. Lol. So we changed the fuse, the compressor came on. For a second. The fan never came on and after running it for no more than 2 miniutes, the fuse blew. My tech says that its the fan. Can u help?
Tuesday, July 21st, 2020 AT 11:07 AM (Merged)
KNOWYOURAUTO
  • 113 POSTS
I have a test light called a Power Probe that comes in handy for these cases. It reads the circuit for power and ground but also has a circuit breaker installed for overload conditions. In this case I would connect it to the battery and run the cooling fan to see if the circuit breaker trips determining a bad fan motor.
Use caution with this method. When the vehicle is cooled down unplug the fan motor connection and set an industrial fan in front of the vehicle. If you new fuse fails to blow once the engine is warm, you can suspect the fan.
I also have an inline circuit breaker that can be installed in the place of the fuse and makes a buzzing noise when the circuit overloads. This would be helpful as the fan motor or a/c compressor can be momentarily unplugged during the buzzing. The buzzing would stop and you could again suspect the fan motor.
Good Luck.
TRULOVE
  • 1993 CADILLAC DEVILLE
  • V8
  • FWD
  • 125,000 MILES
Have 93 sixty special Cad. LED on ac won't come on. AC blows thru defrost until led comes on. Have noticed when it's cold or humidity is low (not often down here) it will work after car has run for awhile. System regulates to 75 degrees and will work once LED lights up. Fuel gauge does sometimes does the same. Appreciate ANY help I can get.
RIVERMIKERAT
  • 6,110 POSTS
It sounds like you have a low refrigerant issue. Open the hood and start the car. While the engine idles, turn on the AC. See if the clutch engages on the compressor. Check the relays in the system under the hood. High humidity areas cause electrodes to corrode. You might want to use some rubbing alcohol and an old toothbrush to clean the electrical contacts of the relays, switches and connectors.
WRENCHTECH
  • 20,758 POSTS
I think your issue is electrical in nature and would have to be troubleshooted while the problem is present.
TRULOVE
Where are the relays, switches and connectors to clean? Thx
RIVERMIKERAT
  • 6,110 POSTS
Refer to the attached image. The relays are (facing the engine from the front) at the right rear of the engine compartment.
The compressor coil connector is on the front of the compressor behind the pulley. The switches are the ones on the dash you use to control the A/C.
CADIEMAN
  • 3,544 POSTS
The a/c and fuel panels are controlled by the bcm. One can short the other out. You need to remove both panels. Then unplug the a/c panel connector to see if the fuel panel lights up. If no plug the a/c panel back in. Then remove the fuel panel connector and watch to see if the a/c panel lights up. When either panel lights up the other one is bad. Gl
OSEPHUS
  • 19 POSTS
  • 1992 CADILLAC DEVILLE
  • 4.9L
  • V8
  • FWD
  • 159,000 MILES
Heater blows warm air then gets colder actuator and blend door are working. Both hoses to heater core are hot.
