1991 Ford Ranger no spark
POWDERT90
  • 1991 FORD RANGER
Timing belt broke going 50 mph, but didn't know it. Tried cranking and had spark on the exhaust side (8 plug 4 cylinder) but not on ignition. Figured out timing belt was broken so replaced it but then no spark on either side. Replaced the brain & ignition control module, and tested coil packs which are good. No ignition fuse is blown. I'm out of ideas. Help?
Do you
have the same problem?
Wednesday, September 12th, 2007 AT 9:31 PM
If its a direct igniton system meaning No Distributor the computer might not be telling the ICM to fire the coil. If it has a camshaft and crankshaft sensors double check it.
Wednesday, September 12th, 2007 AT 11:03 PM
Recommended Guides
